TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 8, 2025 at 6:22 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Boost #’s and warm up time sound normal for your altitude and lower thermostat to me
    Norton likes this.
  2. Apr 8, 2025 at 8:38 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Thanks. I may need to go to a 2.8 - I'm a bit gunshy of doing more, don't want to snout cut and I remember reading past 2.8 theres transmission stuff you need to do as well. But I might get there too!
    As far as temp goes - should I be concerned about letting it warm up more? Unsure if that's a gauge issue or a real read warmup issue.
  3. Apr 8, 2025 at 8:50 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    If you tune the truck properly, it doesn’t matter what altitude you’re are when you tune it. My 2¢
  4. Apr 8, 2025 at 9:04 AM
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    Appreciate it! I was leaning on info from years back when my tuner suggested I get re-tuned when I moved from Colorado to North Carolina (EFR Turbo'd Audi). For the Tacoma the change won't be nearly as drastic, but it'll still be about 3,000ft different, so I'm not overly concerned.
  5. Apr 8, 2025 at 12:13 PM
    Sterling_vH111
    Sterling
    socal
    I think the 2.8” pulley is perfect. I have it.
    I get about a peak of 7 psi at sea level.
    I also have a 160° thermostat, and notice it takes a little longer to warm up, but I also don’t rev or mash throttle on any vehicle until it’s warm.
    Also if you’re going by the OEM gauge, that thing is pretty vague and generalized so I wouldn’t worry.
    If you do see consistent cold temps in the winter, this could be an issue if the truck takes too long to get up to operating temp or never quite fully reaches that threshold.
    The ECU I believe has some codes it will trigger if this is the case.
  6. Apr 8, 2025 at 12:22 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    You picked a good time to order that! New China tarrifs up to 104%!!
  7. Apr 8, 2025 at 1:14 PM
    Operator8
    Woodland Park, CO
    SAS INW
    That on top of them bumping the price up $2k.... Thankfully I was also able to save about $400 when it came to taxes.
    scootter82[QUOTED] likes this.
  8. Apr 8, 2025 at 3:39 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    No. @JustDSM tuned mine remotely for this elevation. Zero problems. Highly recommended.
    My advice, FWIW, is to cut the snout before you install everything and go with a Smoothflow Quickchange Hub. That gives you the most flexibility with the least ass-pain in the future. I'd also argue you can comfortably go with whatever pulley size provides stock boost levels. Going above stock boost is where concern is warranted.
    This is good advice, especially for a custom-tuned vehicle with forced induction, descending from a higher-to-lower elevation. Without adjusting the tune, you're likely to run lean, which can destroy your engine. Coming from lower-to-higher elevation is less risky, as you're more likely to run rich, which tends to threaten only your plugs and cats.
    SUMOTNK likes this.
  9. Apr 8, 2025 at 7:14 PM
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    Holy snikeys, what a deal. Similiar situation I had last year but I ended up paying full retail. No regrets though.
    happyabortion and Norton like this.
  10. Apr 8, 2025 at 7:16 PM
    herecomesace
    x2
    happyabortion likes this.
  11. Apr 9, 2025 at 11:18 AM
    EricT
    Arizona
    AFE air filter and box about to go in here, damn that filter is huge. So much more material than the stock config, and I dont think theres that secondary carbon whatever thing.
    If not obvious, you all have me strongly considering pulley sizes now. As in, maybe 2.7 or so.
    Beyond trimming the snout, any other considerations? My goal is a reliable and smooth 6.5 pounds available boost. And I am just about at 6k feet elevation.
    I do however occasionally travel down to 3k elevation, and sometimes sea level outright. If I do, are there any serious considerations I should have for that change? Also, on a pulley change would that also be time to consider a re-tune?
    I'm still rolling with the bully dog included on the magnuson kit. I know it runs lean, but also I am up high. Should I be concerned about getting a better / proper tune asap?
    Norton likes this.
  12. Apr 9, 2025 at 3:06 PM
    Norton
    You'll probably need a 2.6" pulley for reliable 6.5PSI at 6K ft elevation. (Mine peaks there at WOT with a 2.5" at ~7K ft elevation.) I recommend RIP-modding your pulley(s) and supplemental tension (from something like @Roostfactor's Pulley Wrap Mod) to minimize slip.
    Consult your tuner about travel to lower elevations, as doing so could result in running too lean.
    Yes - get rid of your BD. Custom tune by @JustDSM (Overland Torque Tune, OTT) is the way to go.
    herecomesace, SUMOTNK and JustDSM like this.
  13. Apr 9, 2025 at 3:44 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm down in Phoenix (1200 feet).. but regularly get up in elevation (Prescott, Flag, other peaks to camp, etc) ~6k-8k feet. I'm running a 2.5 pulley on a HP Tune via Justin. I see about 8-9 lbs of boost.. but that doesnt necessarily mean anything. Correct me if I'm wrong here guys, but everyone's boost readings are going to vary.. not just due to pulley size and elevation.. but exhaust setups will play a big factor as well, no? Constrictive vs Non. I used to be at like 12lbs of boost.. then I opened up my exhaust some more.
    But.. if and when you do decide to jump down in pulley size @EricT , and you want to add a pulley wrap.. let me know and I can do a VW roller bearing wrap mod for you. Definitely get on a HP Tune sooner than later.. other than that.. you'll be fine running up down in elevation.
    Billy182, garciav, Norton and 2 others like this.
  14. Apr 9, 2025 at 5:32 PM
    NashMan
    NashMan Well-Known Member
    I put my fuel regulator to boost refrance and my fuel persure dropped to 34 psi vs 44 with it open air. I am on the danger fench right now on being to lean after installing my bigger throttle body on a full throttle run is see 11.8 and some times see a 12. my mods so far are fuel pump, = legth headers, =legth y pipe and 3 inch exhuast, pully 385, volant intake older stlye one with ram air, retarted cam gears
    I am looking to buy a fuel perssure regulater and bump my ful pressure but i am un certin how the ecu will react with no flat rate fuel perssure
  15. Apr 9, 2025 at 6:25 PM
    JustDSM
    Justin
    Ogden, UT
    If your ECU isn't properly configured to be boost referenced you will run lean (create positive fuel trims) under vacuum. You'll find the truck will run a bit richer when under positive pressures - which is why it was a popular mod back in the day.
    The ECU is calibrated specifically for a fixed fuel pressure in OE calibrations.
    Norton likes this.
  16. Apr 9, 2025 at 7:26 PM
    NashMan
    it just has the trd tune on it. the idea was to do possibly 3 things a buy adjustable fuel reg then set it to 44 psi and see if the rising rate will fix it but it may go to rich option 2 is to run FMU https://vortechsuperchargers.com/pr...yU_y3viS6DpzevqN_-iJJqcBTuNcTXoNAgose26QkUg42 or last option that I may do because it is cheap and I Have done to older toyota's and just use the b&M fuel pressure upgrade kit or blox makes one too https://www.swapshopracing.com/contents/en-us/p5729_BM_Racing_CommandFlo_Fuel_Pressure_Regulato.html
  17. Apr 9, 2025 at 7:39 PM
    EricT
    Arizona
    Hey question - for the PCV, a stock one is expecting stock levels of vacuum right? And we dont exactly have that anymore. Do I need a differently rated PCV?
  18. Apr 9, 2025 at 7:47 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That would be news to me.
    EricT[QUOTED] and Norton like this.
  19. Apr 9, 2025 at 7:49 PM
    Norton
    Boost is on-demand, not all the time. Mine still idles down around 15-20in Hg vacuum. No PCV change required.
    EricT[QUOTED] and Sterling_vH111 like this.
  20. Apr 9, 2025 at 9:01 PM
    NashMan
    a pcv vavle are all the same in there job no matter the vaccum on the other hand only thing that degrades is your brake force if you were to run massive over lap cams for high rpm
    EricT[QUOTED] likes this.
