TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 1, 2018 at 12:27 PM
    #6781
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Which one are you running?
  2. Oct 1, 2018 at 12:27 PM
    #6782
    ThomasMore66
    Dallas/Fort Worth & Durango
    Me too. Change it every oil change.
  3. Oct 1, 2018 at 12:28 PM
    #6783
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    As I understand it's more important for a forced induction engine as the result of pressure. Not to say it wouldn't benifit a n/a motor. Keeps unnecessary gunk out of the engine.
    BassAckwards and Roostfactor like this.
  4. Oct 1, 2018 at 12:33 PM
    #6784
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    You only have to pull the supercharger once to form a strong opinion on the catch can addition. There is a surprising large amount of oil buildup in the neck of supercharger body all the way down to the intercooler. I’m a firm plus one on the addition of catch cans.
    Got mine from these guys: http://www.bobsautosports.com/#2907
  5. Oct 1, 2018 at 12:47 PM
    #6785
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I modified a cheapy Amazon special.
    BassAckwards[QUOTED] likes this.
  6. Oct 1, 2018 at 1:02 PM
    #6786
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just make sure its sealed up well. Vacuum leaks suck:rimshot:
  7. Oct 1, 2018 at 1:19 PM
    #6787
    BassAckwards
    :laughing:
  8. Oct 1, 2018 at 1:19 PM
    #6788
    BassAckwards
    Thanks fellas! Looks like that is going to move closer to the top of my list.. figured it would be a good addition to keep things cleaner
  9. Oct 1, 2018 at 1:26 PM
    #6789
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I've got the cheap chinese $30 can from Amazon with the hoses that smell like a bag of :censored:. The can is actually decent quality for the price.
  10. Oct 1, 2018 at 1:37 PM
    #6790
    Roostfactor
    TX panhandle
    Yeah, if you go that route get some good fuel line or equivalent tubing.
  11. Oct 1, 2018 at 1:41 PM
    #6791
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    First thing I did was replace the hoses.
  12. Oct 1, 2018 at 2:06 PM
    #6792
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That would probably be a question best asked in a separate thread. I choose not to give my opinion on catch cans.
  13. Oct 1, 2018 at 3:25 PM
    #6793
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I got a catch can from agpturbo. Loved it on my srt4. So I got the one for the evo I think. It was $100 and the hoses were a tight fit but worked great.
    DocME, Torspd, Roostfactor and 2 others like this.
  14. Oct 2, 2018 at 2:22 AM
    #6794
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    yes it does. pretty sure thats exactly what took out my engine back in 2013
  15. Oct 2, 2018 at 5:09 PM
    #6795
    Jesse
    Poulsbo
    15' DCSB OR S/C
    At what point in throttle position or boost will the fpr mod show results? My meth gauge displays injector pulse width in percentage. Might that number change? Or would I be delivering more fuel at the same reading? Do I assume I could only run richer with this?
  16. Oct 2, 2018 at 6:44 PM
    #6796
    Roostfactor
    TX panhandle
    Lets take a look at this intriguing question @White lightning boosted, shall we?
    Stock fp = 43.5psi
    Fpr mod lowers fuel pressure below 43.5psi when engine is in vacuum
    Fpr mod raises fp above 43.5psi when in boost.
    Fuel injectors are either ON or OFF!
    There is no halfway...afr is reached by increasing or decreasing the time each injector is open.
    The above is a known factor with fpr mod so now the only variable is when transitioning from closed loop to open loop.
    We know the TRD tune is inherently rich (for stock pulley and engine requirements) but has no choice but to lean out depending on mods (extra fuel requirement) because the ecu is no longer controlling the afr but is going off of a fixed table.
    So armed with all of this new information what do you think a graph would look like between no fpr mod and with fpr mod?
    P. S. Sorry, I guess I'm in teaching mode tonight :D
  17. Oct 2, 2018 at 7:17 PM
    #6797
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My algebra skills are right down there with dunking a basketball and women. I think the afr would be the same. The two on a graph should make a slight x. Intersection point at vacuum to boost location.:fingerscrossed:
    Roostfactor likes this.
  18. Oct 2, 2018 at 7:21 PM
    #6798
    Roostfactor
    TX panhandle
    Very good!
    That's is exactly how I would hypothesize the graph. The angle of the "X" would be dependent on the fuel pressure change
    Afr's would stay the same in closed loop because the ecu would command the injectors to stay open longer to compensate for the lower fp.
    That does not apply to open loop.
    BassAckwards and Torspd like this.
  19. Oct 2, 2018 at 7:24 PM
    #6799
    Jesse
    Poulsbo
    15' DCSB OR S/C
    You are an amazing teacher if you can explain that in a way I understand!
  20. Oct 2, 2018 at 7:32 PM
    #6800
    Roostfactor
    TX panhandle
    Just one of many around here! Happy to spread the knowledge!
