TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 2, 2024 at 9:13 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I have had the hypertech installed for almost 10 years so my calculations are near what they should be.
    jamesepoop[QUOTED] likes this.
  2. Dec 2, 2024 at 9:13 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I mean.. 4.88 is definitely a jump. I'm not surprised at all then. I get shit mileage with the weight and my 4.56s.. like 10-11 mpg..
    Norton likes this.
  3. Dec 2, 2024 at 9:14 AM
    nudavinci64
    Robert
    yah but 4.56 to 4.88 is not really a big jump. if it was stock to 4.88 sure but 8 mpg. Im not the only person running 4.88's on 2nd gens.
  4. Dec 2, 2024 at 9:24 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I get it.. I just wouldnt be surprised if you're seeing that more than anything else. Thats why I stuck with 4.56's.. its already high rpms now.. 4.88's only make it worse.
  5. Dec 2, 2024 at 9:27 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Ita been quite a few years (over 8+) but I swore my mpgs went down A LOT when I got my walbro installed. Like a 2-3mpg loss similar to what @nudavinci64 is describing.
    But knowing fuel pressure/trim is regulated regardless of pump capacity, and I don't smell gas vapors, no CELs, and dyno pulls have shown proper AFR....
    .....I attributed it to the natural working conditions of the new fuel pump. Only because I couldn't explain the drop in mpgs
    :confused: sorry...
  6. Dec 2, 2024 at 9:28 AM
    nudavinci64
    Robert
    yah I get that. It was not an option, nor would I have. I liked 4.56 but i ran it with smaller tires then bigger tires then and didn't see much of a difference so would be surprised it would drop that much but that is def a harder one to test out.
  7. Dec 2, 2024 at 9:32 AM
    SUMOTNK
    Eddie
    @nudavinci64 new wheel/tire setup? Didn't you go from Wilwood to PowerBrake or something? Brakes dragging?
  8. Dec 2, 2024 at 10:22 AM
    nudavinci64
    Robert
    There has been no new brake setup in the past 2 years but am running Stoptech Front/Rear. I don't hear any dragging. Tech the brakes were swapped over to the rear axle but haven't heard or felt it drag. I put some new wheels on but the same tires, which could be an issue since prob worn differently. Eventually, I will get new ones.
    SUMOTNK[QUOTED] likes this.
  9. Dec 2, 2024 at 11:37 AM
    nudavinci64
    Robert
    I plan to plug in my HP tuner and get some logs this weekend. Is there anything specific to look for? It's been a while since I loaded it up or I can post up some screenshots.
  10. Dec 2, 2024 at 12:21 PM
    nudavinci64
    Robert
    I started it up just now and noticed that at Idle in Park, I am idling a bit higher than expected. It was cold to start, but after a few minutes, it was still sitting at 1200 or so. I took it for a spin around the block, and it is sitting at 1000. I did not see any loose Vacuum hoses. I will give the MAF a bath later and see if that helps. Are there any other things that may continue to elevate idle? 02 sensors would be my other thought just not sure how to check that assuming getting some logs will help. I it on my ULtra Guague, and they are reading in Lambda around .9 - 1 normally so didn't think much of it.
  11. Dec 2, 2024 at 2:17 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    If you don't mind, send me a 30 second idle log followed by a very slow, steady and controlled rev up to 4K RPM in park. (should take about 20 sec to get from idle to 4K).
    That'll tell me a lot about what's going on.
    Norton likes this.
  12. Dec 2, 2024 at 2:31 PM
    nudavinci64
    Robert
    Sounds good ill run a log. Need to dig out the laptop for the HP. Thanks Justin.
    JustDSM[QUOTED] likes this.
  13. Dec 4, 2024 at 9:51 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
  14. Dec 4, 2024 at 3:02 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Stock belt is fine on a 2.8 in my experience
    Norton likes this.
  15. Dec 4, 2024 at 8:45 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Stock belt works well here, all the way down to 2.5" RIP-modded pulley, with @Roostfactor's pulley wrap mod and the stock tensioner. :cool:
  16. Dec 4, 2024 at 9:26 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Hi Trav
    If you find one that’s actually available, PLEASE let me know!
  17. Dec 5, 2024 at 7:36 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Finally passed annual emissions. Time for fun
    1000020632.jpg 1000015226-01.jpg PXL_20221120_191307448-01.jpg Screenshot_20241119-110629.png
    SUMOTNK, nudavinci64, XPOTRPR and 3 others like this.
  18. Dec 5, 2024 at 10:05 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It blows my mind that you Cali guys put up with all that and commit to installing and uninstalling shit just to pass emissions.. Sounds awful.. lol and I'm totally taking advantage of it tomorrow when I get out there to pick up my new toy from someone who is just over it all and is throwing in the towel on getting it to pass smog.
    Joining the other side of the boosted life spectrum.. 86 Turbo 4Runner. Looking forward to going down the Turbo rabbit hole. We drive out in a few hours.. staying a couple nights out there to take care of everything and prep it for the drive back on Saturday.
  19. Dec 5, 2024 at 10:28 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    What part of cali are you picking it up from?
  20. Dec 5, 2024 at 10:31 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Huntington area.
