TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 29, 2018 at 5:21 AM
    #6701
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I think he’s just talking about the boot pleats rubbing.
    I know you already know this Jon, but I always order my CVJ axles with high angle inner and OEM outer boots. Rubbing has never been an issue.
  2. Sep 29, 2018 at 5:27 AM
    #6702
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    When they did mine, the guy showed me all the worn parts and explained what they changed / upgraded. I don’t remember the details any longer, but they did do a bunch of stuff to it.
  3. Sep 29, 2018 at 7:25 AM
    #6703
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Would these different boot pleats matter if you had a bracket lift? Or since I understand my axle geometry being stock-ish would I get more life out of them?
  4. Sep 29, 2018 at 7:57 AM
    #6704
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Forgive me.
    The stock CV axle boot's are only capable of so much angle on them from lift before a different design (like a 930 bates or LT boot) is required, or in many cases more desirable due to the chance of less tearing.
  5. Sep 29, 2018 at 8:43 AM
    #6705
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Google brother watching you. :spy: Seriously
  6. Sep 29, 2018 at 8:48 AM
    #6706
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I don’t really know anything about drop bracket lifts.
    That said, I imagine your axle angles are the same as they were stock, and you have no need to add high angle boots.
    I’m not sure exactly what you’re asking about getting more lift.
  7. Sep 29, 2018 at 8:55 AM
    #6707
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Was assuming my geometry was the same as stock. Curious if a boot designed for suspension lifts would have a longer life.
  8. Sep 29, 2018 at 9:15 AM
    #6708
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Your lift basically keeps the geometry equal to that of a stock truck, unless of course you add adjustable coilovers and crank them. I have had everything from stock boots to the CVJ high angle ones. Never had an inner boot problem. All my ripped boots were the outers.
    How many inner boots have you gone through?
  9. Sep 29, 2018 at 9:18 AM
    #6709
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Thanks for the clarification. How many inner boots have you gone through?
  10. Sep 29, 2018 at 9:19 AM
    #6710
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Revised suspension is in the forecast. Cant fully reverse the bracket lift but do want to upgrade uca's and kings. Research is required as most are not silly enough to go bracket lift. I bought mine this wayo_O
    Roostfactor and stairgod like this.
  11. Sep 29, 2018 at 9:21 AM
    #6711
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Head on over to the DB lift thread. A few guys over there have done UCAs and Kings/Foxs
  12. Sep 29, 2018 at 9:52 AM
    #6712
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Actually, I've eaten through at least 3 pairs of outer boots so far. The inners for me have not been so much the problem. Especially now that I have been running the 930 LT style. My inners are ready to give but the others tore long ago.
  13. Sep 29, 2018 at 10:15 AM
    #6713
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    also you can return to a non DB kit.
    @AaronArf did it to his awhile back. Just takes a little fab work.
  14. Sep 29, 2018 at 10:41 AM
    #6714
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Kinda what I am saying. Boots are a wear item, and I have ripped way too many outer boots due to wheeling.
  15. Sep 29, 2018 at 11:06 AM
    #6715
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They are more of a wear item when you have a lift and angles are more pronounced.
    If you wheel and frequently move those boots up and down pretty frequently, of course they are going to tear quicker. Nature of the beast.
    I personally loved my LT boots but they were constructed of cheaper rubber and they became dry rotted fairly quickly. If they didn't they would had lasted much much longer than they did.
    Biscuits likes this.
  16. Sep 29, 2018 at 2:21 PM
    #6716
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Now I'm questioning my carrier bearing as well (more play than I would like, so I may as well do a complete rebuild).
    Which one did you go with?
  17. Sep 29, 2018 at 4:57 PM
    #6717
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I replaced it with a polyurethane variant IEDLS polyurethane yellow version. Some modifications may be necessary depending on your lift heights, mine required none and I'm still rocking it actually. It also drives with much more compliance since there isn't a bunch of slop like the stock carrier has.
    There was a HUGE group buy on it that I organized some time ago. There are at least two threads circulating regarding it that I created some time ago.
  18. Sep 29, 2018 at 5:11 PM
    #6718
    rmepilot
    Rob
    Huntsville, AL
    I’m just under 3” all around. I’ll probably add a CB drop when I rebuild it.
  19. Sep 29, 2018 at 5:24 PM
    #6719
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You may not need to if you go polyurethane. I actually ran the carrier flipped the way it came and fabbed my own sandwich plate to seal off the bearing and ran it like that. If you are that high than you most likely will not need to either if you go with the poly CB.
  20. Sep 29, 2018 at 5:37 PM
    #6720
    rmepilot
    Rob
    Huntsville, AL
    Sweet!
