TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 14, 2018 at 11:21 AM
    #7201
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Your video makes me hungry for power!!! :hungry:
  2. Oct 14, 2018 at 11:44 AM
    #7202
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    So this happened today while driving. Luckily I noticed the sound of it rattling right away
  3. Oct 14, 2018 at 11:47 AM
    #7203
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    :eek::eek:
    That is no bueno!!
    12TRDTacoma[OP] likes this.
  4. Oct 14, 2018 at 11:48 AM
    #7204
    ThomasMore66
    Dallas/Fort Worth & Durango
    Why does this happen?
  5. Oct 14, 2018 at 11:49 AM
    #7205
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I have no clue, but I think this is the second time I have seen this happen?
  6. Oct 14, 2018 at 11:59 AM
    #7206
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Oh snap!! Who else did it happen to? Where from the motor exactly is that from?
  7. Oct 14, 2018 at 12:00 PM
    #7207
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I was at the dunes yesterday romping around but nothing crazy. The dirt drag strip was flooded so I hadn't even did any WOT runs
  8. Oct 14, 2018 at 12:08 PM
    #7208
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    What are ya gonna do? Get it welded back on??
  9. Oct 14, 2018 at 12:17 PM
    #7209
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    It's the tensioner for the SC belt. I'll have to contact Magnuson to see if I can get a new one under warranty or otherwise purchase just this part
  10. Oct 14, 2018 at 12:57 PM
    #7210
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I believe that tensioner is near the bottom of the engine IIRC.
    I still don’t see how that happens?!?!?
  11. Oct 14, 2018 at 1:30 PM
    #7211
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Oct 14, 2018 at 1:49 PM
    #7212
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Curious if he was running a smaller pulley/shorter belt.
  13. Oct 14, 2018 at 2:26 PM
    #7213
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yep. happened to me maybe a year at most ago. Was just driving down the road, and heard and felt 0 boost.. pulled over and popped the hood.. and it was just chillin down on my skidplate.
    I was running the 2.8 (I believe, I dont think I had switched to the 2.6 yet).. and running the shorter gates belt. the extra strain Im sure didnt help at all... but those tensioners are known to be a bad casting process. Mine broke in the same exact spot. the thinnest area of the tensioner, plus weak casting.. and especially with any extra load (shorter belt), they just snap like that. I just replaced mine with another one.. and went back to the original S/C belt. but.. since im running a 2.6 now, I might re-visit the shorter belt.
    I'll see if I can dig around and find more about my incident.
    rmepilot, Biscuits, Torspd and 2 others like this.
  14. Oct 14, 2018 at 2:32 PM
    #7214
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It might not be a bad idea to revisit having a whole new tensioner made of full steel again. The shorter belt's adds extra tension which is good to ensure no slippage, and if you have too much tension on the cast aluminum tensioner casing, snap it goes.
    I never did like cast aluminum. It's very brittle.
  15. Oct 14, 2018 at 2:35 PM
    #7215
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    exactly. I did reach out to a company, but they were only able to either make something custom (very pricey) or alter another kit to make it work (also pricey). I just couldnt justify it.
    EDIT: Here's when mine happened..
    https://www.tacomaworld.com/threads/lost-boost.491228/page-5#post-16148882
  16. Oct 14, 2018 at 2:42 PM
    #7216
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I remember when you broke yours actually. I was blown away because I couldn't believe it. Still can't believe it actually. I have been doing some investigative work to figure out if there is a 70.5" or 70" length version of the Gates Fleetrunner belt which can be modified to have a rib or 5 cut off of it so the guys with 2.8 pulley's can still run stock length but get increased belt traction if coupled along with Roostfactors pulley wrap mod.
    I currently run a Fleetrunner belt. It works amazingly combined with all the wrap and tension mods I have made additional to.
  17. Oct 14, 2018 at 2:44 PM
    #7217
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Wow pretty much identical breaking points. I wasn't even in boost when I noticed mine. Just heard it rattling against the crank pulley and noticed the SC belt off. I cut the belt out and drove home with no issues just using light throttle
  18. Oct 14, 2018 at 2:50 PM
    #7218
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    which makes me even more confident its their manufacturing process on that tensioner casting.
    same here. not in boost, and had to cut it out to drive home. they replaced it and all has been good since then. I may try that shorter Gates belt tho again since I have the 2.6"
    12TRDTacoma[OP] and Norton like this.
  19. Oct 14, 2018 at 3:03 PM
    #7219
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Remove tensioner, warm with heat, weld on gusset, let cool slowly.
  20. Oct 14, 2018 at 3:38 PM
    #7220
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
