TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 7, 2024 at 1:15 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @Musubi3 don't forget to do the fuel pressure Regulator Mod to boost reference your fuel injectors! Congrats on becoming FIed!
    Musubi3 and Norton like this.
  2. Oct 7, 2024 at 4:03 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I went back to page one… what’s the benefit of this? Without it, I don’t see fueling issues and my fuel trims look good.
  3. Oct 7, 2024 at 8:16 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It allows fuel pressure to rise at the same rate as boost, so instead of the injectors fighting cylinder pressure to spray in fuel at it's normal fixed rate (in our case 43.5 psi) as the boost increases, it now has a reference to boost and the pressure climbs at the same variable rate that the boost does.
    Ie: let's say you are making 10 lbs of boost. Instead of staying at a fixed 43.5 psi throughout the RPM band as you are stomping on the pedal you are increasing fuel pressure as the boost climbs and ultimately making 53.5 psi.
    You'd be surprised how much better the seat of the pants feels after you do the mod and are properly tuned for it.
    JasonLee[QUOTED], Norton and SUMOTNK like this.
  4. Oct 7, 2024 at 9:04 PM
    9kfever
    9kfever Well-Known Member
    send it!
    Musubi3[QUOTED] likes this.
  5. Oct 7, 2024 at 9:06 PM
    9kfever
    Rising fuel pressure was a thing of the past with FMUs. Way better ways to tune these days while maintain constant fuel pressure!
  6. Oct 8, 2024 at 8:47 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I'd like to hear what @JustDSM has to say about the HPtunes he does and the FPR mod. I think he recommends and does the tune assuming the FPR mod is done? I'm sure if you have monster injectors you can achieve the right amount of fuel with constant pressure, but to me it seems intuitive to have the fuel pressure always be a certain PSI ABOVE the manifold pressure, i.e. the pressure differential across the injector is constant. Perhaps it doesn't matter with stock pully and boost pressures,, since the TRD tune is rich all the time and doesn't seem to run out of fuel without FPR mod. But as fuel demands go up, so too does the duty cycle of the injectors. At some point you won't be able to spray the fuel required without larger injectors, or added fuel pressure. I don't know where that line is, but curious what "the tuning guru" has to say.
    12TRDTacoma[OP] likes this.
  7. Oct 8, 2024 at 9:02 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    I just went through several sessions with Justin. We never discussed performing this mod. I was under the impression it was no longer recommended so I never brought it up.
    JuanitoBonito likes this.
  8. Oct 8, 2024 at 9:08 AM
    racebug68
    Travis
    Chandler, AZ
    interesting, Now I'm even more curious to hear what he has to say. I would assume it isn't a "do it if you want to" kind of thing, where he either relies on it or not. but perhaps the fuel trims can account for it. I dunno, hope he clarifies
  9. Oct 8, 2024 at 10:02 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Ok, I'll weigh in here. :)
    In the 'early' days before tuning these ECU's was a reality, the "FPR Mod" or "Boost Referencing the FPR" was a way for folks to get some extra fuel at part throttle when under boost to help enrich the truck and provide a little extra headroom in the fuel system to keep IDC's down when running small pulleys. People may have done it for other reasons, but as I came into the scene, that's the nuts & bolts of what people were functionally trying to achieve with this modification.
    Now that we can configure these ECU's directly, this modification isn't essential (in my opinion) for all applications. We can configure when/how the ECU goes into open loop, while also configuring how much and where (RPM/Air Load) the engine enriches. There are situations where it makes sense to do it and others where it would make little to no difference.
    There is specific mapping in the ECU that is used to effectively simulate the effect of the FPR Mod electronically with a fuel modifier table that scales the calculated IPW down when in vacuum. At atmospheric pressure or greater, the airflow model in conjunction with your fuel model will (if properly scaled and configured) will ultimately produce the correct IPW so the observed mixture ratio matches what the ECU is commanding. This is due to the fueling calculation routine in the ECU being configured for a static fuel pressure.
    When you go to a boost referenced FPR setup on these vehicles without specifically tuning for it, a few things happen. Most notably, your closed loop (when you're in a vacuum) fuel trims will get wonky. In some instances, it potentially even triggers a CEL if your other mods (mostly related to the intake/MAF housing) are due to the fuel trim error. You'll find the engine will generally run positive fuel trim values from the FPR mod alone, as the fuel pressure is reduced when in vacuum, and the ECU is expecting and compensating for a static fuel pressure in these conditions. There may be a slight degradation in driveability/idle quality, but I would wager most would not notice. Fueling will be 'normal' when intake manifold pressures are near atmospheric pressure. As you transition to boost, the additional fuel pressure will generally produce a richer than target mixture (assuming everything is 100% calibrated). This isn't necessarily a bad thing, depending on the mixture that's being targeted.
    Circling this back to what I do when I tune these ECU's.. Unless you mention that you've done the mod or want to do the mod, I leave the factory compensation tables intact, and everything will run honkey-dorey just as Toyota intended. If it's specifically asked for, I will edit the compensation tables to account for the change and everything will fuel properly during vaccum and boost (though you might run slightly richer than our targeted ratio (which is ok). In instances where we've got a pretty heavily modified engine that's moving more air than your typical pulley'd truck, I may request you do the FPR mod to extend the headroom of your current injectors or similar. But to wrap it up, it's absolutely not necessary (in my opinion) if you're not on the extreme end of the mod spectrum with stroker kits, cams, ported heads, stupid small pulleys, etc..
    Hope that helps some.
  10. Oct 8, 2024 at 10:27 AM
    racebug68
    Travis
    Chandler, AZ
    excellent. thanks @JustDSM, makes much more sense now. Could be either way depending on how the tune was requested.
    12TRDTacoma[OP] and JustDSM like this.
  11. Oct 14, 2024 at 7:42 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    I have a recent one ( about 1 year old) and when I went to do the butterfly adjustment thing it was already set, so I wonder if I got lucky or it was standard practice now?
    stickyTaco likes this.
  12. Oct 15, 2024 at 8:46 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You probably just got lucky to be honest. Unless Magnuson started tightening up their QA/QC.
  13. Oct 15, 2024 at 2:51 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    No adjustment needed on mine (late 2021 purchase).
  14. Oct 16, 2024 at 12:19 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    When I finished installing the SC, I installed the supplied K&N oiled filter into the stock airbox. I'd like to move away from the oiled filters and wanted to find out what recommendations you guys have for me.
    I'm looking for something that can work well with the SC while still help filter things out in my occasional dusty off-roading. I noticed some using the donaldson powercore for additional filtering, but with the downside of some performance loss. FWIW, I don't mind swapping air filters prior to my outings in dusty areas.
    Is it worth checking out AFE's CAI's, or stick with stock airbox options (i.e. AFE Pro Dry OE repl.)?
  15. Oct 16, 2024 at 1:06 PM
    findingthingsout
    midwest
    AFE CAI is the way. They have 2 options. The older version is preferred last I heard. That is what I have.
    There are also mods and upgrades if you are really trying to up the flow.
    Page 1 of this thread covers this topic.
    scootter82 likes this.
  16. Oct 16, 2024 at 2:11 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    If you want a stock filter and not upgrade to a full intake system, AFE power has a stock replacement dry filter option.
    https://afepower.com/afe-power-31-10114-magnum-flow-pro-dry-s-air-filter
    Norton likes this.
  17. Oct 16, 2024 at 11:10 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  18. Oct 27, 2024 at 2:03 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Got the pulleys off today to swap in some NST lightweight ones. Everything but the supercharger crank pulley.
    I also have those titanium studs in my garage from Eddie a few years back. So far, the Stock studs have lasted about 20,000 miles and there are still nice and tight.
    Part of me says to swap them both out because I’m in there anyways, but the other part of me says don’t fix what ain’t broke…
    Stock studs have unknown mileage on them, but are tight and look good…
    What does the supercharged board say?
    I am running with the gates RPM belt, as I know that has been a topic of speculation lately
    12TRDTacoma[OP] and SUMOTNK like this.
  19. Oct 27, 2024 at 2:57 PM
    Sterling_vH111
    Sterling
    socal
    I’ve also noticed, pretty sure there are supposed to be 3 of these bolts holding the tensioner, right ??!!
  20. Oct 27, 2024 at 3:28 PM
    SUMOTNK
    Eddie
    I also try to subscribe to the "if it ain't broke...don't fix it" philosophy.
    But somehow I'll convince myself that it's a modification that is somehow better than the non-broken stock item and therefore, the above adage doesn't apply. I'm fairly certain that's a symptom of being bitten by the modbug.
    Eg: the stock pulleys weren't broken but the NSTs are lighter. The stock studs weren't broken but these Ti studs are hypothetically stronger.
    With that said... my studs are still not installed. Haven't had a reason to tear apart that area.....and I probably just jinxed myself right there.
    Lastly, the Ti studs were the hard work of @Athlaos. I was only involved in the US shipping logistics. Gotta give credit where credit is due.
    And holy crap... I want to check the bolts on my tensioner now. Good luck @Sterling_vH111 and let us know your impression on the NSTs.
