TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 18, 2018 at 5:17 PM
    #5721
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    No same one as yours avh4200
    I dont have radio on mine. I just play from my phone. I think @loginfailed has radio capability but I dont knw what he did.
    loginfailed[QUOTED] likes this.
  2. Jul 18, 2018 at 6:42 PM
    #5722
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  3. Jul 18, 2018 at 6:56 PM
    #5723
    GT7
    Grant
    Phoenix
    2013 DCLB
    Just loaded up the ovtune. Went for a drive and a few full throttle runs.
    Mods: 2.7 pulley
    Afe intake
    Full urd spec u
    Urd cam gears
    When I first installed the ucon I wasnt that impressed. Then I got a stock ecu and it was very noticeable
    The ovtune is the same, didnt notice much difference from the trd tune Ive been on. This is my 2 mile review. More to come in the next few days
  4. Jul 18, 2018 at 7:59 PM
    #5724
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, you can listen to whatever source you choose while the gauges are displayed.
    Oh maybe my screen is just dirty :anonymous:
  5. Jul 18, 2018 at 8:10 PM
    #5725
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have their harness for my 2006 Tacoma to Haltech Elite 2500.
    @Hacktacular , at one point purchased a plug n play Unichip, for his '09+ Tacoma. Sent that in to them to Boomslang, to have them make a plug n play jumper harness, for his Elite 2500.
  6. Jul 18, 2018 at 8:17 PM
    #5726
    ThomasMore66
    Dallas/Fort Worth & Durango
    So does OBD2 still work? You have to pass emissions in Houston, right?
  7. Jul 18, 2018 at 8:25 PM
    #5727
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    How about radio, air bags, windows, etc...?
  8. Jul 18, 2018 at 8:26 PM
    #5728
    ThomasMore66
    Oh my. Hadn’t thought about that.
  9. Jul 19, 2018 at 5:23 AM
    #5729
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    OBD still works, but slightly different. Haltech basically controls it. However, an inspection center can still see the cam sensor code, and injectors code. Despite there not being a light. Luckily they are not worried about those codes here.
    The way around that, would be an AEM, which connects into the CAN system. Or the self tuning version of the OVTune.
    All of the normally controlled functions are untouched. Factory ECU is still there.
  10. Jul 19, 2018 at 5:34 AM
    #5730
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Thanks for tagging me Torspd!
    Boomslang is a reputable company and communicates well. Every install is a bit different. In my case everything works as normal except for the OEM traction control or VSC and the temp gauge. The reason for that is because I took over the DBW (drive by wire) with my Haltech.
    I also took over the CEL (check engine light) from the OEM. The VSC lamp is lit because of this. The only other thing that doesn't work correctly is the dashboards temp gauge, again because I have taken that over to allow the Haltech to see it.
    I need to get another sensor installed so that the OEM can have a sensor of its own. I usually run an OBD app on my phone to monitor the temps and other data coming out of the Haltech. I could also easily correct the traction control issue and use the Haltech for that but I kind of like having the ability to :burnrubber: if my heart desires. Let us know if you have any other specific questions.
  11. Jul 19, 2018 at 5:57 AM
    #5731
    Hacktacular
    Robert
    Nice, thanks for sharing. What was the red SUV that left like that?
  12. Jul 19, 2018 at 6:42 AM
    #5732
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    brand new range rover
    Hacktacular[QUOTED] likes this.
  13. Jul 19, 2018 at 6:43 AM
    #5733
    Hacktacular
    Robert
    Oh yea, supercharged and big HP stock. its no wonder he left like that....nice runs on your part!
  14. Jul 19, 2018 at 6:53 AM
    #5734
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    thanks. i thought they sucked. i was hoping mid 13's. it was 81 degrees and i drove an hour there. super charger was really hot. i need to get some wider tires for the rear and practice trying to launch it. i was spinning a lot on some runs too. next mod is going to be meth and killer chiller. need to cool that pig down
  15. Jul 19, 2018 at 7:05 AM
    #5735
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I think for the money you will benefit more from the meth. No parasitic drag from the ac compressor. I tried 3 times to get an email response from killer chiller with questions as I was going to buy one. NOTHING. I email snow performance and they return my emails very quick. My experience.
    Roostfactor and Hacktacular like this.
  16. Jul 19, 2018 at 7:22 AM
    #5736
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    mr.trd likes this.
  17. Jul 19, 2018 at 7:25 AM
    #5737
    Jesse
    Poulsbo
    15' DCSB OR S/C
  18. Jul 19, 2018 at 7:42 AM
    #5738
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Is there anywhere we can buy a complete set of pulleys? Like crank, alt,...... I haven't found any. On that note just talked to pulley boys about it. They may be making some.
    12TRDTacoma[OP] and Roostfactor like this.
  19. Jul 19, 2018 at 7:43 AM
    #5739
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    can the haltech not share the input with the gauge cluster?
  20. Jul 19, 2018 at 8:03 AM
    #5740
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It cannot connect to the CAN system as an independent standalone. Other vehicles where it replaces the OEM ecu, it does.
