TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 24, 2018 at 2:42 PM
    #7821
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Good question, I haven't looked at it to see how replacements go. I can tell you I have about 30k miles on mine so far and it's great. Keep in mind that 1st gen Tacomas came with the double cardan shaft from the factory. Few people know this. Either way, getting ujoints replaced is cheap. Even cheaper is just keeping them greased!
  2. Oct 24, 2018 at 2:43 PM
    #7822
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Got a little extra money. Think meth is getting ordered soon
  3. Oct 24, 2018 at 2:44 PM
    #7823
    ThomasMore66
    Dallas/Fort Worth & Durango
    Every once in a while I go to the new 2nd gen threads just to see what's happening. Nothing, that's what's happening. This thread is the life of TW.
  4. Oct 24, 2018 at 2:46 PM
    #7824
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    You ever been to the 3rd gen threads. It's scary in there lol
  5. Oct 24, 2018 at 2:48 PM
    #7825
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The longer the shaft.. the greater the run-out (vibes)
    @snowsk8air2 look into having the DS re-tubed. Had to have mine done.. again.. a month or so ago. Soooooo much better. Back to smooth. Especially when paired with my IEDLS CB.
    Biscuits likes this.
  6. Oct 24, 2018 at 2:50 PM
    #7826
    ThomasMore66
    Yeah, I got a warning from the mods one time and decided I should stay out of there. It was just too easy to poke the tiger and sit back and watch them devour each other. They're like a fire ant mound. There might have been alcohol involved.
  7. Oct 24, 2018 at 2:50 PM
    #7827
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Haha I drop in there every once in a while just to gauge how much of a shit show it is. There are always threads that don't disappoint
    Biscuits, Roostfactor and loginfailed like this.
  8. Oct 24, 2018 at 2:54 PM
    #7828
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Mines not bad right now. Got a little dent in it and a lot of missing paint. I have no vibes since going sua. But I'm sure another crawling trip or two and I'll bend it enough to need replacing or repair. Where did you have yours done?
  9. Oct 24, 2018 at 3:00 PM
    #7829
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    mine was definitely sand blasted too. :rofl:
    I had a few gouges and dents in it.. so it needed it. I use Az driveshaft and differential down here in Phx. Mesa technically.
    snowsk8air2[QUOTED] likes this.
  10. Oct 24, 2018 at 4:26 PM
    #7830
    ThomasMore66
    Onward through the fog.
  11. Oct 24, 2018 at 4:34 PM
    #7831
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    If you can talk shafts, then can I inquire about lubrication? Anyone know if there is an externally accessible port that I can use to prime my oiling system on my engine swap project? Some folks will use a garden sprayer to generate pressure and distribute a couple quarts of oil into the engine. I'm trying to figure out if the port under the oil filter is on the supply side to the engine, or if I should pull the oil pressure sender next to the filter? Any direction would be appreciated.
    Biscuits and loginfailed[QUOTED] like this.
  12. Oct 24, 2018 at 5:23 PM
    #7832
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    @Torspd?
    Torspd likes this.
  13. Oct 24, 2018 at 5:24 PM
    #7833
    Roostfactor
    TX panhandle
    And this was one of the reasons I turned down the job in Fort Worth.
  14. Oct 24, 2018 at 5:28 PM
    #7834
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Is the adjustment of the bypass gonna be added to page 1?
    BassAckwards and 12TRDTacoma[OP] like this.
  15. Oct 24, 2018 at 5:32 PM
    #7835
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yes it will. Eventually. Lol.
    Skootter14 likes this.
  16. Oct 24, 2018 at 5:33 PM
    #7836
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is where I have my oil pressure sensor. 1/2" NPT plug. You could do it there.
    For me, after everything is assembly lubed, I just pull the fuel pump relay, and crank the engine until the oil light turns off. That equates to 20 psi.
    ^^^ That was the method prior to the oil pressure gauge.
  17. Oct 24, 2018 at 5:45 PM
    #7837
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Duuuuuuuude! That picture reminded me of the fun on the clovers .... Good times .
  18. Oct 24, 2018 at 5:52 PM
    #7838
    DocME
    California
    '07 FJ Cruiser
    Thanks! I lubed up the valve train/cams with Amsoil assembly lube when I installed the UCON timing gears, but it doesn't seem to stick around like some of them. I'm ultimately concerned with the rod bearings being dry as the engine has set for 6 months. I will crank as suggested. Hoping to bring this thing back together in the next couple weeks, I hear its boost season again.
  19. Oct 24, 2018 at 6:05 PM
    #7839
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Clevite or Redline assembly lubes, for future reference. :thumbsup:
    DocME and Roostfactor like this.
  20. Oct 24, 2018 at 6:25 PM
    #7840
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I’m sure you can weld it yourself if you do it the simple way. I did a pair a few years back. I bolted the flange that bolts to the head to my work bench and made a jig to bolt the stock header exhaust flange in its stock location. Cut the cats off the oem header, unbolt oem header from bench (while leaving oem cat bolted to jig), slide new header into jig and bolt to table, weld, and install. Doesn’t get any more fool proof than that. Unless you have access to a loft and regularly perform that kind of exhaust work I would avoid doing it on the vehicle even if that means paying a professional
