TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 13, 2018 at 10:50 PM
    #6521
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Lynnwood wa.
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Or maybe I'll make the modifications after the maf location to prevent a potential issue.
  2. Sep 13, 2018 at 10:51 PM
    #6522
    Roostfactor
    Roostfactor Well-Known Member
    Near TX panhandle
    2015 DCSB OR Pyrite Mica
    UCON, URD TCAI, URD Headers, Custom Y-Pipe and fully 3" exhaust, Walbro 255 fuel pump, Maggy SC, 2.7 pulley, CSF Radiator, JF Racing SC pulley wrap mod
    Just takes a bit of google my friend.
    http://www.saxonpc.com/100mm-cells-for-100.html
    If I ever re-position my throttle body directly to the sc inlet and get rid of the stock restriction my plan is a 4" intake where the battery currently sits, then taper down to the 3" tb with one of these honeycomb straighteners to prevent maf errors.
  3. Sep 13, 2018 at 11:32 PM
    #6523
    12TRDTacoma
    12TRDTacoma [OP] Pulley Man ;)
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    Wow. They sell them preassembled. I had no idea. I would not mind running one of these at all.
    On a sidenote, that would be one hell of a mod for the blower. How much of a power bump do you think it would give you if you did that?
    Roostfactor likes this.
  4. Sep 14, 2018 at 8:02 AM
    #6524
    Roostfactor
    Near TX panhandle
    I dont have any idea really. As far as I know it has never been done before. It would most likely improve throttle response due to closer tb position and top end.
    Probably not much improvement for stock or 2.85 pulley but for those with smaller pulleys we may see benefit. It's like what I had talked about before, when you start to create vacuum in the sc inlet it takes more hp spin the sc.
    @Athlaos talked about this as well referring to his dyno charts.
    I also demonstrated this to @5thGearPinned when we had his sc off. With a drill hooked up to his sc spinning at roughly 2200 rpm if you block a little more than half the sc inlet the drill would start bogging down and of course would get worse to more you close off the inlet. Considering we are spinning 6 times that speed it makes sense we are being robbed of available hp due to parasitic drag on the sc.
    So it's not that the engine necessarily would make that much more power but losing parasitic load on the sc would make the power available to the flywheel.
  5. Sep 14, 2018 at 8:15 AM
    #6525
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    I would personally love to be able to do this to mine, but California emissions. :(
    Athlaos and Roostfactor like this.
  6. Sep 14, 2018 at 8:21 AM
    #6526
    Roostfactor
    Near TX panhandle
    Leave! I did.
    BillDaCat8, rmepilot, Torspd and 4 others like this.
  7. Sep 14, 2018 at 8:41 AM
    #6527
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    Well... That is one workaround to the problem. Lol.
  8. Sep 14, 2018 at 9:10 AM
    #6528
    Roostfactor
    Near TX panhandle
    No offense to all the Cali folk as I grew up there but man, once I left there is no going back!
    StOrMyThEtAcO likes this.
  9. Sep 14, 2018 at 9:26 AM
    #6529
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    None taken at all dude! This state sucks!!
  10. Sep 14, 2018 at 11:26 AM
    #6530
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    There's nothing wrong with California except for the people and gov't.
  11. Sep 14, 2018 at 11:28 AM
    #6531
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    As long as all of the people pouring out of there, remember to vote against policies which ruined that great state. There won’t be a repeat. As long as they remember.....For the ones there, they need to vote against B.S. that stifles people’s lives, while simultaneously being a vampire on their wallets. Nearly punitive to live there.
    Something so simple as installing a “y-pipe” or headers, that makes the legislators’s nerves crawl. Emissions is likely 20% the reason. Betting high. Money however, is C.A.R.B.’s driving force. They have literally been quoted for saying that they make the rules, so they know how to break them. That’s a longer unrelated story though.
  12. Sep 14, 2018 at 11:38 AM
    #6532
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; mesojdm's Ultimate LED Dome and Map Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Pro 500; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    If CO is any indication, many don't understand or remember what they're fleeing. We've got a lot of transplants here, where we continue drifting further and further in CA's direction. :mad:
    Roostfactor and 12TRDTacoma [OP] like this.
  13. Sep 14, 2018 at 11:38 AM
    #6533
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Recently CARB tasked independent engineer firms to come up with ideas for a completely petroleum free vehicle. That would last about as long. Including bearings, joints, etc..... They were not happy with the responses of what could be used instead. Then they became very frustrated. Lol
  14. Sep 14, 2018 at 11:40 AM
    #6534
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Running from the policies which made them leave, then making the same choices in the new place. Insanity......:annoyed:
    At their behest, no one will be allowed to make their own choices to buy and use boost like the drug addiction it is.
  15. Sep 14, 2018 at 12:11 PM
    #6535
    oni06
    oni06 Well-Known Member
    Keith
    Harbor City, CA
    Because you know next time it will work.
    o_O:annoyed:o_O:annoyed:
  16. Sep 14, 2018 at 4:58 PM
    #6536
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    A Truck
    Some Stuff
    Dislike. Put on Iggy. Goodbye David :mad:
  17. Sep 14, 2018 at 5:10 PM
    #6537
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '15 DCLB S/C 4x4 Limited Pyrite Mica
    Same with Oregon. :annoyed:
  18. Sep 14, 2018 at 5:13 PM
    #6538
    rmepilot
    Rob
    Huntsville, AL
    I remember when C Springs was a cool place to live. You guys still have a great Irish Pub. :cheers:
    Norton and Roostfactor like this.
  19. Sep 14, 2018 at 5:34 PM
    #6539
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, Toyo AT2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs URD 2.85" stealth pulley, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator.
    Not everywhere in CO has rules, just like TX. It’s only the big cities.
  20. Sep 14, 2018 at 6:05 PM
    #6540
    oni06
    Keith
    Harbor City, CA
    That's where all the CA people are going. Plus the cities make the rules for everyone else just because of population.
