TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 17, 2018 at 2:09 PM
    #7381
    ThomasMore66
    Dallas/Fort Worth & Durango
    Do you see an afr difference if you run real gas?
  2. Oct 17, 2018 at 2:41 PM
    #7382
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    No, not really.
    12TRDTacoma[OP] likes this.
  3. Oct 17, 2018 at 4:34 PM
    #7383
    ThomasMore66
    Hmm, wonder if it’s the calibration of the gauge. Or maybe it doesn’t have 10%.
  4. Oct 17, 2018 at 5:16 PM
    #7384
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Hey guys, so i installed my afr post cat so i could monitor both sides. What sort of readings should i expect at wot and normal driving? Its the trd tune and the magnuson sc. The gauge came out of a taco so id assume its calibrated right, but would like to double check!
  5. Oct 17, 2018 at 5:41 PM
    #7385
    Roostfactor
    TX panhandle
    Most likely the ecu wraf sensors are sending a signal to ECU for stoic regardless of ethanol content.
  6. Oct 17, 2018 at 5:45 PM
    #7386
    Roostfactor
    TX panhandle
    The gauge is not calibrated for a Taco but does probably require some sort of calibration.
    Mine calls for unplugging the sensors and turning ignition on for a period of time, then plugging sensors in with them in free air (not in exhaust) until gauge shows calibration is finished.
    You should see 14.7ish at idle and part throttle and the number should go lower in boost.
    BassAckwards and Biscuits like this.
  7. Oct 17, 2018 at 5:48 PM
    #7387
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Thanks for the info. I will look into what its actually doing, but that sounds about where its at.
  8. Oct 17, 2018 at 5:56 PM
    #7388
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You don't have an Innovate MTX gauge do you?
  9. Oct 17, 2018 at 7:20 PM
    #7389
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Any of you guys ever look into putting something like a Recaro type seat(s) in your truck? ....just curious.
    Biscuits and loginfailed like this.
  10. Oct 17, 2018 at 8:06 PM
    #7390
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yup. PRP seats are awesome and affordable. One day...
    Biscuits likes this.
  11. Oct 17, 2018 at 8:08 PM
    #7391
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I probably wouldn’t do Recaros, but I’d definitely like some nice power heated and cooled seats. I had Sport package leather seats in my 3 series and they were super comfy and supportive.
  12. Oct 17, 2018 at 8:32 PM
    #7392
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Got two Cobra seats in mine.
    inwood customs and rmepilot like this.
  13. Oct 17, 2018 at 8:36 PM
    #7393
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Why would EtOH have an effect on the A/F ratio?
    Recaro, Cobra, a seat out of a RAV4... Anything. For whatever reason, I find the seats in my 2014 rather uncomfortable.
    Nice!
  14. Oct 17, 2018 at 8:38 PM
    #7394
    ThomasMore66
    Dude, you have like 5,000 miles on your truck. Your seats should still be great. :duel:
  15. Oct 17, 2018 at 8:42 PM
    #7395
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol...your killin me man.
  16. Oct 17, 2018 at 9:33 PM
    #7396
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I just put heated seats in mine a week ago. Love em!
  17. Oct 17, 2018 at 9:34 PM
    #7397
    Biscuits
    We need refrigerated seats down in Texas.
  18. Oct 17, 2018 at 9:35 PM
    #7398
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Have you tried the seat risers? Mine are better on my back since adding them.
  19. Oct 17, 2018 at 9:36 PM
    #7399
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. That weather would kill me.
    Biscuits[QUOTED] likes this.
  20. Oct 17, 2018 at 9:37 PM
    #7400
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I mainly wish they could be lowered like in the 4runners. My fiancé’s 17 corolla sport we just traded in had great comfy seats that had all kinds of adjustability.
    Edit. I’m 6’1” so I don’t need seat risers
    Roostfactor and Biscuits like this.
