TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 2, 2018 at 11:33 AM
    #6001
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Highway sometimes while downshifting
    BassAckwards likes this.
  2. Aug 2, 2018 at 11:36 AM
    #6002
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I have factory clutch in mine. Well I think. Bought it used. Hasn’t slipped at all. Got my urd stage 3 clutch, aluminum flywheel, and all new throwout bearing and tsb parts ready to go when I get some time.
  3. Aug 2, 2018 at 11:44 AM
    #6003
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    That’s the one I’ll probably go with myself. That or the stage 2
  4. Aug 2, 2018 at 11:59 AM
    #6004
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  5. Aug 2, 2018 at 12:02 PM
    #6005
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    2.825
    BassAckwards[QUOTED] likes this.
  6. Aug 2, 2018 at 3:47 PM
    #6006
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Thanks for the info guys. I know the whole once your in there concept. That's why if a clutch was required, then I was going with the URD sleeve and TOB. I definitely don't romp on it too much, and mostly want the power for the mountain passes. I just didn't want to install the SC, then find out a week later the clutch was toast. I don't have a garage, or the tools for a clutch replacement, or the blower install. So if I can postpone the clutch for a year that will save me some money in labor for upfront installations. I like the TRD short shift, but that $350-450 is hard to swallow when URDs is only $150.
  7. Aug 2, 2018 at 4:34 PM
    #6007
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    So besides for the TRD eBay belt listed below. Is there any other factory length belts y'all recommend?
    Before Toyota puts my truck back together I'm thinking a new belt will do it good.
  8. Aug 2, 2018 at 4:47 PM
    #6008
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    You definitly shouldn’t have a problem having your stock clutch give you any problems for a while if you take care of it. But definitely do the TOB when you replace it because those are a weak spot in our clutches. The TRD short shifters you can also find deals on if you shop around. I’ll keep an eye out and shoot one to you when I come across one. :thumbsup:
  9. Aug 2, 2018 at 4:48 PM
    #6009
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Sc or accessory?
  10. Aug 2, 2018 at 5:26 PM
    #6010
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    What is the belt length recommended with the 2.8 URD stealth pulley. I know I cut up a gates racing belt to make the current belt, but I don't remember if it was a 70.5 or 69.5 to do so. I am going to try the dayco w-rib belt and see if that is part of the reason for low boost, maybe it isn't all elevation. Also found out I put in the NGK BKR7EIX plugs which are the cross to the IKH-22 not 24. Thinking about also swapping those while I install the Ucon EMS. Is that highly advisable? Plugs have maybe 10K on them. Will I gain anything from the colder plugs with only the 2.825 pulley and my other mods? Not planning on going any smaller on the pulley. In fact if the Ucon EMS doesn't get the truck to run right, truck is for sale. This is my last attempt to get it to run like it should. So I am super anxious about this, cause I love my truck and do not want to get a Tundra to replace it.
  11. Aug 2, 2018 at 5:33 PM
    #6011
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I would figure out the running problem before installing the ucon.
    What are you running for boost?
    12TRDTacoma[OP] likes this.
  12. Aug 2, 2018 at 5:38 PM
    #6012
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    The Ucon will hopefully fix the running problem. I run INSANELY rich. And my boost is in the low to mid 3's. Pretty sure I have some belt slip, but maybe it is all elevation.
    jojotoo likes this.
  13. Aug 2, 2018 at 5:40 PM
    #6013
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    U on bully dog tune? Or trd. Put a quick change pulley set up on it and see how it goes.
  14. Aug 2, 2018 at 5:51 PM
    #6014
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
  15. Aug 2, 2018 at 5:54 PM
    #6015
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    UCON doesn’t play well with anything other than an untainted ECU. Just FYI
    12TRDTacoma[OP] and jojotoo like this.
  16. Aug 2, 2018 at 5:57 PM
    #6016
    Roostfactor
    TX panhandle
    UCON will fix the insanely rich but make sure you have a stock ecu to replace whatever you are currently using.
    What is your elevation again? That seems awfully low boost. Either belt slip or bypass valve adjustment.
    Stock belt is 70.5". You may be able to squeeze a 69.5" if you grind off some of the tensioner stop.
  17. Aug 2, 2018 at 6:04 PM
    #6017
    ThomasMore66
    Dallas/Fort Worth & Durango
    And a smaller pulley
  18. Aug 2, 2018 at 6:07 PM
    #6018
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    o_O
  19. Aug 2, 2018 at 7:55 PM
    #6019
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Gadget said he calibrated it for the TRD flash. And he did talk about how he knows the ucon doesn't work well with the bullydog tuned ones. But nothing about the TRD flashed ecu's. If I were to get a new ecu I would have to have it calibrated again wouldn't I. Honestly I don't like hearing this. Lol. This is just the type of thing that makes me feel like there will never be an end to just trying to get it to run. I understand mods, but damn, it is neverending just to get it to be reliable again. Lol
    Elevation is 4400. With the 2.8 pulley is the standard 70.5" belt typically used? I really wish I could remember what belt I modified.
  20. Aug 2, 2018 at 7:59 PM
    #6020
    StOrMyThEtAcO
    Cody
    CO
    All of them
    SC belt.
