TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 14, 2018 at 8:54 PM
    #7241
    ThomasMore66
    Dallas/Fort Worth & Durango
    And?
  2. Oct 14, 2018 at 8:57 PM
    #7242
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It’s on. At least he made it out of the driveway.
  3. Oct 14, 2018 at 9:04 PM
    #7243
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks to @crashnburn80 ! If he didnt have a 2.7 pulley I would have been hosed. Pulley. Boyz managed to give me two wrong pulleys! Otherwise I'd have a 2.5 on.
  4. Oct 14, 2018 at 9:13 PM
    #7244
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Oh yeah, there was that too. Good thing we buy the same mods so between the two trucks we can always make one work.
  5. Oct 14, 2018 at 9:20 PM
    #7245
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Maybe I should buy one more s/c belt.
    12TRDTacoma[OP] and Biscuits like this.
  6. Oct 14, 2018 at 9:52 PM
    #7246
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    How was the install? Complicated, issues, etc???
    Norton likes this.
  7. Oct 14, 2018 at 9:55 PM
    #7247
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Look back a few posts for the picture. It tells the tale:/
  8. Oct 14, 2018 at 10:13 PM
    #7248
    Skootter14
    Jeremy
    I must have missed it. Only saw the pic of the 19mm vs 21mm that you just posted
  9. Oct 14, 2018 at 10:18 PM
    #7249
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The pulley hub needs to go on further than the urd tool allows. In haste a 19mm box end seems perfect. The inside of the wrench points apparently made contact. My superhuman strength was too much. A 21mm box wrench was perfect. Fortunately I have room to file the high spots off. Could have been worse. It runs great. Cant wait to get the correct pulleys. Mine have one too many ribs.
  10. Oct 14, 2018 at 10:35 PM
    #7250
    Skootter14
    Jeremy
    I need to get one from pulley boys before I move since they are right down the road.
    EDIT: as long as I can run a 2.8 with regular belt and current mods (Walbro 255 pump and regular S/C injectors (455cc IRCC))
  11. Oct 14, 2018 at 10:35 PM
    #7251
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    And just don’t completely lose the install tool in the middle of the process.
  12. Oct 14, 2018 at 11:17 PM
    #7252
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Yes you can. I have a 2.8 with a DW 255, TRD's upgraded injectors, and a OEM length belt.
    Whoa boy.
    Norton, Torspd, Roostfactor and 2 others like this.
  13. Oct 14, 2018 at 11:21 PM
    #7253
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    So here is the deal. Over extensive time, research, and proven mileage on others vehicles, I have found that pulley sizes in between half inch sizes will allow you to run a belt which is half an inch shorter than previous sizes.
    Say you run a 2.7 or 2.8" pulley, step down belt sizes to a 70" belt. Stock size is 70.5 while utilizing a 3.0 pulley. A 69.5" belt which is 1" shorter than stock length should be utilized when running a 2.5 pulley. You could likely get away with running the 69.5" belt when using a 2.6" pulley.
    Example. I am in between half sizes of pulley's as I am currently running a 2.3" pulley. I use a 69" belt, because if I go 68.5 that is way too tight and that opens a risk to breaking the tensioner.
    I will update and edit the first post to reflect such information soon.
    Further investigation shows there is a 6 rib version of a 70" long (1778mm effective length) serpentine belt available from Gates. If folks running a 2.7 or 2.8 pulley would like to step down in between belt sizes for in between pulley sizes, you could order this one off Amazon and slice off a rib from it with a razor blade on a vice.
    https://www.google.com/url?sa=t&sou...FjADegQICRAB&usg=AOvVaw1u0Kt7IawLxCRMNbBYyqSP
  14. Oct 14, 2018 at 11:34 PM
    #7254
    Biscuits
    2.3" pulley??
  15. Oct 14, 2018 at 11:36 PM
    #7255
    Biscuits
    Five rib Gates for those of us who don't have vices in their garage.
    https://www.gates.com/us/en/power-t...belts/gates-micro-v-belts/p/p100351/v/1228289
    Nevermind.
    Skootter14 and Roostfactor like this.
  16. Oct 14, 2018 at 11:40 PM
    #7256
    Skootter14
    Jeremy
  17. Oct 14, 2018 at 11:45 PM
    #7257
    Biscuits
    Edit. Never mind, I saw it.
    Guess I'm gonna drive a Buick Impalabu.
    Skootter14[QUOTED] likes this.
  18. Oct 15, 2018 at 12:07 AM
    #7258
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Biscuits[QUOTED] likes this.
  19. Oct 15, 2018 at 12:14 AM
    #7259
    Biscuits
    Yeah yeah, you're right. I was looking at the wrong numbers. I'll go back to the corner and sit quitely while the adults talk.
  20. Oct 15, 2018 at 2:24 AM
    #7260
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I was the fastest. The black one on the left of my blue one is also supercharger. Running the 2.825 pulley. We raced and I pulled on him pretty good. The other 2 are mostly stock. One guy who couldn’t make it has a built motor and a urd blower. His is fast. I wanna race him next time.
