TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 18, 2018 at 3:00 PM
    #7421
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Oct 18, 2018 at 3:01 PM
    #7422
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looks for tiny shavings' powder, around the pulleys of the belt.
    inwood customs likes this.
  3. Oct 18, 2018 at 3:07 PM
    #7423
    ThomasMore66
    Dallas/Fort Worth & Durango
    My KO2’s let out a howl when that happens. Makes the bimmer/Benz crowd I work with get out of the way.
  4. Oct 18, 2018 at 3:57 PM
    #7424
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  5. Oct 18, 2018 at 4:01 PM
    #7425
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Mine don't howl, unless you're talking tire noise under cruise. They are not quiet.
  6. Oct 18, 2018 at 4:17 PM
    #7426
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Frankly, I don't think posting videos of your shaft play online is normal....
    But, seriously there is usually some play in the factory spring coupler. do you have the factory coupler? or have you replaced with a solid coupler?
  7. Oct 18, 2018 at 4:46 PM
    #7427
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Is this not the appropriate website to share my amateur shaft play videos :rofl:
    I still have the factory coupler. Thanks for the info.
  8. Oct 18, 2018 at 4:58 PM
    #7428
    ThomasMore66
    When they spin. When you stand on it in traffic to jump into a spot. Then maybe you smell rubber. Someone was commenting on the smell of burnt rubber. I was providing context. I do seem to spin them more with the 2.6.
  9. Oct 18, 2018 at 7:57 PM
    #7429
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Innovate DLG1. Two afr readings (1 for each bank) on one gauge.
    Biscuits likes this.
  10. Oct 18, 2018 at 8:36 PM
    #7430
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Raises the back only... Makes the position more upright instead of slouched.
  11. Oct 18, 2018 at 8:40 PM
    #7431
    inwood customs
    Dave
    Rubber on exhaust heating up?
  12. Oct 19, 2018 at 4:07 AM
    #7432
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Ah, I see, even still that would just cramp my head more towards the top.
  13. Oct 19, 2018 at 5:46 AM
    #7433
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  14. Oct 19, 2018 at 9:53 AM
    #7434
    ThomasMore66
    Still raining in Dallas
  15. Oct 19, 2018 at 10:04 AM
    #7435
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    it snowed a little yesterday
  16. Oct 19, 2018 at 10:08 AM
    #7436
    eon_blue
    Azusa, CA
    how I wish I was only paying $3.60 for premium :annoyed: Lucky to find 91 for under $4 here. But...we do have a racing gas station in town with 110 octane for nearly $10/gallon though lol
  17. Oct 19, 2018 at 11:04 AM
    #7437
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    got 93 this morning for 3.39 a gallon
  18. Oct 19, 2018 at 12:33 PM
    #7438
    Roostfactor
    TX panhandle
    I'm in Meridian, Mississippi right now. $3.10 for 93 at a Walmart here but not ethanol free.
    5thGearPinned and BassAckwards like this.
  19. Oct 19, 2018 at 12:34 PM
    #7439
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I get shell 93 (10% ethanol) in kerrville for 3.00/gal
  20. Oct 19, 2018 at 12:48 PM
    #7440
    Roostfactor
    TX panhandle
    Agreed. Looks very much like the weakest point in the tensioner arm.
    I ordered one off Amazon so I can check it out further. A bit of strengthening in that area might be a good idea.
    I'd rather fix it before a potential break then possibly have to deal with it later.
    Who knows, maybe if I figure something out others might be interested an improved version.
