TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 21, 2018 at 7:56 AM
    #7561
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Realistically we would need a decent batch to cut down on cost from the r&d part of it. No matter how many are made in the batch, machining time will not be minimal, so it will be expensive.
    I can see a cost of upwards of $200 per as realistic. But for peace of mind and not ending up with a broken tensioner on the side of the road, I would buy it for that price
  2. Oct 21, 2018 at 8:51 AM
    #7562
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    loginfailed likes this.
  3. Oct 21, 2018 at 9:18 AM
    #7563
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    exactly. Machine time will be the biggest portion of it. I was actually thinking around that price point as well tbh. but who knows..
    stairgod[QUOTED] likes this.
  4. Oct 21, 2018 at 9:46 AM
    #7564
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That will be too rich for my blood.
    rmepilot and XPOTRPR[QUOTED] like this.
  5. Oct 21, 2018 at 9:50 AM
    #7565
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Like I said, we'll see and I'll be able to save some doing the work myself.
  6. Oct 21, 2018 at 10:43 AM
    #7566
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Okay let's do this, obviously because this is a continuously ongoing thread and people are used to seeing it make it's way In the consistently posted threads I will post up an exclusive thread for a group buy so more people can see it and know about it, because posting about it in here will only gain so much notoriety.
    Only and if only @XPOTRPR is ready to proceed with a group buy and says it's okay, however.
  7. Oct 21, 2018 at 10:50 AM
    #7567
    12TRDTacoma
    Rob
    Concordia
    Boosted
    $200 too expensive for a custom made billet item? Dude the billet coolant reservoir for our trucks are like $400 and way less complex to build than this tensioner. I think $200 is actually pretty fair. Obviously cheaper would be better but considering the R&D to build this thing for a smaller niche amount of people, I think it's mostly fair.
    Biscuits and ls1 prerunner like this.
  8. Oct 21, 2018 at 10:51 AM
    #7568
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    On a different note, what’s everyone’s take on URD’s supercharger setup for the 4banger 2.7ltr??
  9. Oct 21, 2018 at 11:16 AM
    #7569
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Just a wild guesstimate on my part, keeping in mind my extremely limited machining experience, knowledge of material cost, and machining time.
  10. Oct 21, 2018 at 11:41 AM
    #7570
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I dont think we're to that point yet. I want to gather some more info about the tensioner and just get a design started. This was just to get a test of people interested I think.
  11. Oct 21, 2018 at 11:51 AM
    #7571
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I'm interested. However, and I apologize for not looking back in this thread to find the previous posts, what caused the failure of the stock tensioner in the first place?
  12. Oct 21, 2018 at 11:59 AM
    #7572
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    People using small pulleys.
    Biscuits and 12TRDTacoma[OP] like this.
  13. Oct 21, 2018 at 12:04 PM
    #7573
    Athlaos
    Leigh
    Edmonton
    How would changing the size of the drive pulley cause the tensioner to fail? I would think putting a shorter belt on or increasing belt tension would do it, but not the small pulley alone.
  14. Oct 21, 2018 at 12:07 PM
    #7574
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's exactly why, we have theorized that there is a fault in the casting process or the tensioner is hitting the stop at some point when using a belt that is of too high tension which is causing it to snap in the process since these are made of cast aluminum.
  15. Oct 21, 2018 at 1:29 PM
    #7575
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    If that’s the case shave off the stop. How many of these failures happen off road vs pavement?
  16. Oct 21, 2018 at 1:34 PM
    #7576
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    One snapped during removal and one snapped on pavement.
  17. Oct 21, 2018 at 2:06 PM
    #7577
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think you are missing the point. The point is we want to remove the potential weak points on the serpentine system so we can ensure full boost in a fully reliable fashion. Shaving the stop and calling it good is not enough peace of mind for most of us. I have personally never had an issue but I really would not like to tempt fate like that. Besides, as tight as it is in there with so many vital things right there, cooling hoses, wiring, sensors. I'd rather not play roulette with having my belt snap or jump off and cause chaos in there.
  18. Oct 21, 2018 at 3:18 PM
    #7578
    Roostfactor
    TX panhandle
    I didnt say it wouldnt be worth that price. Only that "too rich for my blood" meaning I cant afford that price.
    Biscuits and rmepilot like this.
  19. Oct 21, 2018 at 3:37 PM
    #7579
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
  20. Oct 21, 2018 at 3:59 PM
    #7580
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You can deww eett!!!!!
