TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 19, 2018 at 11:53 AM
    #5121
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    Exhaust is 100% stock.
    I was just getting into that part of the thread and was starting to doubt that I really needed the FPR mod. I’ll leave the jet out and reference VAC for now. I’m still trying to figure out which WB/boost gage I want to go with. Im leaning toward the PLX DM 6. I’m running a scanguage for all the other stuff.
    I’m thinking the money would be better spent there than on an intake. That’s why I was wondering if they’re really worth it? I’m already running the AFE dry filter in the stock intake with the charcoal filter removed.
    I had that spark knock noise reflash back in 2014 so there was no option for the TRD tune for me. I received a BD tuner that was specific for the SC Tacoma so the “stock” tune is what I loaded and did not change it for the 2.85 pulley.
  2. Jun 19, 2018 at 11:59 AM
    #5122
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Crap.... u got bullydog tune?
    Get the wideband asap, get the boost gauge and intake later
    Just throwing more parts on the truck for fun without knowing if the existing tune is safe is like russian roulette
  3. Jun 19, 2018 at 12:29 PM
    #5123
    Del Scorcho
    Eagle, ID
    It’s not the BD tune. It’s Magnuson’s tune which is nearly identical to the TRD and they just use the BD to deliver it. The actual tune developed by BD for the SC Tacoma is whole other pile of feces. That one is not in my truck.
  4. Jun 19, 2018 at 12:31 PM
    #5124
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Reguardless of what time you run, running without a wideband and boost guage is silly. Especially when not running it in 100% stock form.
    12TRDTacoma[OP] and Roostfactor like this.
  5. Jun 19, 2018 at 12:45 PM
    #5125
    Del Scorcho
    Eagle, ID
    Nearly all of my driving is between 2500ft and 9000ft. Even in winter, I’m nowhere near standard at sea level. At the moment, running lean is not a problem and I’m not towing anything.
    A wide band will probably be my next project, and I will for sure have one before I start towing a trailer.
    Being up at higher altitudes I was just wondering if the intake was really worth it without doing anything to the exhaust. I’m not touching the exhaust because to me it sounds like a bunch of squirrels trying to claw their way out of a metal trash can. No way to make that 4.0 sound good.
  6. Jun 19, 2018 at 12:47 PM
    #5126
    ThomasMore66
    Dallas/Fort Worth & Durango
    No Tacoma’s in Rome.
    Roostfactor, loginfailed and Biscuits like this.
  7. Jun 19, 2018 at 1:39 PM
    #5127
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Seems kinda silly going through all that is involved with running a S/C to not open up the exhaust. With a good sized muffler and a couple resonators you can make it sound descent, and not too loud.
    From my reading every truck is slightly different, even with matching mods. The WB AFR should be required... I can vouch for the PLX devices, I even run the PLX bluetooth dongle for the Torque App.
  8. Jun 19, 2018 at 2:42 PM
    #5128
    inwood customs
    Dave
    Yeah, the stock setup is def holding back some ponies.
    as for exhaust sound I agree with you, Ive been thru so many exhaust configurations its hard to remember.... But I finally found MY happy place.
    May not work for others, but thats because after you get the sizing/headers/ypipe figured out, SOUND is subjective.
    finding the "right" muffler/mufflers is a personal choice.
    https://www.youtube.com/watch?v=d-M-CyyQz48
  9. Jun 19, 2018 at 3:08 PM
    #5129
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    To answer your question on the afe intake if it will make a difference while having stock exhaust, the answer is absolutely. It was worth the money and the bonus for me was that it made the whine louder. It increased throttle response and power through out the range. I did this with stock exhaust after a couple of months of installing the supercharger. It makes a difference. I would get a wide band for sure though.
  10. Jun 19, 2018 at 5:27 PM
    #5130
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I am just down the road from you and I can tell you that you are running rich, but how rich seems to be different with every truck and every elevation change. But yes switching from the factory intake with a high flow filter to a AFE stage 2 does make a difference. It took my AFR's from the high 7's to the low 8's. Yes I am absurdly rich. But that did make a difference. And my sensor took a shit on me so I am not sure if going from the AFE dry filter to the new Donaldson filter helped or hindered my AFR. Back to the Denso sensor searching for my Innovate.
  11. Jun 19, 2018 at 5:31 PM
    #5131
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    What did you end up with for your exhaust? Sounds pretty similar to mine. URD spec.U headers and spec.U equal length exhaust with two MagnaFlow 59955 cats just before the merge to one pipe and a 18" glasspack between the muffler and the tip.
  12. Jun 19, 2018 at 7:12 PM
    #5132
    inwood customs
    Dave
    Thorley long tubes, urd ypipe, 3" borla xr1 right after the ypipe, urd 3" piping from the mk2 exhaust..... flowmaster super 44... chopped after axle.
    mr.trd[QUOTED] likes this.
  13. Jun 19, 2018 at 7:26 PM
    #5133
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I've been eyeing the Borla X-1 series. Never heard it on a Tacoma.
    inwood customs likes this.
  14. Jun 19, 2018 at 10:56 PM
    #5134
    Biscuits
    If it's not too much trouble, could you post a clip of what it sounds like in the cab at speed?
  15. Jun 19, 2018 at 11:10 PM
    #5135
    inwood customs
    Dave
    Lmao, i just bought 4 new side doors (sd card cover) for my gopro. Without them, the slightest bump corrupts the whole file. They should be here on the 26th.
    Ill try and remember to do this tho... i dont have many vids of the current exhaust setup and also dont think i have any at highway speed inside the cab.
    You know its not the borla kit right? Its a frankenstein. The only borla part is the xr1 after the ypipe.... its super small.
    Biscuits[QUOTED] likes this.
  16. Jun 19, 2018 at 11:15 PM
    #5136
    inwood customs
    Dave
  17. Jun 20, 2018 at 1:04 AM
    #5137
    Biscuits
    Thanks man, I'd appreciate it.
    Lol yeah I know. I had a SI/SO Borla X-1 on my Silverado. Lopped off the stock oil drum of a muffler and replaced it with the X-1.
  18. Jun 20, 2018 at 7:46 AM
    #5138
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are ways. There are ways.... :devil:
  19. Jun 20, 2018 at 2:40 PM
    #5139
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You sporting dat der Fiat?
  20. Jun 20, 2018 at 3:02 PM
    #5140
    inwood customs
    Dave
    actually I found a clip of me merging on the highway from a yield.
    I had my lady, a ton of luggage, and my dog with me so I was easing on the gas to about 70 and then maintained.
    For some reason the clip seems much louder than I recall my truck sounding. (maybe the location of the camera near the windshield capturing resonance?). I have some drone from the super44, but I cant recall it being quite this loud. Windows up and ac on
    If it plays in potato mode, the video was just uploaded and sometimes it takes a few minutes for youtube to play the clips in 1080p
    https://youtu.be/p1SXORcSZsk
