TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 29, 2018 at 5:39 PM
    #6721
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I just talked the wife into headers. :bananadance:
    Earlier today she said my truck sounds week... o_O
    She drives a Hemi Durango. :burnrubber:
  2. Sep 29, 2018 at 5:48 PM
    #6722
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Just tell her that you guys should race for pink's. That'll make her change her mind about that "sounds weak" comment.
  3. Sep 29, 2018 at 6:12 PM
    #6723
    rmepilot
    Rob
    Huntsville, AL
    She’s got me beat on hp/trq, but that AWD SUV is heavy.
    Roostfactor and BassAckwards like this.
  4. Sep 29, 2018 at 6:21 PM
    #6724
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I drove away from a 5.7 hemi 1500 not too long ago. I think youre good, the weight advantage youve got is substantial
  5. Sep 29, 2018 at 7:00 PM
    #6725
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I almost kicked my buddy's ass back when he had a 1500 hemi Ram 5.7 when I was bone stock 4.0 non supercharged. He walked away from me because of the obvious 2 cylinder advantage, but yeah, point is you are past good now. Never sleep on a boosted Tacoma. Many make that mistake on me. ;)
  6. Sep 29, 2018 at 7:17 PM
    #6726
    ThomasMore66
    Dallas/Fort Worth & Durango
    It’s all happening...
  7. Sep 30, 2018 at 1:07 AM
    #6727
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is something so visually and beautifully striking about seeing all those pulley's in one image. :D
  8. Sep 30, 2018 at 5:12 AM
    #6728
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I find it very difficult to believe that you've managed to keep an axle in one piece long enough to tear a boot.
    :boink:
  9. Sep 30, 2018 at 1:39 PM
    #6729
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    You are on thin ice buddy. You have two on your wall of shame.
    And I have yet to blow apart an outer cage.
  10. Sep 30, 2018 at 2:38 PM
    #6730
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks to everyone that gave tips for changing plugs with the s/c in place. Went pretty smooth.
  11. Sep 30, 2018 at 2:49 PM
    #6731
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Told you it would. :) I got that procedure locked down now.
    Roostfactor and Biscuits like this.
  12. Sep 30, 2018 at 2:53 PM
    #6732
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Only spooky part was getting the drivers side center coil top out. That's a tight clearance.
    Biscuits likes this.
  13. Sep 30, 2018 at 3:24 PM
    #6733
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No excuses, play like a champion!
  14. Sep 30, 2018 at 3:28 PM
    #6734
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. But when it's your dd and your wrenching parked on the street the unexpected gets your blood going. Builds character. Bought the truck with 27k plugs I pulled arent factory. Runs smoother than ever now.
  15. Sep 30, 2018 at 3:29 PM
    #6735
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I really need to do this to both Tacomas.
  16. Sep 30, 2018 at 3:32 PM
    #6736
    Jesse
    Poulsbo
    15' DCSB OR S/C
    If you have two swivels, two 3" & one 6" extension you're good. Took me 2 hours cause I'm special.
  17. Sep 30, 2018 at 3:33 PM
    #6737
    Biscuits
    And by chance I do!
    What plugs did you end up going with?
  18. Sep 30, 2018 at 3:35 PM
    #6738
    Jesse
    Poulsbo
    15' DCSB OR S/C
  19. Sep 30, 2018 at 3:36 PM
    #6739
    Biscuits
    Beautiful, sir.
  20. Sep 30, 2018 at 3:38 PM
    #6740
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I know. If only my hand modeling career could finance my mod habbit.
