TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 22, 2018 at 9:48 PM
    #7701
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I have a huge problem when I am wrenching on cars. I tend to become very tunnel visioned and I forget anything else exists. I just get do focused on what I need to get done and I forget to take any pictures or test anything. I'll try to see what I can do, though I do know the UPR tensioner uses a 40lb spring. Stock may be some 5lb's less. Maybe, nothing huge like what all the previous comments and such spoke of from comparison of the two.
    If I remember correctly I believe the Cobra uses a secondary serpentine system as well so they get all the dedicated stuff that we do.
    Roostfactor[QUOTED] likes this.
  2. Oct 22, 2018 at 9:53 PM
    #7702
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  3. Oct 22, 2018 at 9:58 PM
    #7703
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Understood. I can be that way too.
    A little stiffer I think would be perfect but if you as the pioneer of this case get some data it would be awesome!
  4. Oct 22, 2018 at 10:00 PM
    #7704
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Did I hear group buy?
  5. Oct 22, 2018 at 10:02 PM
    #7705
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thats what she said :anonymous:
  6. Oct 22, 2018 at 10:04 PM
    #7706
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You would think stiffer would not be better but I can still take my belt and "indent it" downward with my hand without tons of effort so I think the extra pressure could definitely be useful. :D
    No you did not. Not yet. I do not want any group buys until I get some hard data and facts on this install. I want to know the ins and outs and what may or may not need modifications prior to mounting it on even if that includes shimming the tensioner out further for whatever reason. Too many variables to say group buy just yet. Though anyone is free and welcome to pick up any one of the tensioners listed if they'd like!
  7. Oct 22, 2018 at 10:06 PM
    #7707
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just being a wise guy:thumbsup:
  8. Oct 22, 2018 at 10:06 PM
    #7708
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Instigator. Lol.
    mr.trd and rmepilot like this.
  9. Oct 22, 2018 at 10:08 PM
    #7709
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oddly enough, there are other products made for our tensioners which would not work, but are meant to address strength issues on these tensioners. Metco released a strengthening brace for them long ago which you can still pick up, but due to the way our tensioner is oriented and requires a bracket to run it on our trucks we cannot run it due to physical interferences.
    So there are known issues with these things, it's just issues that we were not aware of prior due to our community being a little more underground than Terminators and Lightning's.
    Biscuits, rmepilot and Roostfactor like this.
  10. Oct 22, 2018 at 10:12 PM
    #7710
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Pretty good explanation of the problem and the case for a better tensioner here:
    https://www.cjponyparts.com/steeda-...with-90mm-billet-pulley-gt-2005-2010/p/TEN13/
  11. Oct 22, 2018 at 10:17 PM
    #7711
    12TRDTacoma
    Rob
    Concordia
    Boosted
    However, we don't suffer from bent brackets because what we have holding our tensioner base is pretty stout, so qe got lucky there. Unfortunately all the stress goes to the actual arm itself. I even read cases of a guy breaking the OE tensioner arm at the very end by the pulley because he didn't put the ratchet all the way in.
    I believe it all at this point. Lol.
  12. Oct 22, 2018 at 10:17 PM
    #7712
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Steeda looks like a normal tensioner, just with a billet plate welded to the front of it.
    12TRDTacoma[OP] likes this.
  13. Oct 22, 2018 at 10:20 PM
    #7713
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah that's exactly what it is. Which is why I recommend people go for the UPR or the other overly expensive option. To me if I'm going to pay over $150 for a tensioner I might as well go with the one which is a fully fabricated unit.
    JacksonTacoma and rmepilot like this.
  14. Oct 22, 2018 at 10:21 PM
    #7714
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, the UPR is only $30 more. Kind of a no-brainer.
    rmepilot and 12TRDTacoma[OP] like this.
  15. Oct 22, 2018 at 10:25 PM
    #7715
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I’m just trying to compare apples to apples here with the 1gr-fe. But yeah, obviously AC Delco makes them for many applications too. Yes, I agree boosted 4.6 and coyote mustangs definitely would have higher percentages of breaks based on the fact these base PD kits already start at 10 lbs boost. And pulling easily over 500rwhp. With that kind of power stronger made tensioners are a must especially for belt slippage.
  16. Oct 22, 2018 at 10:25 PM
    #7716
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Wow.
  17. Oct 22, 2018 at 10:25 PM
    #7717
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  18. Oct 22, 2018 at 10:29 PM
    #7718
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You beat me to it. Lol. I was just about to post the top pic.
    We will have zero problems with it.
    The only thing that worried me was someone mentioned the Allen bolt holding the arm in place started backing out. (Back in 2015, but kinda recent) he stated UPR knew about it but who knows if they addressed it. He said he ended up using a bolt with a locking nut or something like that to stop it from backing out because nothing else was working. That is what worries me most right now. Otherwise he said it has been a great unit.
  19. Oct 22, 2018 at 10:31 PM
    #7719
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Roush looks similar to stock, but it's definitely beefier, look how much thicker the arm is.
  20. Oct 22, 2018 at 10:41 PM
    #7720
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That is true, but with that being said they are also running Whipples and M112's which do not require as much speed turning the rotors hence the blower pulley can be larger in order to produce that same 10 PSI that we need to step down large amounts of pulley diameters just to achieve. It's all pretty relative here.
    Nice. I never looked too deeply into the Rousch. They did also say that the internal spring was heavier duty over the OE arm. Might be worth something to the guys who don't mind sporting the word Rousch. Or they can just grind the words off. Either way, either way.
