TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 24, 2018 at 8:07 AM
    #6281
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's a circumstantial mod really.
    JacksonTacoma likes this.
  2. Aug 24, 2018 at 8:09 AM
    #6282
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I boost referenced after installing the 2.7 and becoming too lean. 2.8 was fine with no FPR. My 2.5 is a tad rich with FPR. All on OVTune.
    12TRDTacoma[OP] likes this.
  3. Aug 24, 2018 at 8:18 AM
    #6283
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm on ovtune 93 with a 2.8 soon to go 2.6 wanted to be safe-ish.
  4. Aug 24, 2018 at 8:27 AM
    #6284
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  5. Aug 24, 2018 at 8:32 AM
    #6285
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I would do the FPR when you install the 2.6 and see what the numbers are. With 2.7, the stock fuel pressure on stock TRD injectors was not enough fuel for me on OVTune.
  6. Aug 24, 2018 at 8:33 AM
    #6286
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Love it. Once I have my 2.6 on I'll do some data logging for a custom tune. Want to take advantage of the methanol abilities!
  7. Aug 24, 2018 at 8:34 AM
    #6287
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for the tip. How does one do the fpr mod:anonymous:
  8. Aug 24, 2018 at 8:38 AM
    #6288
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    vacuum line on the fpr attach it to a boost source.
  9. Aug 24, 2018 at 8:46 AM
    #6289
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    you gotta think about it this way too. u have boost in ur intake plenum and the injectors have to spray and the boost is pushing back the injector. the fpr mod just matchs the boost levels with the fuel pressure so the injectors are spraying like in a n/a motor
  10. Aug 24, 2018 at 8:50 AM
    #6290
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    FPR is the second easiest performance mod you can do after the TRD shift knob
  11. Aug 24, 2018 at 8:51 AM
    #6291
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Looks like I'm not the only one with nasty looking plugs. These all look far worse than those coming off my STI. And it runs the same plugs.
  12. Aug 24, 2018 at 8:54 AM
    #6292
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You have a 6 speed pro? Did you special order that beast?
  13. Aug 24, 2018 at 8:54 AM
    #6293
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Which of all the TRD shift knobs? :D
  14. Aug 24, 2018 at 8:54 AM
    #6294
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for the explaining:thumbsup:
  15. Aug 24, 2018 at 8:55 AM
    #6295
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Page one talks about the FPR mod if you need a further explanation on it.
  16. Aug 24, 2018 at 8:56 AM
    #6296
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    No automatics have one too
    No I'm auto trans but still got the high performance knob :)
  17. Aug 24, 2018 at 8:57 AM
    #6297
    BassAckwards
    Gotcha! Everyone knows a TRD stamped shifter is good for a few extra ponies :D
    RyanL, Biscuits, rmepilot and 2 others like this.
  18. Aug 24, 2018 at 9:01 AM
    #6298
    12TRDTacoma
    Rob
    Concordia
    Boosted
    At least 5 guaranteed but most have reported 10 extra horses from it.
  19. Aug 24, 2018 at 9:02 AM
    #6299
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    That's why I forked over an extra $5K for a TRD Pro
  20. Aug 24, 2018 at 10:16 AM
    #6300
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The FPR mod is only increasing fuel at a 1:1 ratio. How can you be so rich at part throttle?
