TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 14, 2018 at 5:02 AM
    #7181
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    @loginfailed , would you still happen to have the links to the speedhut gauges that you bought originally for your S/C? I was looking through the group buy thread, I know you posted it. Just can't find it. @Darkgoatracer is looking to do what you did and run dual widebands, so he is looking to order a second afr gauge that will match the first. I looked back through my email, and cant find the order confirmation anymore. Must have deleted it.
    I know I based mine off yours, and it was very similar.
  2. Oct 14, 2018 at 5:04 AM
    #7182
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    36 degrees right now boys. Going for a ride with some xrunner guys through the white mountains of nh. Great day to be boosted. Will post some pics later.
  3. Oct 14, 2018 at 6:20 AM
    #7183
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think it was this one:
    https://www.speedhut.com/gauge/GL-AFWB-01/7/Air-Fuel-Gauge-Wide-Band-10-18-(FOR-INNOVATE)
    Black Dial, Silver Text, Eurostile Font, Blue Illumination, Steath Black Bezel
    On the blade, they have a lot more options now than they did then. But I think mine was:
    “Black Blade, Racer Red (Glows Red)
    Norton and TacoCat[QUOTED] like this.
  4. Oct 14, 2018 at 7:22 AM
    #7184
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Everyday is a good day to be boosted!
    I know I was loving every second of it yesterday. 1789 miles, without having to knock the auto into 4th gear one time due to hunting in my eight thousand pound Taco / trailer combo.
    Used a LOT of fuel however...
    mr.trd, TacoCat, Skootter14 and 3 others like this.
  5. Oct 14, 2018 at 7:27 AM
    #7185
    ThomasMore66
    Dallas/Fort Worth & Durango
    36. Haven’t seen that temp in a long time. In Dallas they talk about Artic Blasts when it gets below 40.
  6. Oct 14, 2018 at 7:48 AM
    #7186
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This thread has been very active since yesterday!
    @RyanL qwikchange pulley. If you live at high elevations you can get away with running smaller pulley's due to the fact that boost is less the higher in elevation you go.
    Make sure you run an AFR/ boost gauge combo whatever you do, AND make sure you swap out the factory fuel pump whatever you do as well. Both are essentials and mandatory prerequisites if you want to begin modding. After that a qwikchange set up is the best ideal way to go for you and depending how much boost you are pushing, anything that gets you past 8.5 psi and you are going to want to rehaul your valve body in your transmission.
    Welcome to the madness. ;)
  7. Oct 14, 2018 at 7:57 AM
    #7187
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    37* out right now. Going to have one last bomber run before I get rid of it.
    The pulley that is. Going to do some pulley swap(s) with @crashnburn80 after the game.
  8. Oct 14, 2018 at 9:14 AM
    #7188
    ThomasMore66
    You going larger?
  9. Oct 14, 2018 at 9:15 AM
    #7189
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You mean smaller. :)
    Norton and TacoCat like this.
  10. Oct 14, 2018 at 9:15 AM
    #7190
    Jesse
    Poulsbo
    15' DCSB OR S/C
  11. Oct 14, 2018 at 9:16 AM
    #7191
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    How have you been enjoying the truck since all the changes.....mainly the headers and pulley?
  12. Oct 14, 2018 at 9:22 AM
    #7192
    ThomasMore66
    I love it. 1st gear is kinda worthless because it redlines immediately. I think there is enough room with the TRD tune and fpr mod to go to the 2.5”.
  13. Oct 14, 2018 at 9:29 AM
    #7193
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah, you can do it and see how it goes....
  14. Oct 14, 2018 at 9:33 AM
    #7194
    ThomasMore66
    If it works at 500’ of elevation, it’ll work in CO. Live a little! Life should be fun.
    Sitting here downloading all the pics from my daughter’s wedding wondering when I became the old guy in the room.
  15. Oct 14, 2018 at 9:41 AM
    #7195
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    You can always move to Alabama... :D js
    Skootter14[QUOTED] likes this.
  16. Oct 14, 2018 at 9:46 AM
    #7196
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Ahhh...your an animal!! :cool:
  17. Oct 14, 2018 at 10:20 AM
    #7197
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I went as far as to head to Benning to the maneuver course before going back to Rucker....haha.
    Doubt I’ll ever head back there
  18. Oct 14, 2018 at 10:35 AM
    #7198
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It's crazy how slowly it happens. I figured it out when the guys coming into the military were born after I graduated high school.
    Biscuits, Norton and rmepilot like this.
  19. Oct 14, 2018 at 10:38 AM
    #7199
    rmepilot
    Rob
    Huntsville, AL
    Other than schools, I avoided Rucker at all costs. Redstone is a whole different world.
  20. Oct 14, 2018 at 10:51 AM
    #7200
    TacoCat
    Johnny-5
    Chantilly, VA
    You are the man. Once again. @Darkgoatracer im pretty sure this is the one. Just match up what options match the one you already have. Or you could just buy two new ones if you were looking for a different theme :) as long as they work with the innovate lc-2 i linked you to, they should work fine.
    Darkgoatracer likes this.
