TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 15, 2018 at 5:20 AM
    #6541
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Fact. Look at NY...
    Norton, oni06[QUOTED] and rmepilot like this.
  2. Sep 15, 2018 at 7:26 AM
    #6542
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Check engine light came on last night P0103 Mass air volume input circuit high. Looked at freeze data. 42.1 lb/ min while I was at 4700 RPM. Probably was pushing 9 or 10 psi when it happened. URD intake.
    AFR's are reporting the same as they always throughout the RPM range and the sensor did not take in excessive water... I just chalk it as a glitch, I just cleared it and away I go.
  3. Sep 15, 2018 at 7:33 AM
    #6543
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have nothing to add, except for some nerdy calculations and estimations.
    42.1 lb/min = 318 g/s
    318 g/s x 1.18 = ~375.24 hp @ flywheel
    :thumbsup:
  4. Sep 15, 2018 at 7:45 AM
    #6544
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Very nice! I have actually seen more in the past before when doing a few WOT datalogs, so it's good to know where I am at for the most part. :D
  5. Sep 15, 2018 at 7:58 AM
    #6545
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    1 lb/min = ~7.5 hp @ crank.
  6. Sep 15, 2018 at 7:59 AM
    #6546
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :thumbsup: for future maths!
  7. Sep 15, 2018 at 8:01 AM
    #6547
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  8. Sep 16, 2018 at 12:33 PM
    #6548
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I thought this was interesting, when Roost and I had my supercharger off, the orange intercooler seal fell off. So I ordered a new one from URD. Without the seal my boost was as high as 12psi but a steady 11.45. When I put the new seal in, the boost is now at a normal 10 to 10.25. This is with a 2.5 pulley.
  9. Sep 16, 2018 at 12:41 PM
    #6549
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Oem trd fit vs. Magnuson current?
  10. Sep 16, 2018 at 12:42 PM
    #6550
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That sounds like an indicator that the heat exchanger is a confirmed restriction inside of the blower, and the fact that the seal is not keeping the air from going only through the exchanger is allowing extra boost to build.
  11. Sep 16, 2018 at 12:44 PM
    #6551
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That is correct. Airflow will always take the path of least resistance. Any intercooler, radiator, heat exchanger will always have a measure of resistance greater than the air not having to go through something. It the price you pay when manipulating temperatures.
  12. Sep 16, 2018 at 12:48 PM
    #6552
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So what do you think, seal on or seal off? I have always slightly contemplated removing the seal of mine because I have read they go bad anyways.
  13. Sep 16, 2018 at 1:23 PM
    #6553
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I would remove the seal if I was spraying meth or fuel.
    Roostfactor likes this.
  14. Sep 16, 2018 at 5:25 PM
    #6554
    Jesse
    Poulsbo
    15' DCSB OR S/C
    If it's easily reused I may pop it off to see what happens.
    Roostfactor and 12TRDTacoma[OP] like this.
  15. Sep 16, 2018 at 5:58 PM
    #6555
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think I’d rather leave the seal on so the air is forced to go through the cooler.
    I’ve seen @Roostfactor ’s cooler temperature probe setup and the cooler is definitely lowering the temps of the air entering the intake manifold.
    If you take the seal off, the air will take the easier path around the cooler and thus hotter air will be going in.
    I’m not an expert on what the hamsters are doing inside the engine, but I think they’ll run and turn the wheel a lot faster if they’re not dead from heat stroke.
  16. Sep 16, 2018 at 6:50 PM
    #6556
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Damn Login, that is too funny. Just too much. It’s like hurricane weathermen getting busted.
    Torspd, Roostfactor, stairgod and 3 others like this.
  17. Sep 16, 2018 at 6:52 PM
    #6557
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Most seals start to fall apart with higher boost and time. I took my out about 5 years ago. It definitely is great in the winter
  18. Sep 16, 2018 at 7:23 PM
    #6558
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Winter time = Boost season.
    I think everyone here loves the cool temps, for vehicle purposes of course.
  19. Sep 16, 2018 at 7:24 PM
    #6559
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    :rofl:
  20. Sep 16, 2018 at 7:24 PM
    #6560
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yea that weather channel fake news clip was a good one.
