TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 24, 2018 at 12:27 PM
    #7801
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You can physically feel the valve bind when you have went to far. Back it out just a hair and you'll hear the tink. Good to go. Call it a day and it's all done and sealing better.
    Roostfactor likes this.
  2. Oct 24, 2018 at 12:32 PM
    #7802
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm super excited to try this out!
    loginfailed and Roostfactor like this.
  3. Oct 24, 2018 at 1:37 PM
    #7803
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Might be something to look into when changing plugs...
  4. Oct 24, 2018 at 2:06 PM
    #7804
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just got off the phone with Tom Woods. My one piece will be here early next week. Not planning to regear so according to @ItalynStylion the one piece should be the ticket. I'll have to cut the cross member, but I'll save the part I cut off in case I need to weld it back on later.
  5. Oct 24, 2018 at 2:10 PM
    #7805
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Any info on what the problem is if you regear? I know someone mentioned that it will be spinning too fast, but what kind of damage can that cause?
    loginfailed[QUOTED] likes this.
  6. Oct 24, 2018 at 2:11 PM
    #7806
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    How does regearing change anything with what type of driveshaft you have?
  7. Oct 24, 2018 at 2:12 PM
    #7807
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    https://www.tacomaworld.com/threads/single-piece-driveshaft-vibes-be-gone.475797/
    Basically when you regear the shaft has to spin a lot faster at which point it reaches its "critical speed". He talks about it in the thread above.
    BassAckwards[QUOTED] likes this.
  8. Oct 24, 2018 at 2:14 PM
    #7808
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  9. Oct 24, 2018 at 2:15 PM
    #7809
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The stock 2 piece has a much higher critical speed than a single piece.
    12TRDTacoma[OP] likes this.
  10. Oct 24, 2018 at 2:16 PM
    #7810
    BassAckwards
  11. Oct 24, 2018 at 2:18 PM
    #7811
    12TRDTacoma
    Rob
    Concordia
    Boosted
    X2
    A 2 piece driveshaft will always have a higher maximum speed in comparison to a one piece DS.
    For those who own DCLB's I would highly advise against a one piece.
  12. Oct 24, 2018 at 2:32 PM
    #7812
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Just seems strange to me I guess. I would think having more joints/ angles to deal with would be worse at higher rotating speeds. More chances for things to be unbalanced/ bind up. But then you also have smaller individual sections that need balancing which would be easier than one big piece that would be harder to evenly balance perfectly.
    Anyways while on the topic. I recently changed my carrier bearing to a timken one. Kinda a mix between the oem and the full hard mount eids one as it is encased in a mostly solid hard rubber giving it minimal slop. I am happy with it so far. No vibes and it feels much more solid. I didn't think I would feel a difference, but getting rid of all the slop in the oem cb is noticeable. But boy have I drug my driveshaft across some shit. I'm almost scared that there's minimal slop because I'm sure the slop from oem allowed the ds to just deflect itself out of the way instead of being solid and bending.
  13. Oct 24, 2018 at 2:33 PM
    #7813
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Long bed might be able to pull off a one piece if the diameter is increased.
    But I'm all for a 2 piece, though. The plan is to use the Tom Woods and have the stock one modded like this:
    https://www.tacomaworld.com/threads...om-double-cardan-driveshaft-installed.560063/
    mr.trd likes this.
  14. Oct 24, 2018 at 2:34 PM
    #7814
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The above assertions are correct. To give you a mental image, you have a long shaft (might as well get your giggles out now) that is strong enough to support its own weight. However, it does flex to an extent. The longer it is, the more flex you will get. Kinda like how a ruler appears to have no flex but a yard stick kinda flaps around if you move it quickly. At some point, a single piece shaft will start acting like a jump rope and that point is defined as its critical speed. This is where harmonics start to take hold and the shaft will literally tear itself apart as it spins faster and faster.
    But if you can imagine cutting the length of that shaft in half by adding a support bearing, it can't move around in the middle and effectively makes it two smaller shafts. A shaft like that can spin much faster.
    How does that relate to regearing? Well the point of a regear is to have the drive shaft spin faster per revolution of the wheel. With an aggressive regear, you'll have the shaft spinning quite quickly and if you're using a single piece shaft, that could be quicker than its critical speed.
  15. Oct 24, 2018 at 2:35 PM
    #7815
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Confirmed from Magnuson themselves, the Tacoma supercharger tensioner uses a 3.0" idler pulley. Translates to 76mm. We can and will be able to use the HD double bearing pulley that is an optional (or sometimes standard) add on for some of these billet tensioners. :thumbsup:
  16. Oct 24, 2018 at 2:37 PM
    #7816
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Good explanation. I was hoping you'd chime in, since you've been through this at great length already.
  17. Oct 24, 2018 at 2:37 PM
    #7817
    BassAckwards
    If you get a double cardan joint added to the driveshaft, if the ujoints ever go out on that, do you have to take the ds to a shop to have them replaced, or can you drop it and do it yourself like with the stock shaft?
    I feel like i remember reading somewhere that you cant change them yourself with the double cardan
  18. Oct 24, 2018 at 2:40 PM
    #7818
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If we can talk seats in here, then driveshafts are fair game :D
  19. Oct 24, 2018 at 2:40 PM
    #7819
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You have done a great deal of research and have proven already that running a one piece over a two piece the longer it gets is just a bad idea waiting to tear apart. (Quite literally)I have never been on board with an overly long one piece driveshaft, especially for a truck because of the potential harmonic/ vibration issues that presented themselves if the angles were off even just a bit, but your research over the past few years only further solidified my original theory as to why I wasn't on board with that ideal.
  20. Oct 24, 2018 at 2:41 PM
    #7820
    ThomasMore66
    Dallas/Fort Worth & Durango
    It's just pouring rain in Dallas at the moment. Not a good boost day.
