TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 9, 2018 at 11:36 AM
    #6101
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Sounds like an idiot convention to me. In a closed system I can out a centrifugal pump in any orientation that I desire. Position only matters as far as height vs the LTR inket is concerned to avoid trapping air in it.
    Then again I am not a enginerd and have not schooling in such things.
    Roostfactor likes this.
  2. Aug 9, 2018 at 11:37 AM
    #6102
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Off topic, but since centrifugal force is now known as centripedal, do we now call the pumps centripedal also? :confused:
  3. Aug 9, 2018 at 12:33 PM
    #6103
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    No, only practical experience which usually destroys the schooling!
  4. Aug 9, 2018 at 12:43 PM
    #6104
    Roostfactor
    TX panhandle
    I hope that was not directed at Skooter14 though. He seems like a cool dude just trying to ensure he does his mods correctly.
  5. Aug 9, 2018 at 2:08 PM
    #6105
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That explains why the fuel trims tend to bounce around higher than 0 at idle. I forgot that we go open loop when we WOT our trucks with these tunes. It's too bad these ECM's are more difficult to deal with than GM computers. That is about the only thing good old GM has going for them in that arena. Lol.
  6. Aug 9, 2018 at 3:33 PM
    #6106
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    ucon option
  7. Aug 9, 2018 at 4:13 PM
    #6107
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    the ucon runs the truck in closed loop all the time, right?
  8. Aug 9, 2018 at 4:21 PM
    #6108
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Effectively yes.
    Roostfactor and inwood customs like this.
  9. Aug 9, 2018 at 4:22 PM
    #6109
    Skootter14
    Jeremy
    haha thanks for looking out @Roostfactor , I appreciate it.
    I didnt take this as a jab at me, if it was, o well. It's the internet and I am way more secure in myself and the way I do things than to let anyone make me feel negative (again, not saying stairgod was trying too in any way!). I fly attack helicopters for a living and have had my fair share of "life experiences"...99/100 times I have a reason for the way I do things, and if someone wants to bash me for a particular thing...so be it :cool:. You sticking up for me/anyone though is just another reason why I like this "little" circle of peers in this particular thread. I think we consistently help support/troubleshoot with one another so no one is left behind. :cheers:
    On another subject, I got the worm clamps and a few more angle fittings for the reroute of hoses. Just one more mount to make for the pump and I'll be set!
  10. Aug 9, 2018 at 4:36 PM
    #6110
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    No that was not directed at him. It was for the idiots at Magnusson.
  11. Aug 9, 2018 at 4:39 PM
    #6111
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Make sure to post pics when you are done. I am going to have to move my pump eventually too. Moving the winch into it's space, so it has to go.
    Funny enough that when @fatfurious2 had his SC installed the pump was moved and he had cavitation issues
    Roostfactor and fatfurious2 like this.
  12. Aug 9, 2018 at 4:43 PM
    #6112
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have it resolved now. Or so I think. Let me know if pictures are needed of my setup. I haven't messed with anything since.
  13. Aug 9, 2018 at 5:23 PM
    #6113
    Skootter14
    Jeremy
    I def will get pics. I’m moving the pump for the same reason.
    Feel free to throw em up! I’m looking to slide my pump off to the passenger side and orient it vertical
    fatfurious2[QUOTED] likes this.
  14. Aug 9, 2018 at 5:55 PM
    #6114
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Why would you have lower fuel pressure than stock in vacuum? Doesn't the fpr connect to a vacuum port if not connected to the boost port?
  15. Aug 9, 2018 at 6:00 PM
    #6115
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Fpr is normally connected to fresh air port on ur intake. When doing fpr mod u hook it to boost port. So when not boosting its under vacuum causing more restriction on fpr and less fuel
    Pressure.
    Norton and Roostfactor like this.
  16. Aug 9, 2018 at 8:24 PM
    #6116
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Why is everyone so worried about vacuum and the fpr mod. I mean the only time you are at vacuum is idle and cruising at constant speed. I could be wrong, but 15.2/ 15.3 should be fine for AFRs at idle or constant speed since there is minuscule load on the engine. I’ve been wrong before though
  17. Aug 9, 2018 at 8:44 PM
    #6117
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Ehhh it's a smidge lean, but probably ok on engines with less than 200k
  18. Aug 9, 2018 at 9:09 PM
    #6118
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Evening gents,
    I just finished up swapping my coil packs from side to side (the front driver side to passenger, and so on). Prior to doing this, the truck was throwing a P0356 code, now its throwing a P0353 code. Could this be indicative of a bad coil pack? And if so, could this be causing studdering and hesitation while driving?
    Installed my fuel pressure gauge a few days ago, and it holds 41-43 psi during the hesitation and studdering, so i dont think i have a fuel pressure issue.. really hoping my coil pack is the problem, and that i can replace it and finally have the truck run properly.. thoughts?
  19. Aug 9, 2018 at 9:11 PM
    #6119
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I don’t know much but the coil pack makes sense to me....
  20. Aug 9, 2018 at 9:12 PM
    #6120
    BassAckwards
    Makes sense to me too.. especially since its going from one side to the other..
