TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 7, 2018 at 12:14 PM
    #6841
    ThomasMore66
    Dallas/Fort Worth & Durango
    The Oracle has spoken.
    rmepilot, Norton, loginfailed and 2 others like this.
  2. Oct 7, 2018 at 12:19 PM
    #6842
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Its about time you realize the true extent of my capabilities Sir Thomas! :D:thumbsup::D
  3. Oct 7, 2018 at 12:43 PM
    #6843
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @Darkgoatracer thanks you!
    Here is a picture for your help
  4. Oct 7, 2018 at 1:11 PM
    #6844
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I saw that pic on the FB page.
    E3CE743D-E9AE-467C-AFA9-28E5768042D9.jpg E6C53625-CFB3-4718-8027-C6959562A386.jpg
    Biscuits likes this.
  5. Oct 7, 2018 at 2:43 PM
    #6845
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I believe most sensor bungs have a lip that will sit flush when you drill the proper size hole in the exhaust. That’s how I’ve seen 3 different sensors (AEM)
    Biscuits and Darkgoatracer like this.
  6. Oct 7, 2018 at 4:42 PM
    #6846
    Roostfactor
    TX panhandle
    It totally depends on the bung. Some are flat, contoured, saddle, etc. I researched extensively when I was designing my exhaust.
    Biscuits and Skootter14[QUOTED] like this.
  7. Oct 7, 2018 at 5:42 PM
    #6847
    ThomasMore66
    Facebook?! I’ll have none of that.
  8. Oct 7, 2018 at 7:24 PM
    #6848
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Fakebook...
    :crapstorm:
  9. Oct 7, 2018 at 7:27 PM
    #6849
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    But IG is ok?
    Roostfactor and jojotoo like this.
  10. Oct 7, 2018 at 7:28 PM
    #6850
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hard to keep up with the cool kids.
  11. Oct 7, 2018 at 7:33 PM
    #6851
    Skootter14
    Jeremy
    that's why if you have none of that stuff. . .you don't have to worry about it :thumbsup:
  12. Oct 7, 2018 at 7:33 PM
    #6852
    rmepilot
    Rob
    Huntsville, AL
    :notsure:
    I prefer to just say no.
    Roostfactor likes this.
  13. Oct 7, 2018 at 7:36 PM
    #6853
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    ¯\_(ツ)_/¯
    I use just about all of them, each for different reasons.
    oni06 likes this.
  14. Oct 7, 2018 at 7:38 PM
    #6854
    ThomasMore66
    I did go there.
  15. Oct 7, 2018 at 7:41 PM
    #6855
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I know, that’s why I asked. :D
    Tandem tagged you before when they had your rig in the shop.
  16. Oct 7, 2018 at 8:11 PM
    #6856
    ThomasMore66
    Been out of high school 34 years. Never looked back. Never looked for anyone, don’t need to know what happened to them. Not lost, don’t need to be found. Does piss me off that some businesses only work that way. A good ol’ Website is the answer.
  17. Oct 7, 2018 at 8:47 PM
    #6857
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Everyone’s different, just like everyone else.
  18. Oct 8, 2018 at 3:51 AM
    #6858
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  19. Oct 8, 2018 at 5:48 AM
    #6859
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  20. Oct 8, 2018 at 8:44 AM
    #6860
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    These 30-40 degree mornings would be amazing if it weren't for the whole 7k ft elevation thing. Been mostly skimming and the occasional shit post in here the past few months. Everyone still fast, happy and full of boost?
