TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 7, 2018 at 8:59 AM
    #6401
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yeah, I’m certainly no expert. I’m just regurgitating what Gadget told me when I called to order the 2.55” and supporting mods.
    He did say I COULD get away with just running the 7th. He highly recommended running the 61s for fuel delivery and the 7th for cooling purposes however.
    I’ve had meth inj. on other rigs. Problem is, I can’t get meth without driving 20 miles one way. I’m sure it’s more effective, but I like just filling my fuel tank and not having to worry about sourcing meth, or keeping a reservoir filled.
  2. Sep 7, 2018 at 9:08 AM
    #6402
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Good to know, wasn't aware of this..
    Yep, UCon here. I will probably go with the 61lb injectors instead of the 7th, just because I plan on running meth injection later on down the road.
    How do you go about getting a duty cycle reading on the injectors? is that somewhere in the data that the UCon can log?
    loginfailed likes this.
  3. Sep 7, 2018 at 9:39 AM
    #6403
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I mail order mine from jegs. Comes right to my door.
  4. Sep 7, 2018 at 9:47 AM
    #6404
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Nice. I wasn’t aware of that option. It was 2009 last time I messed with Meth anyway. For all I know, I could get it down the street now.
    Roostfactor likes this.
  5. Sep 7, 2018 at 9:58 AM
    #6405
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Windshield washer fluid is the equal or good alternative is it not? The blue fluid you can buy at a parts store I've heard works great.
  6. Sep 7, 2018 at 10:04 AM
    #6406
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I do believe the duty cycle can be found under one of the folders in the UCON tuning program
  7. Sep 7, 2018 at 10:05 AM
    #6407
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Consistency isn't always guaranteed.
  8. Sep 7, 2018 at 10:19 AM
    #6408
    BassAckwards
    :thumbsup:
  9. Sep 7, 2018 at 10:31 AM
    #6409
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I’ve heard that too. I just ran straight meth. Consistency is never a problem that way :D
    It can. You can even see the duty cycle of the 7th if you have it.
  10. Sep 7, 2018 at 10:32 AM
    #6410
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You have to have had a session with Scott (the UCON guru). You would only get a session with him if you have issues and he needs to troubleshoot. He remotely connects to the UCON via your laptop and load UTune Lite on your computer. Once it is loader on your computer you can at anytime plug it into the UCON and perform datalogs.
    @rjbiii if we have time after I install your stuff I will plug in my laptop to your UCON, run a datalog, and show/explain to you all the data.
    This is true but you have to get the program from Scott as far as I know.
  11. Sep 7, 2018 at 10:35 AM
    #6411
    BassAckwards
    That makes sense! Yeah ive had probably 10 sessions with him trying to get everything sorted out. Finally seems like the truck is running better though. Definitely interested in having you explain the data to me!
  12. Sep 7, 2018 at 10:54 AM
    #6412
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Windshield washer blue -20* with no additives is 30% meth. Add 3 12oz bottles of heet gas dryer to it and its 50/50. Both options and boost juice are good to go according to snow performance and my use.
  13. Sep 7, 2018 at 10:54 AM
    #6413
    Roostfactor
    TX panhandle
    The only problem is in the hotter climates like where I live they dont have the blue -20° stuff in stock all year. Only in the winter.
    I'm not really concerned with the consistency as I would add a few bottles of HEET to a gallon and the UCON should handle the afrs.
  14. Sep 7, 2018 at 10:55 AM
    #6414
    Roostfactor
    TX panhandle
    Beat me to it!
  15. Sep 7, 2018 at 11:17 AM
    #6415
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am definitely no expert on meth subject matter, just going off of what I remember reading about semi consistently. It's good you guys are at least aware of the inconsistencies it can have.
  16. Sep 7, 2018 at 11:25 AM
    #6416
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Look in the Inj1 tab of your logs. Down toward the bottom, I believe it’s listed as dctlx or something.
  17. Sep 7, 2018 at 11:26 AM
    #6417
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  18. Sep 7, 2018 at 11:48 AM
    #6418
    BassAckwards
    Thanks man! Great info
  19. Sep 9, 2018 at 4:55 PM
    #6419
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Anyone got some urd cam gears for sale? Anyone find someone to make some?
  20. Sep 9, 2018 at 4:59 PM
    #6420
    Roostfactor
    TX panhandle
    @JustDSM ?
