TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 19, 2018 at 8:18 AM
    #5741
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Stop peddling your meth to everyone! :rofl:
    Sorry, couldn't resist.
  2. Jul 19, 2018 at 8:40 AM
    #5742
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Call me Heizenburg prodigy:devil:
    Roostfactor likes this.
  3. Jul 19, 2018 at 9:10 AM
    #5743
    ThomasMore66
    Dallas/Fort Worth & Durango
    Man, I need to go to school on this. Why don't we all go this route and abandon the UCON or OV? Seems like we could find a tuner in a lot more places if we expanded our universe.
  4. Jul 19, 2018 at 9:30 AM
    #5744
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'll learn with ya!
    12TRDTacoma[OP] and Hacktacular like this.
  5. Jul 19, 2018 at 9:45 AM
    #5745
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Currently, there are only three of us on here with a Haltech. All in the turbo BS thread. Standalones are inherently complicated. As you generally have to wire everything up, or purchase a pre-fabricated jumper harness. Then you have to configure all of the sensors and settings.
    Then you have to tune it.
    Having unlimited access, control, and flexibility, is trade-off with cost, complexity, and high potential to damage one's goods if too aggressive or unskilled.
    If someone has a great base tune file though, it saves A LOT of headache. Should they be willing to share that file.
  6. Jul 19, 2018 at 10:03 AM
    #5746
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    If you are referring to the temp gauge issue, yes. It can be removed from the harness and use its own sensor. But as Torspd mentioned, it is not a replacement. It is a parallel install.
  7. Jul 19, 2018 at 10:22 AM
    #5747
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    12TRDTacoma[OP] likes this.
  8. Jul 19, 2018 at 10:24 AM
    #5748
    Jesse
    Poulsbo
    15' DCSB OR S/C
  9. Jul 19, 2018 at 10:35 AM
    #5749
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @White lightning boosted
    I hesitate to plug (NST) NonStop Tuning. They make/made a complete pulley kit. My experience with them wasn't pleasant....nonexistent communication, delayed delivery (took 5 months), etc... but in the end, i did get all my pullies and the product was decent.
    Buyer beware. Proceed at your own risk with NST
  10. Jul 19, 2018 at 10:38 AM
    #5750
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I remember reading a previous comment about that. Made me wonder why more people aren't running their product. Thought I'd hint that to pulley boys. Cant hurt to have more options.
  11. Jul 19, 2018 at 11:20 AM
    #5751
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    should see if pulley boys will make a bigger crank pulley for the supercharger
  12. Jul 19, 2018 at 11:26 AM
    #5752
    ThomasMore66
    No slip issues.
    inwood customs and Roostfactor like this.
  13. Jul 19, 2018 at 11:32 AM
    #5753
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Purchased the set few months ago. No issues. They promptly replied to all my email.
  14. Jul 19, 2018 at 11:43 AM
    #5754
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Looks great!! :thumbsup: :hattip:
    Any AV clips of these?
    I'm looking at a y-pipe for my first SC mod.
  15. Jul 19, 2018 at 11:44 AM
    #5755
    SUMOTNK
    Eddie
    Glad to hear. Hopefully this is a new/fresh chapter for their business.
  16. Jul 19, 2018 at 11:49 AM
    #5756
    SUMOTNK
    Eddie
    I have stock pulleys that I'm willing to lend to them (PulleyBoyz) for any development work that may be needed for our trucks.
  17. Jul 19, 2018 at 11:51 AM
    #5757
    Hacktacular
    Robert
    If you do, I'll help any way I can. I got tired of the BS and took it upon myself to make shit happen. I need to have tuning freedom. The others don't offer that IMO.
  18. Jul 19, 2018 at 12:00 PM
    #5758
    Roostfactor
    TX panhandle
    Thanks! Not specifically for the exhaust. I posted a clip a couple weeks ago in this thread showing intercooler temps. You mostly only hear supercharger. PM me if you want more info.
  19. Jul 19, 2018 at 12:14 PM
    #5759
    rmepilot
    Rob
    Huntsville, AL
    Will do!
  20. Jul 19, 2018 at 4:52 PM
    #5760
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Now with some more time with ov tune, its good. Definitely a decent increase in umph. I like it alot so far.
