TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 11, 2018 at 9:44 PM
    #5081
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Did a loooong time ago.
  2. Jun 12, 2018 at 2:48 AM
    #5082
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    You have the stroker kit in yours don't you?
  3. Jun 12, 2018 at 5:26 AM
    #5083
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct you are.
  4. Jun 12, 2018 at 5:28 AM
    #5084
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Eventually a hater's hate finds its way back to hate themselves.
  5. Jun 12, 2018 at 5:31 AM
    #5085
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look at the components they use. The tolerances are good, I can tell you that as well.
  6. Jun 12, 2018 at 6:35 AM
    #5086
    Roostfactor
    TX panhandle
    Whoa! Still trying to wrap my head around all the hate.
    inwood customs likes this.
  7. Jun 12, 2018 at 7:17 AM
    #5087
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's rude to call other people strokers.
    :D
  8. Jun 12, 2018 at 7:40 AM
    #5088
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Wow. If by affects you mean eliminate, you are correct.
    Then again, you have a way with understatements. :p
    So what you're saying is you gotta get juice for your engine to be swole?
    Torspd[QUOTED] likes this.
  9. Jun 12, 2018 at 7:47 AM
    #5089
    ThomasMore66
    Dallas/Fort Worth & Durango
    Odds are one of us breaks something if we stay on the current trajectory of “more”. What does a better 1GR look like? Sleeved? Stroked? Better rods? What’s possible here? What’s a realistic cost? I’ve never seen a cam option.
  10. Jun 12, 2018 at 8:00 AM
    #5090
    Biscuits
    As per @Torspd with regards to cams...
  11. Jun 12, 2018 at 8:04 AM
    #5091
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Set a goal, and achieve it. Let budget guide you. Rods, pistons, headgaskets, and head studs, is the "basic build".
  12. Jun 12, 2018 at 8:06 AM
    #5092
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Cams are an option, but since there are four of them versus the traditional one design it really makes the swap out much more annoying, and expensive as has been mentioned. Which is why it is not a more well known thing. There is power to be had there though. Definitely not as easy as a cam swap on a GM 350 that's for sure.
  13. Jun 12, 2018 at 8:16 AM
    #5093
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The price alone makes most people balk. However, the owners of Tacomas generally aren't after every ounce of power. Therefore the market is extremely small. The only supplier catering to that is one is out of the UAE. Unless you deal directly with Kelford Cams to have a "custom grind" machined. Which is fairly easy.
  14. Jun 12, 2018 at 8:18 AM
    #5094
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Why do I feel like 75% of the people who build their 1GRs end up selling their vehicles shortly after being built. Makes me wonder if it’s worth the $$ for the power, then again there isn’t many who have done it.
  15. Jun 12, 2018 at 8:23 AM
    #5095
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is an insurance policy. I know a few whom have built theirs, years ago, and still have them. People getting a crap shop to build their, creates a bad word of mouth.
  16. Jun 12, 2018 at 9:17 AM
    #5096
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    1jz swap like driftslayer
  17. Jun 12, 2018 at 11:53 AM
    #5097
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  18. Jun 12, 2018 at 12:33 PM
    #5098
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    What size pulley did you go with?
  19. Jun 12, 2018 at 12:36 PM
    #5099
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    You ever get a dyno just on the stroker kit?
  20. Jun 12, 2018 at 12:38 PM
    #5100
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    2.7 at the moment. I have a 2.5 on the bench, but want to check out my afrs and such before I go that far.
    Not a fan of the pulleyboys etching on the 2.7, but I'll live with it for now.
