TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 9, 2018 at 8:36 PM
    #6421
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I’m also looking for some.
    I PMed the fella that said he was gauging interest and looking into making some… But he is still looking into it and hasn’t gotten any quotes or CAD drawings or anything to a machine shop yet
  2. Sep 9, 2018 at 8:47 PM
    #6422
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    What are you guys looking to accomplish with the cam gears? Increased timing?
    Sort of sounds like the only way to truly utilize it to the best extent is to have UCON.
  3. Sep 9, 2018 at 9:43 PM
    #6423
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Don’t want ucon and all the headaches everyone has with it. Truck runs amazing on trd tune. Just want everything I can get for it. Urd says u can’t run ucon with out cam gears. So they have to have a huge effect on the motor
  4. Sep 9, 2018 at 10:37 PM
    #6424
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    They delay the exhaust valve opening and more importantly closing to help evacuate the cylinder more completely.
  5. Sep 9, 2018 at 10:46 PM
    #6425
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The cam gears retard the timing by 3 degrees
  6. Sep 10, 2018 at 12:35 AM
    #6426
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It sounds like the only thing that will allow to run them right will be UCON or OVTune.
  7. Sep 10, 2018 at 1:56 AM
    #6427
    Roostfactor
    TX panhandle
    Pretty sure they run fine with stock ecu but not certain.
    @TRON?
    BassAckwards likes this.
  8. Sep 10, 2018 at 5:47 AM
    #6428
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. Just not optimized.
    The UCON without the cam gears, is where potential engine damage can occur. As an integral component For That Tune has been taken away.
  9. Sep 10, 2018 at 11:47 AM
    #6429
    TRON
    5 years strong
    Speaking of ovtune.. Anybody have a custom SC tuned yet?
  10. Sep 10, 2018 at 12:22 PM
    #6430
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I dont yet but as soon as I have time to figure out tech stream I'll do some logging and get one.
  11. Sep 10, 2018 at 12:23 PM
    #6431
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I don't believe anyone has received a custom tune since Murphinator's which I think was the basis for the handheld tune. I realize the guy is extremely busy, but at this point all we've gotten beyond the first handheld tune is a bunch of carrots on a stick. Supercharger V2 tunes were supposed to be ready at the beginning of August.
    Norton, jojotoo, Roostfactor and 3 others like this.
  12. Sep 10, 2018 at 12:25 PM
    #6432
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. I had questions regarding clearing o2 codes for v2 and have yet to get an answer.
  13. Sep 10, 2018 at 12:30 PM
    #6433
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have the custom tune software and everything ready to go, the only problem is that I don't even know how to use the stuff well enough to run a datalog. All I see are endless windows of values and thus far, the TRD tune has gotten me pretty good results.
  14. Sep 10, 2018 at 12:32 PM
    #6434
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    As in they can be run with the TRD reflash? or do you mean you can go back to stock and not worry about taking them out?
  15. Sep 10, 2018 at 12:33 PM
    #6435
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    TRD flash
    BassAckwards[QUOTED] likes this.
  16. Sep 10, 2018 at 12:34 PM
    #6436
    BassAckwards
    Good to know.. many thanks sir
  17. Sep 10, 2018 at 1:37 PM
    #6437
    TRON
    I don’t understand why the NAs are so difficult. I mean they all should be a standard tuned pretty much minus the octane level.
    I’m curious to see the gains on a well tuned TRD flash that’s been leaned out with mods. Obviously a pigrich TRD tune has more to gain
  18. Sep 10, 2018 at 2:10 PM
    #6438
    Roostfactor
    TX panhandle
    It's my understanding he does more than just a little timing advance.
    Adjust timing
    Adjust intake cam timing
    Adjust fuel
    Maybe adjust throttle by wire?
    This is for all parameters
    He also adjust shifting!
    I dont know if he can adjust shift firmness but he does shift points and even that I'm sure is a lot of work because of all the variables that go into the shift scheduling.
  19. Sep 10, 2018 at 3:36 PM
    #6439
    TRON
    Yeah the intake cam should be the most gains. Us manual shifters are all good ;)
    Norton and Roostfactor like this.
  20. Sep 10, 2018 at 7:32 PM
    #6440
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    That and I would want the ucon exhaust cam gears to go along with whatever ovtune comes up with.
