TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 16, 2017 at 1:23 PM
    #661
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Not yet, I believe the first batch of ovtune are shipping out this week
    equalme[QUOTED] likes this.
  2. Nov 16, 2017 at 1:25 PM
    #662
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It sounds ridiculous doesn't It? It sounds hell of pissed off when you are revving it.
    That's no moon!
    Translation: (That's no 2.5 pulley!)
    lol
    The brand or company RatioTek is owned by the relative of the man who invented TransGo. The family apparently knows their engineering and reverse engineering as well. That was good enough for me to buy.
    Neither, that is correct. I am reviewing data logs of it when I took it for a drive. I want to ensure that all looks okay. I was hitting 10 psi already between half and 3/4 throttle.
  3. Nov 16, 2017 at 1:31 PM
    #663
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Hell yeah brother!
  4. Nov 16, 2017 at 1:39 PM
    #664
    ThomasMore66
    Dallas/Fort Worth & Durango
  5. Nov 16, 2017 at 1:44 PM
    #665
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I know I know but I don’t think I have the nads to run a 2.3 on my daily driver. I still have all 4 cats as well. Hoping for a video so I can live vicariously through you lol.
  6. Nov 16, 2017 at 1:44 PM
    #666
    12TRDTacoma
    Rob
    Concordia
    Boosted
    To all following this developing story. I do believe I have reached the end of the max the TRD tune can handle. (Could be wrong there, but proper values to me on a boosted vehicle are unfamiliar territory). Besides, my reported AFR's as well as fuel trims have been needing cleaning up for a while as for right noe they just dump fuel at part throttle and even WOT applications so I finally went ahead and pulled the trigger on a Self tuning OVTune device.
    This will ensure I am consistent across the AFR board at all pedal positions and that my fuel trims stay in check at all times. I am looking forward to reclaiming some much needed fuel economy back anyways.
    Biscuits and Murphinator like this.
  7. Nov 16, 2017 at 1:45 PM
    #667
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There are only 2 cats bud. Lol.
  8. Nov 16, 2017 at 1:46 PM
    #668
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I Thought one cat in the header and one at the y pipe on each side?
  9. Nov 16, 2017 at 1:46 PM
    #669
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    4. I have 2 remain.
  10. Nov 16, 2017 at 1:47 PM
    #670
    GT7
    Grant
    Phoenix
    2013 DCLB
    Mine had 4 cats.
  11. Nov 16, 2017 at 1:47 PM
    #671
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh you guys could be right. However, one on each bank would be considered a WU-TWC (warm up three way cat)
  12. Nov 16, 2017 at 1:49 PM
    #672
    FinnJ
    Finland
    I don’t know, looks same inside. My rear ones are enough to pass the smog test.
  13. Nov 16, 2017 at 1:52 PM
    #673
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's because they're the main cats. The ones in front are only there to allow the rear main cat converters to reach temperature quicker.
    Nothing new. This design has been around for years.
    Hey @GT7 @FinnJ @Murphinator take it easy yeah? You guys can put down the pitchforks. :D
    Murphinator likes this.
  14. Nov 16, 2017 at 1:53 PM
    #674
    GT7
    Grant
    Phoenix
    2013 DCLB
    No pitchforks over here :)
  15. Nov 16, 2017 at 1:55 PM
    #675
    FinnJ
    Finland
    Same here, just chit-chatting. :)
    12TRDTacoma[OP] likes this.
  16. Nov 16, 2017 at 1:58 PM
    #676
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh yeah I know. I'm just messing with you guys. Hahaha.
  17. Nov 16, 2017 at 1:58 PM
    #677
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Knowledge is power my friend, no pitch forking over here either :cheers:
    This whole time I thought the front cats mattered.. damn.​
  18. Nov 16, 2017 at 2:00 PM
    #678
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They matter only for open loop to closed loop activation time. Other than that if you guy them or keep them they will activate a code for pre cat inactivity, but you can remove those codes with tuning software or similar.
    Murphinator[QUOTED] likes this.
  19. Nov 16, 2017 at 2:00 PM
    #679
    FinnJ
    Finland
    Still a little more, cause you started this. :boink: Try to hang on. ;)
    Why the O2-sensors are behind the front cats then? ECU don’t know anything about the rear ones?
  20. Nov 16, 2017 at 2:00 PM
    #680
    GT7
    Grant
    Phoenix
    2013 DCLB
    Just started looking at your build thread
    :thumbsup::thumbsup:
