TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 13, 2018 at 11:26 AM
    #5621
    ThomasMore66
    Dallas/Fort Worth & Durango
  2. Jul 13, 2018 at 11:34 AM
    #5622
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    There is just little over a quart of coolant in our TRD SC systems unless you got a bigger reservoir.
  3. Jul 13, 2018 at 11:37 AM
    #5623
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    HUH? you are saying that inside the intercooler, lines, reservoir, and radiator, that all adds up to 1 quart? Must be a typo... but I don't know for a fact how much it holds
  4. Jul 13, 2018 at 12:47 PM
    #5624
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    im pretty sure i put a full gallon of coolant in when i installed my supercharger
    Skootter14 likes this.
  5. Jul 13, 2018 at 1:03 PM
    #5625
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I ran less than a gallon for sure, but yeah, the blower holds a sort of decent amount of coolant. If you do a simple drain and refill though it is one and 1/8 or one and 1/4 quart.
    Skootter14 and TRON like this.
  6. Jul 13, 2018 at 1:30 PM
    #5626
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    How critical would post-intercooler nozzle placement for standard water injection be? Drilling and tapping into the manifold bolt cover would be easy enough.
  7. Jul 13, 2018 at 1:35 PM
    #5627
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It's only important in turbo applications. Dont want to fill up the intercooler with liquid. We can place them from behind the intake sensor anywhere we like.
  8. Jul 13, 2018 at 1:46 PM
    #5628
    Voodoo Rufus
    Bakersfield, CA
    In those applications it's easy. You tap into something post-intercooler, and on an air-air setup that's simple. With our AWIC it's a little more challenging. Especially since some here were concerned about the spray pattern being uniform going into the cylinders.
  9. Jul 13, 2018 at 1:47 PM
    #5629
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Mine is before the throttle body for that reason.
  10. Jul 13, 2018 at 1:49 PM
    #5630
    Voodoo Rufus
    Bakersfield, CA
    I don't understand why people gravitate towards pre-compressor installs, aside from ease of use. I know some people say the mist helps the rotors seal better.
    Problem I would see is that you're heating up the injectant with the compressor, lessening it's intercooling effects. Cool injectant hitting the compressed charge would cool it far more. Sometimes even sub-ambient!
    ThomasMore66 and 12TRDTacoma[OP] like this.
  11. Jul 13, 2018 at 2:04 PM
    #5631
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ease of install, yes. Cools the rotors, yes. I agree with you on spraying post charge. Maybe I'll do that too.
  12. Jul 13, 2018 at 2:05 PM
    #5632
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Find me somewhere to inject post charge where it’s going to mix well and I will be the test mule.
  13. Jul 13, 2018 at 2:06 PM
    #5633
    Jesse
    Poulsbo
    15' DCSB OR S/C
    We have similar tunes. Maybe a great comparison @Murphinator !
    Murphinator and Roostfactor like this.
  14. Jul 13, 2018 at 2:08 PM
    #5634
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yes indeed.
    I was going to do it by tapping the charge air cooler lid, but I didnt think it would mix good. Then again I have not taken mine off, I’ve only seen it from pics other people have posted. So I could be missing the whole picture, maybe it would work.
  15. Jul 13, 2018 at 2:11 PM
    #5635
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I just emailed snow performance to see what they think. Wait and see.
  16. Jul 13, 2018 at 2:14 PM
    #5636
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    One main factor is if you install post tb you must have a solenoid to turn the system on and off or you will constantly suck water into the motor when in vacuum.
  17. Jul 13, 2018 at 2:15 PM
    #5637
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True.
    Roostfactor[QUOTED] likes this.
  18. Jul 13, 2018 at 2:17 PM
    #5638
    Roostfactor
    TX panhandle
    The rag is in there because I was smoothing the inlets.
    5thGearPinned and Murphinator like this.
  19. Jul 13, 2018 at 2:19 PM
    #5639
    Roostfactor
    TX panhandle
    To get a nice even most probably on small nozzle over each pair of inlets so 3 total.
  20. Jul 13, 2018 at 2:20 PM
    #5640
    Voodoo Rufus
    Bakersfield, CA
