TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 2, 2024 at 4:28 PM
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    BillDaCat8[QUOTED] likes this.
  2. Sep 2, 2024 at 6:31 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    He just said his trans will get up to 240+ and engine he said highest he has seen is 220 on the UG. He did say if he turns hid ac off it does drop the temps slightly but not exactly the weather you want to be driving in with no AC.
    BassAckwards[QUOTED] likes this.
  3. Sep 2, 2024 at 6:55 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I can't speak to towing, as a I do little of that. I remain happy, however, with and stock cooling and a 2.5" pulley on mine - it works well to compensate for the elevation where I live and generally drive (~5K ft - ~8K ft). When hauling a load on a hot day, I've seen engine temps crest just over 200 degrees. I have a 6MT, so don't normally monitor trans temps.
  4. Sep 2, 2024 at 9:38 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Nice! Hit me up, and we can grab a beer or whatever. I live in San Mateo, so if you're down this way, you're not far off. You're probably mountain biking in my backyard with some of my neighbors.
    Damn sorry to hear about the stud. I need to look into mine. No issues yet but seems like only a matter of time.
    SUMOTNK likes this.
  5. Sep 2, 2024 at 10:02 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I tow 3,500 lbs with a 2.8 pulley and stock cooling. My truck is heavy and I'm running 33" tires on stock gearing.
    I live at 4,500 ft and when it gets hot I am usually towing off road between 6 and 10k ft and moving at slower speeds so I don't get the benefit of the airflow that you have on the freeway.
    It gets hot but I haven't seen coolant temps above the low 230s.
    Norton and BassAckwards[QUOTED] like this.
  6. Sep 3, 2024 at 5:03 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks, yeah that’s too warm to be without AC or blasting the heat to try and cool things down.
    Thanks for chiming in Steve, I have heard that the 2.5 is good for elevation, but I think I might resist the urge to downsize and just leave things alone.. I really don’t want to have cooling problems and the truck pulls just fine with the 2.8
    Thanks for sharing your experience on the subject. That is a pretty good comparison. The 230s would have me in a mild panic though..
    How long ago did you add your blower? I remember reading one of your posts in another thread where you were towing a tandem axle TT when still n/a. Did you ever tow that with the SC?
  7. Sep 3, 2024 at 7:45 AM
    Norton
    A few things I neglected to mention... First, @JustDSM tuned my truck, so I know it's setup right. Second, when I said just over 200 degrees, I meant no higher than about 205. She generally runs around 185 degrees, plus/minus few. Third, I only see increased temps when under a bit of load (e.g., a slow, steady hill climb) and A/C running.
    FWIW, I suspect you'll be happy either way.
  8. Sep 3, 2024 at 8:05 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I agree. Check that whole setup regularly. Every oil change is a great interval.
    Looking at the way it’s designed, that bracket needs more support. Is basically just hanging off of those two long studs and then has that one little bracket over to the compressor. That’s it. Seems under built to me. I’ll stare at it some more in a couple weeks when I’m back in PHX. There’s got to be a way to beef it up by adding another bracket or two.
    I’d also like to work with @Athlaos on my idea for keeping those studs from backing out. Perhaps we can come up with a 2.0 version that includes a couple of additional pieces to get that assembly good and solid.
    nudavinci64 likes this.
  9. Sep 3, 2024 at 8:06 AM
    nudavinci64
    Robert
    yah hard to say. I know with 2.8 I had all sorts of cooling issues. I think a big part was the CSF was not sealing well. But once I add a better trans cooler with a fan it was good or way better.
  10. Sep 3, 2024 at 8:08 AM
    nudavinci64
    Robert
    i like it! I still have stock but some of those waiting but have debated even adding them.
  11. Sep 3, 2024 at 8:11 AM
    BillDaCat8
    Jake
    PHX
    Thanks guys. I’ll be headed down to Menlo Park this weekend to visit the bike shop I bought the bike from. (Woodside Bike Shop) Perhaps we could meet up then.
    SUMOTNK[QUOTED] likes this.
  12. Sep 3, 2024 at 1:21 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Yeah, my old trailer was 5,500lbs loaded but I didn't have the blower then. Transmission temps were higher on average with the old trailer on pavement (didn't tow it off road). The only time I see 230° coolant is in 4lo on extended steep climbs (mile+ long climbs) when it's 100° out and the ac is running. When the trail levels off the temp drops quickly so I assume it's is partially due to the transmission cooler bleeding heat into the radiator.
    I think if you're towing that weight on pavement it shouldn't be an issue.
  13. Sep 4, 2024 at 8:28 PM
    BillDaCat8
    Jake
    PHX
    Anyone know of a secret handshake at SCOL? I mentioned TW to no avail…
  14. Sep 4, 2024 at 8:33 PM
    BillDaCat8
    Jake
    PHX
    Thanks Bill.
    I was hoping to find a no-mod solution. But, if that’s the best option these days… I’ll consider it.
    Billy182[QUOTED] likes this.
  15. Sep 5, 2024 at 12:16 AM
    Billy182
    Bill
    NJ
    X-Runner
    I should be the one thanking you Jake. My 2.5 pulley was slipping like hell, and your wrap mod worked fantastic in eliminating that problem. I got renewed incentive to start driving the truck again and making more improvements, so thank you very much!
    On a side note, I had an rpm belt on it, but felt these belts may be a contributing factor in stud breakage due to their not stretching during sudden engine load changes. It’s just an unproven theory of mine, although the plus side is I haven’t noticed any seat of the pants drivability differences between the fleetrunner and rpm belts.
  16. Sep 5, 2024 at 10:01 AM
    nudavinci64
    Robert
    I have been thinking the same. I had a fleet runner on their first but likely due to a bad cut I had the belt almost come off and switched to the Stock length RPM but with all these issues considering going back to the fleet runner.
    BillDaCat8 and Billy182[QUOTED] like this.
  17. Sep 6, 2024 at 3:54 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Still seeing 10s with 2.7 pulley and methanol. Pulls strong without much heatsoak anymore.
    Should I just keep getting smaller pulleys until my a/f gets a little leaner? Lol
    herecomesace likes this.
  18. Sep 6, 2024 at 4:46 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Just cut some groves in the shaft and go full send. :devil:
    Kidding. Lol!
    IvanhoeTaco[QUOTED] likes this.
  19. Sep 6, 2024 at 10:09 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    The stoichiometric AFR of the methanol injected throws off the AFR reading so it's richer than it would be without methanol injection.
  20. Sep 7, 2024 at 4:52 AM
    IvanhoeTaco
    Eastern NC
    I was at 11 with 2.7 pulley before meth
