TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 19, 2018 at 5:05 PM
    #5761
    ThomasMore66
    Dallas/Fort Worth & Durango
    Weak! Why is it good? What are your AFR’s? Smokey burnouts?
    inwood customs likes this.
  2. Jul 19, 2018 at 5:10 PM
    #5762
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    My afr gauge still is busted or something. I replaced sensor twice. Still no good.
    No burnouts either. So far the power seems to come on smoother. Feels less lazy when you go from cruising speed/rpm to full throttle
    jojotoo likes this.
  3. Jul 19, 2018 at 5:47 PM
    #5763
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Installed the URD 255lph fuel pump last weekend with the help of another member, and went with the Deatschwerks pump over the Walbro as I read they are quieter. The truck no longer seems to hold fuel pressure when off. If I start the truck by turning the key to accessory and pause for a second or 2 to allow the fuel system to prime, the truck starts normally. If I immediately crank it from off to start the truck turns over many times before starting, enough to turn heads in the parking lot and have my kid as if the truck is broken. I'm very confident everything is installed correctly. We switched out the rubber fuel line from the pump for a non-collapsible flexible plastic fuel line recommended in another thread and it fit perfect.
    So is this normal? Did the OEM pump have a check valve that the aftermarket pump is missing?
  4. Jul 20, 2018 at 12:15 AM
    #5764
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Bosch or AEM AFR sensor?
    It sounds like the internal check valve is defective. You can always install an external if you so desire. That is probably what I would do unless you want to replace the fuel pump again.
    crashnburn80[QUOTED] likes this.
  5. Jul 20, 2018 at 7:37 AM
    #5765
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I agree it seems defective, I was just curious if anyone with the same Deatschwerks pump had a differing experience.
    Replacing the pump is a PITA as I’m sure most are aware.
  6. Jul 20, 2018 at 7:58 AM
    #5766
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I put the Deats pump on a couple months ago and every now and then I get an intermittent long start where it takes 3-4 seconds or so even if the truck has not been sitting.
    crashnburn80 likes this.
  7. Jul 20, 2018 at 10:49 AM
    #5767
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Unless there was a change in the later models, to prime the system, in Accessory mode, it only primes when the key is turned to start the engine.
  8. Jul 20, 2018 at 11:01 AM
    #5768
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    You won't regret that! Will it eliminate the CATs at all? Can you eliminate CATs on a 2015?
  9. Jul 20, 2018 at 11:05 AM
    #5769
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    The y-pipe eliminates the 2 "aft" CATs, so it "should" have no bearing on the O2 sensor readings.
  10. Jul 20, 2018 at 11:13 AM
    #5770
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Do you have an exhaust manifold on the 2015? Or do the front CATs bolt onto the engine?
    And the y-pipe will not effect the O2 sensors in the slightest. They only monitor the front CATs, you good to go. :)
  11. Jul 20, 2018 at 11:48 AM
    #5771
    rmepilot
    Rob
    Huntsville, AL
    Exhaust manifold, with welded CATs, iirc.
    I'm looking for better sound with my TRD CAT-back, but don't want any droning or rasp.
  12. Jul 20, 2018 at 11:54 AM
    #5772
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    So I had front CATs, URD y-pipe, and a TRD CAT back and had zero drone. It sounded awesome. It's only when you eliminate all four CATs and install long tube headers that you will start to battle rasp and drone. I had to install a resonator once I did the long tube headers cause the rasp was pretty bad. You will be just fine, no rasp!
    rmepilot[QUOTED] likes this.
  13. Jul 20, 2018 at 11:57 AM
    #5773
    rmepilot
    Rob
    Huntsville, AL
    That's the info I was looking for. :hattip:
    Any chance you have any AV clips of that setup?
  14. Jul 20, 2018 at 12:01 PM
    #5774
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Glad I could help. I remember searching long and hard about that very issue when I was debating the y-pipe rasp drone demon. It's a nice feeling to find someone that did it and they say, yeah I had no issues with that.
    I don't have any clips with that set up unfortunately. Sorry...
  15. Jul 20, 2018 at 12:03 PM
    #5775
    rmepilot
    Rob
    Huntsville, AL
    No worries.
    I've been looking myself, for about 2 years now.
  16. Jul 20, 2018 at 12:23 PM
    #5776
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Hmm. Maybe it has just been coincidence that it has started quicker then, it has only been in the truck for 5 days. Looks like I’ll install in an inline check valve. Does anyone know the size of the fuel line to get the right size valve fitting? 3/8”?
  17. Jul 20, 2018 at 2:49 PM
    #5777
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I was looking at using one of these high flow inline check valves from Performance Fuel, which I found the identical valve for less here. My thought was to install it close to the tank on the rubber line from the URD kit before the fuel filter.
  18. Jul 20, 2018 at 3:11 PM
    #5778
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    youd have to buy 10 it looks like through that site though
  19. Jul 20, 2018 at 3:16 PM
    #5779
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can buy individually, they just offer discounts for bulk.
  20. Jul 20, 2018 at 3:35 PM
    #5780
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I just went to the site, and the single valve was $13.xx and shipping to me in AZ was another $12.xx. I think you should order 10 of them, get the discount, and then offer the others up to members for $15 (or near that) shipped. They would fit in a regular envelope (with some extra scotch tape) and ship for about a buck. I'd buy one from you. Don't have the time to do a big purchase and send out the extras myself.
