TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 16, 2018 at 9:17 AM
    #7361
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Man.. I need to upgrade my Pioneer Double Din so I can get data to show. Been using an old phone running torque, but on the headunit would be so much cleaner.
    mr.trd, Roostfactor, rmepilot and 2 others like this.
  2. Oct 16, 2018 at 9:19 AM
    #7362
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    It's a really nice bonus to have the data up there. Tire pressures, best 0-60, instant mpg ... it clocks a lot of stuff. I wonder if there's any way to get a boost gauge on there?
  3. Oct 16, 2018 at 9:43 AM
    #7363
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Is that part of Kenwoods interface, or did you need a Maestro type deal to get it to work.
    I've been eyeing a new double din Android headunit. That way it will just mirror my phone, and has Torque built in.
  4. Oct 16, 2018 at 9:57 AM
    #7364
    RyanL
    Indiana
    I have a Maestro to tap into the ECU data. Would love to mirror my phone, but I'm stuck on letting Apple tell me what I can & can't do.
    XPOTRPR[QUOTED] likes this.
  5. Oct 16, 2018 at 10:13 AM
    #7365
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Got ya. Ok good to know.
    I'm pretty sure there are units out there that will work with Apple!
  6. Oct 16, 2018 at 11:02 AM
    #7366
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  7. Oct 16, 2018 at 2:58 PM
    #7367
    ThomasMore66
    Dallas/Fort Worth & Durango
  8. Oct 16, 2018 at 3:53 PM
    #7368
    RyanL
    Indiana
    oh holy crap that sounds good at WOT
    I loved those Roadkill guys back when they were on YouTube. Good times. Is this truck on a newer episode?
  9. Oct 16, 2018 at 4:20 PM
    #7369
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Biscuits, rmepilot and Roostfactor like this.
  10. Oct 16, 2018 at 4:40 PM
    #7370
    RyanL
    Indiana
    That thing’s got like 30 lbs on the rear axel, I wanna know what kind of sandbags they throw in back so they can hook up
    Biscuits and Roostfactor like this.
  11. Oct 16, 2018 at 4:46 PM
    #7371
    ThomasMore66
    There is a newer video where he’s adding the turbo.
  12. Oct 16, 2018 at 5:47 PM
    #7372
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Just do what I said. Throw the 4.0 with the sc in the little one and then swap in a 5.7 with the sc into the 2nd gen. Or an ls
  13. Oct 16, 2018 at 5:49 PM
    #7373
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Interesting .. sounds EXACTLY like my truck !
  14. Oct 17, 2018 at 7:38 AM
    #7374
    ThomasMore66
    So I watched an episode of Engine Masters this a.m. before work where they compared EFI to carbs. One of the things they data logged was the inlet air temp below the carb/throttle body. Air temp was somewhere around 80, but the carb application dropped the inlet temp to almost 32 degF just do to the vaporization. Made me wonder if any of you 7th injector guys have the ability to see the inlet temp after fuel is injected. That was more cooling than I would have thought just from gasoline. Not sure what the fuel pressure was, but from thermodynamics class I can remember that's a isenthalpic expansion just like your aircon unit.
  15. Oct 17, 2018 at 9:10 AM
    #7375
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don’t have a temp sensor there. The only person I know that has install add’l sensors is @Roostfactor but he doesn’t have a 7th.
    Roostfactor likes this.
  16. Oct 17, 2018 at 11:54 AM
    #7376
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That is a large temperature drop.
    As you said in your engineering lingo, much of that is due to the low pressure created as the air passed through the venturi of the carb.
  17. Oct 17, 2018 at 12:04 PM
    #7377
    ThomasMore66
    Found an article that discusses AFR for various fuels (gas/alcohol). I've been curious about what my AFR should be because my the pumps in my area claim 10% ethanol. I cannot buy pure gasoline anywhere near my house.
    https://www.hotrod.com/articles/wideband-oxygen-sensor/ See table at the end of the article.
    mr.trd and TodayWasTHeDaY like this.
  18. Oct 17, 2018 at 1:41 PM
    #7378
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You will be hard pressed to find any fuels out there below E10 these days. There is a list of fuel stations on a website which lists who still carries full strength non ethanol blended fuels. The number of stations, however, is far and few in between.
    Biscuits and ls1 prerunner like this.
  19. Oct 17, 2018 at 1:54 PM
    #7379
    Roostfactor
    TX panhandle
    Got one here in Wichita Falls. 93 octane 100% gasoline. It's more expensive, like $3.60 a gallon right now.
    Biscuits, mr.trd and Norton like this.
  20. Oct 17, 2018 at 2:08 PM
    #7380
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
