TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 7, 2024 at 7:20 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    High, sustained loads on the TRD tune will target 9:1 in some instances.
    Norton likes this.
  2. May 7, 2024 at 7:31 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    That is correct, you get the EO labels from the parts department at Toyota dealers, and the manager is the one who orders the label.
    Unfortunately the labels were discontinued shortly after the supercharger program was discontinued. Some parts departments bought whatever inventory they could find, so that's where you need to look. If you pass through Orange County check with Tustin Toyota. I got a spare label from them last year and they had a handful left.
  3. May 7, 2024 at 7:37 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I am near there — I’ll try there next if RSM Toyota is not able to get it.
    Do you know what part number you got?
    I have found one, 00602-34158
  4. May 7, 2024 at 7:45 PM
    CadCamMan
    TRD SC, suspension
    EO D-425-49, MDC P/N 00602-34155
  5. May 7, 2024 at 8:17 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    If you have a graphics company lined up, I have a spare sticker to use for this @Sterling_vH111
  6. May 7, 2024 at 8:28 PM
    Sterling_vH111
    Sterling
    socal
    I’d have to reach out to my buddy, usually does wraps and stuff but could probably print. Or the dirt bike graphics company that I’ve worked with for close to two decades now will make anything for me, depends if he’s cool with this sort of thing
    SUMOTNK[QUOTED] likes this.
  7. May 7, 2024 at 8:31 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Find a mom with a cricut machine I bet you could get one made quick.
  8. May 7, 2024 at 8:47 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I think @BillDaCat8 hooked me up with some stickers when I picked up my truck. Not sure if he has more lying around.
    SUMOTNK likes this.
  9. May 7, 2024 at 9:12 PM
    SUMOTNK
    Eddie
    Yea, he isn't at the DLR anymore and I got my spare sticker from him a couple years ago.
  10. May 8, 2024 at 7:36 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    is this all or just one case @12.2 WOT?
  11. May 8, 2024 at 8:15 AM
    JustDSM
    Justin
    Ogden, UT
    Every one I’ve logged or tested.
  12. May 8, 2024 at 8:16 AM
    SoCaltaco65
    ok, so not 1 with a bad pump or dirty filter. Sigh.
    Thank you
  13. May 9, 2024 at 4:37 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    I want to thank you for this tread as my guidelines to rebuild the S/C TRD and I just finish rebuild mine last week and bought rebuild kit from ebay for $200 and slide hammer kit $45. I'm following the video from this tread from beginning until end and it's make the job a lot easier thanks for that.
    But when I bought rebuild kit from ebay I got 4 bearings and 2 needle bearings from them, 2 bearings is for nose bearings and 2 smaller bearings I don't know for what as the video on this tread doesn't say anything and I just realized after couple days, is it 2 small bearings suppose to be for bearings rotor supercharger?
    Let me know if I'm wrong if not I want to know how to replace it.
    2nd thing they gave me 8oz supercharger oil, do I need to put it in all of them bc impossible because I didn't take it down from truck when I rebuild it. I even tilted my truck so I can put more s/c oil on it.
    Let me know what you guys think. Thanks
  14. May 9, 2024 at 4:46 PM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    All these number base on stock pulley right?
    I don't try yet to WOT after rebuild it change the pulley to 2.85 urd, intake manifold spacer and 76mm TB. I just scare if will be too lean,
    When is in idle and cruising I got between 14.3 to 14.7
  15. May 9, 2024 at 7:32 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Regarding the 8oz of SC oil, that I just a common container size. It is more than needed. I would not try to overfill by tilting or anything. With the truck level, add to fill hole until fluid starts to run out and then reinstall fill plug. Just like topping off a differential. Overfill=no bueno.
  16. May 9, 2024 at 7:35 PM
    findingthingsout
    midwest
    Those values are mostly irrelevant of pulley size. Unless some limiting mechanical factor was involved. Dipping to 14.3 would occur with a slight load. Do you have a boost gauge?
  17. May 9, 2024 at 8:24 PM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    I just want to make sure the nose bearing got the oil too so not dry but at least I can fill it up about 6oz and who knows the oil will be reduce bc the heat on s/c as when I take it out the old oil from s/c, it's only about 2 or 3oz
  18. May 9, 2024 at 8:25 PM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    I do have boost gauge and afr gauge too.
  19. May 11, 2024 at 8:51 PM
    Suckafartout
    Suckafartout Well-Known Member
    2008 Tacoma trd sc
    Supercharged
    Harbor fried punk rice flim flam from China local depo red tube high temp silicone. You can use it to put Intercooler lid back on too. Or just buy new orange foam dippy.
  20. May 11, 2024 at 9:30 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i would prefer to fasten it how magnuson intended. that foam is rated to vaporize when sucked in the motor. id hate to use a glue that caused problems.
