TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 23, 2018 at 7:31 PM
    #7761
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You want it to close as much as possible without binding. The factory adjustment usually leaves a little room to adjust to the "closed" position.
    This allows for less boost leakage back to the inlet.
    12TRDTacoma[OP] likes this.
  2. Oct 23, 2018 at 7:33 PM
    #7762
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    No they do not unless you adjust them, so in all actuality when you are in boost you are actually allowing some to bleed past the bypass valve. By fully adjusting it to close you will actually pick up a few points leaner in your AFR.
    There is a small Allen head bolt which the valve stops on when you are in boost. You have to adjust it out until you can hear a slight tink from the valve hitting the blower casing. Too much adjustment out and the butterfly will bind and eventually wear out the blade.
    TodayWasTHeDaY and TRON[QUOTED] like this.
  3. Oct 23, 2018 at 7:38 PM
    #7763
    Roostfactor
    TX panhandle
    The adjustment is the small allen head facing up here with locktite on it. It normally faces down.
    You can turn it counterclockwise while quickly letting the actuator snap shut to check for binding.
    Once you feel the butterfly just start to bind in the closed position, adjust clockwise just until the binding goes away.
    That is as close to sealed the bypass will be without binding.
    mr.trd, BassAckwards, Athlaos and 4 others like this.
  4. Oct 23, 2018 at 7:49 PM
    #7764
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    That is a total suckpocalypse.
    I think I will give the Steeda one a try. Since I removed the stock radiator and shroud, it will fit no problem. I can't tell exactly if it has a stiffer spring than stock, though.
    Did the UPR guy say it was discontinued due to some design flaw? Like even if mustangsunlimited has one they can send, should I still get something else?
    Biscuits likes this.
  5. Oct 23, 2018 at 7:54 PM
    #7765
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’ve never solved this problem. Not sure it’s always the driveshaft.
    loginfailed[QUOTED] likes this.
  6. Oct 23, 2018 at 7:59 PM
    #7766
    ThomasMore66
    There’s an adjustment...mind blown. How do you reach it?
    Athlaos likes this.
  7. Oct 23, 2018 at 8:02 PM
    #7767
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Funny enough that is exactly where my Allen stop ended up without allowing the butterfly to bind. Dead on where yours is. Things have been so much better with it just about fully sealed now.
    I got lucky and found a used Thump for sale, which I picked up very quickly for obvious reasons. The UPR rep did not know any info as to why they have stopped making it until indefinite at this moment, but you will have trouble finding a store which has one readily available. No one one has a UPR on hand ready to ship. You may have to settle for one of those $400+ tensioners. As stupid as it sounds, lol. There is a company called ARS which makes an absolutely gorgeous billet unit of it but it costs bank as well.
    The alternative is Roush. The only downside is you will have those big words on the tensioner itself, and we are not Roush, so.. grinder to remove the letters it is. :D
    With really small fingers and a king fu ninja grip of death on the Allen key.
  8. Oct 23, 2018 at 8:21 PM
    #7768
    Athlaos
    Leigh
    Edmonton
    No comment on Steeda? The price is right for us Canadians who are still waiting for the US economy to implode and the exchange rate to improve.
    TodayWasTHeDaY likes this.
  9. Oct 23, 2018 at 8:25 PM
    #7769
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you want stronger than stock Steeda is the way to go, as it has a billet reinforcement piece welded onto it, at the end of the day however it is mostly still cast aluminum, it is no stronger in any other way than stock other than that and will offer nothing over what we currently have. Roush may be the best way to go because I am under the impression that they internally rehaul the spring as well with a more HD unit. I am not saying Steeda is bad, as it is the most readily available option and as of current the best bang for buck over the rest of them, but the Roush is a completely retailed unit, though still completely cast aluminum. Much beefier than stock, however.
    Athlaos[QUOTED] likes this.
  10. Oct 23, 2018 at 8:27 PM
    #7770
    Athlaos
    Leigh
    Edmonton
    Sounds good, I appreciate you doing the research on this for me. I'm sure a sticker will do just fine to cover up the Roush lettering.
  11. Oct 23, 2018 at 8:35 PM
    #7771
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dremel or grinder to the letters. To remove them. Abrasive wheel across the entire surface of the tensioner front to shine it all up and remove all the ugly left over from the grinding.
    For max bling and bragging rights factor, Thump or ARS. Have you some deep pockets ready, however, but at least they are available.
  12. Oct 23, 2018 at 8:59 PM
    #7772
    Athlaos
    Leigh
    Edmonton
    I have just heard about this adjustment as well. I imagine the faster your rotors are going (more boost), the more difference it would make. I'll be changing the supercharger needle bearings soon, so I'll have to do this adjustment when the manifold is off.
  13. Oct 23, 2018 at 9:41 PM
    #7773
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I did it with the blower on, but it was incredibly tough to adjust like that with such limited space available.
  14. Oct 23, 2018 at 10:11 PM
    #7774
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  15. Oct 23, 2018 at 10:14 PM
    #7775
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hahahahaha!!!!!
    When your professional trade description is the label technician, you find a way where there is a will.
  16. Oct 24, 2018 at 12:13 AM
    #7776
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I'd be interested to know this as well just in case.
    mr.trd and loginfailed[QUOTED] like this.
  17. Oct 24, 2018 at 5:28 AM
    #7777
    ThomasMore66
    What I don’t get is for some of this condition starts over time. Something gets worn, settles, etc.
    loginfailed likes this.
  18. Oct 24, 2018 at 7:23 AM
    #7778
    Athlaos
    Leigh
    Edmonton
    Are you sure about that... because if the air is bleeding past the valve, it’s already been metered by the MAF, so AFR won’t be affected, just the overall flow rate into the manifold.
  19. Oct 24, 2018 at 7:25 AM
    #7779
    Athlaos
    Leigh
    Edmonton
    Oh wait. Open loop. Right.
  20. Oct 24, 2018 at 7:29 AM
    #7780
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep. I picked up I believe it was .3 lean points above what I was at on WOT runs for overall AFR after I adjusted it.
    On that note vroom vroom this morning. I'm never putting my jet back in even for testing purposes. I forgot how much more stable and responsive things are without it! :D
