TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 28, 2018 at 5:53 PM
    #6681
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Replace them all, or just the bad one?
  2. Sep 28, 2018 at 5:57 PM
    #6682
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That is totally up to you. When I did my carrier bearing I replaced none, just greased them, but I was low mileage at the time. Depends how many miles you have, if you are over 100 on original stuff you might as well replace them all, because typically stuff like secondary ignition components, heat involved sensors, and rolling assembly items should all be replaced at the same time due to all of them seeing the same amount of load, wear, heat cycles, etc.
  3. Sep 28, 2018 at 5:59 PM
    #6683
    rmepilot
    Rob
    Huntsville, AL
    @ 72k
    The slight vibration got worse, after I walked an early 90's 5.0 Mustang last weekend... :D
  4. Sep 28, 2018 at 6:02 PM
    #6684
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Highly likable post! Judgement call on replacing the rest of the U joints then Mr. Rob.
    I believe I was around that mileage when I did my carrier on the truck. I've been good. Of course, knock on wood as always but the ball is in your court on what you would like to do my Bruddah.
  5. Sep 28, 2018 at 6:14 PM
    #6685
    rmepilot
    Rob
    Huntsville, AL
    Much appreciated 'berto! :thumbsup:
  6. Sep 28, 2018 at 6:15 PM
    #6686
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here to serve. :hattip:
  7. Sep 28, 2018 at 6:34 PM
    #6687
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Are stock driveline(s) the only way to go? I assume they dont require maintenance ever but are there aftermarket ones? Or for racing only where money is no object?
  8. Sep 28, 2018 at 6:41 PM
    #6688
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spicer has a whole line for all your modding necessities. Look 'em up!
  9. Sep 28, 2018 at 6:45 PM
    #6689
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I use the term spicy earlier and a brand of parts like spicer appear. Coincidence?
  10. Sep 28, 2018 at 8:13 PM
    #6690
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I literally ordered the carrier bearing and three U-joints this morning. My carrier bearing is shot, so I decided to just replace everything since I just turned over 100,000 miles a few days ago. I went with stock Toyota parts, is Spicer better?
    Roostfactor and rmepilot like this.
  11. Sep 28, 2018 at 8:15 PM
    #6691
    rmepilot
    Rob
    Huntsville, AL
    My carrier seems to be in good shape, but will probably order the 3 u-joints.
    5thGearPinned likes this.
  12. Sep 28, 2018 at 8:16 PM
    #6692
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I’m in the opposite position, carrier bearing shot, but U-joints seem ok.
    mr.trd likes this.
  13. Sep 28, 2018 at 8:47 PM
    #6693
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’ve only done the sync/jumper procedure without the UCON installed. Don’t know if it’ll work or not if UCON is in the loop.
    Your TRD flashed ECU is useable by another truck as long as it’s the right part number ECU for the truck it’s going into. They just need to do the jumper thing to get it synced up before it’ll start.
    Norton and DocME[QUOTED] like this.
  14. Sep 28, 2018 at 9:38 PM
    #6694
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    stock joints are spicer
  15. Sep 28, 2018 at 10:00 PM
    #6695
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Thanks for the info. I’ll try and sync up the ecu first, without the UCON. Then swap the UCON back in.
    loginfailed[QUOTED] likes this.
  16. Sep 28, 2018 at 10:04 PM
    #6696
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    So what do you guys think of cvj axles. Curious cause in live near Denver and probably due for a new set hitting 100K
  17. Sep 28, 2018 at 10:30 PM
    #6697
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I haven't heard enough information of them to say one way or another. The problem is stock axles only have so much geometry before a different design is required to prevent so much rubbing. I have been running on busted axle boots for about 2 years now. Primarily because I am sick of cleaning grease off the lower sides of the truck and under the frame and would rather let them do their thing under there. I don't wheel anywhere near as much as I used to so it is a moot point for me as of right now as road contaminants are dropped to a minimum, but anyways. Give them a whirl. You don't know until you try.
  18. Sep 29, 2018 at 12:19 AM
    #6698
    12TRDTacoma
    Rob
    Concordia
    Boosted
    In others news I had a friendly power exchange with what appeared to be a current generation (possibly even 2018) Ford F-150 tonight. I think I surprised him, but made him salty that not only could I keep up with minimal effort with his junker, but also would eventually pass him if I kept the pedal at a constant position at all times. Lucky for him I was running on 1/8 tank and anything longer than average spirited runs would be disliked by the blower.
  19. Sep 29, 2018 at 4:47 AM
    #6699
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Great product. Myself and @HolyHandGrenade run them.
    Roostfactor and HolyHandGrenade like this.
  20. Sep 29, 2018 at 4:50 AM
    #6700
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Da fuq you talking about?
    Droptopfox likes this.
