TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 12, 2018 at 8:48 PM
    #5601
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That would be awesome! They do stay a nice gold color for a while but as you know they get darker and darker with age.
  2. Jul 12, 2018 at 8:50 PM
    #5602
    Roostfactor
    TX panhandle
    Wholly @gersus back from the dead! Thanks man and good to hear from you!
    gersus[QUOTED] likes this.
  3. Jul 12, 2018 at 10:57 PM
    #5603
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    It minimized heat soak in the hot summer months. Anybody that’s in tune with these TRD blowers will noticed the power diminish after summer driving in city traffic. As for objective, isn’t it a fact water cools more effectively than coolant? It just corrosive, freezes, and boils ;)
  4. Jul 13, 2018 at 7:10 AM
    #5604
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I dunno, does water in fact cool better than the yota coolant? I was hoping so, but was/am not sure if it does or not.
    Thats where numbers come in and make things measurable, thus objective.
  5. Jul 13, 2018 at 7:14 AM
    #5605
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Water does cool better, but can freeze. That's the main reason antifreeze is the way to go for most systems. If one doesn't mind changing it twice a year it should be worth it. I'll be doing a test on this soon.
  6. Jul 13, 2018 at 7:16 AM
    #5606
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @JuanitoBunito, what brand radiator hoses did you have that didnt work out?
  7. Jul 13, 2018 at 7:20 AM
    #5607
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    All forms of antifreeze coolant used in cars have worse thermal conductivity than straight water. That's the sacrifice you get for raising the boiling point and lowering the freezing point.
    Norton, Skootter14, mr.trd and 4 others like this.
  8. Jul 13, 2018 at 7:24 AM
    #5608
    Jesse
    Poulsbo
    15' DCSB OR S/C
  9. Jul 13, 2018 at 8:20 AM
    #5609
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The solution for many supercharged Corvette ZR1 owners to get maximum cooling effectiveness, while still having coolant protection is running a 70/30 or even 80/20 water/ coolant mix.
    I've wanted to change the mix for a while, but have not done anything to it since I did a service.
  10. Jul 13, 2018 at 8:34 AM
    #5610
    ThomasMore66
    Dallas/Fort Worth & Durango
    What's the best way to test the mixture in the system now?
  11. Jul 13, 2018 at 8:37 AM
    #5611
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Got me.
    If you want to something like 25/75 That is easy to do if you run a gallon of coolant in your engine system.
  12. Jul 13, 2018 at 9:09 AM
    #5612
    Voodoo Rufus
    Bakersfield, CA
  13. Jul 13, 2018 at 9:10 AM
    #5613
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    HPS silicone hoses. I got them off eBay. They were very nice quality just didn’t workout because I have a blower on my motor....
  14. Jul 13, 2018 at 9:10 AM
    #5614
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Crappy parts is is that the Toyota (pink) Super Long Life is pre-mixed. And the (red) Long Life is not the same stuff. According to our techs, you can not go from pink to red. It will cause issues. Now can you run straight water a few times to get it all the pink flushed out and then go to red which is concentrate to get the mix you want. They can not tell my if that will or won't work. But they do believe the real issue between the two is the mixing of them, so a flush may be the ticket.
  15. Jul 13, 2018 at 9:35 AM
    #5615
    ThomasMore66
  16. Jul 13, 2018 at 9:51 AM
    #5616
    Roostfactor
    TX panhandle
    Still shouldn't be hard to dilute the pre mixed stuff further. 1 gallon premixed is 1/2 gallon coolant. Add 1 gallon distilled water to 1 gallon per mixed for a 25% coolant to 75% water ratio.
    Of course you can figure out different mixtures with simple math but what I dont know off hand it what the freezing temp is for the different mix ratios.
    Norton and 12TRDTacoma[OP] like this.
  17. Jul 13, 2018 at 10:01 AM
    #5617
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    damn those are sick :drool:
  18. Jul 13, 2018 at 10:04 AM
    #5618
    Voodoo Rufus
    Bakersfield, CA
    12TRDTacoma[OP] and Roostfactor like this.
  19. Jul 13, 2018 at 10:14 AM
    #5619
    Jesse
    Poulsbo
    15' DCSB OR S/C
    An experiment in a freezer might work.
    12TRDTacoma[OP] likes this.
  20. Jul 13, 2018 at 10:35 AM
    #5620
    Roostfactor
    TX panhandle
    Yeah down to about 5°. I'm sure a quick google would deliver.
