TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 2, 2018 at 7:36 PM
    #6801
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    So if I'm at 1-2% pulse width at idle I should have a higher # now correct? And/or would it only show a change under load and before boost?
  2. Oct 2, 2018 at 7:40 PM
    #6802
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    With fpr mod?
  3. Oct 2, 2018 at 7:40 PM
    #6803
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes. Well, 1-2% before mod.
  4. Oct 2, 2018 at 7:43 PM
    #6804
    Roostfactor
    TX panhandle
    It would be higher after mod because of lower fp.
  5. Oct 2, 2018 at 7:46 PM
    #6805
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Then I understand. Awesome. I have some references memorized. I'll be able to check differences tmrw when driving. For example at 65mph typical pulse width is around 9-10%
  6. Oct 2, 2018 at 7:53 PM
    #6806
    Roostfactor
    TX panhandle
    Keep in mind though at that speed you are probably close to zero vacuum which means very close to stock fp. That would be where your "X" intersects so very little difference in ipw.
    The biggest difference will be seen under high boost high throttle conditions because that is where the greatest demand on the injectors is.
    So at idle with no fpr your at 1 to 2%
    Idle with fpr may be 2 to 3%
    Max throttle no fpr may be 85%
    Max throttle with fpr 75%
    This is just a WAG (wild ass guess) but you get the idea
  7. Oct 2, 2018 at 7:57 PM
    #6807
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I get the idea. I may have to flip flop this mod to get better #s under load. I may be mistaken but I think I've seen pulse width #s at 100% before.
  8. Oct 2, 2018 at 8:01 PM
    #6808
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Need to be careful though. Last week was early morning boostacular on country roads. Lights gaining on me, I slow down and take my turn off. Sherriff kept going. Let's just say he must have heard my exhaust note. Had to be a tacoma lover to look the other way on that one!
  9. Oct 2, 2018 at 8:01 PM
    #6809
    Roostfactor
    TX panhandle
    It's possible. I dont know what the TRD or OV Tunes specify.
    Or could that be your meth % of output?
  10. Oct 2, 2018 at 8:08 PM
    #6810
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Shit... I really dont recall. Could have been. Both numbers are on display. Testing required.
    Roostfactor likes this.
  11. Oct 2, 2018 at 8:13 PM
    #6811
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Wish I could find other info on meth with this motor. Adjusting it is a total guesswork game. Maybe if I data log and use techstream. If ovtune ever orbits back. Now it comes on at 2lbs and hits full at 4.
  12. Oct 2, 2018 at 9:26 PM
    #6812
    Roostfactor
    TX panhandle
    You can use your ipw to determine when to set max meth output. 2psi is probably good for start. What is your max boost now?
    I'm not experienced with it but I would try setting meth max close to your boost max. We are all low boost compared to other applications and going from minimum to maximum spray within 2psi gives very little resolution.
    But isnt your controller also using ipw to equally determine min to max spray?
  13. Oct 2, 2018 at 9:36 PM
    #6813
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It can work off boost or pulse width. OR a combo of both with adjustments in 1% incrementally. Near infinate choices on setting it.
  14. Oct 3, 2018 at 12:05 AM
    #6814
    Roostfactor
    TX panhandle
    Right but I think I remember you saying you were going off Snow's recommendation which had boost and ipw input at a 50 50 ratio.
  15. Oct 3, 2018 at 5:25 AM
    #6815
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I am. Just dont know how close I am. Its tricky to read all numbers, and drive. Benifit of dyno haha!
  16. Oct 3, 2018 at 8:55 AM
    #6816
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Hit 94% injector duty cycle at redline this morning.
  17. Oct 3, 2018 at 10:39 AM
    #6817
    Roostfactor
    TX panhandle
    Do you have a larger meth jet? You are using 50% water to meth ratio correct?
    Look at your controllers idc chart. What % of idc is it set to max out meth output?
  18. Oct 3, 2018 at 1:13 PM
    #6818
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  19. Oct 3, 2018 at 1:29 PM
    #6819
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Purdy!
    loginfailed likes this.
  20. Oct 3, 2018 at 1:35 PM
    #6820
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    loginfailed[QUOTED] likes this.
