TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 25, 2018 at 5:26 PM
    #8001
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Found my bypass valve adjustment. Couldn't hold the yoga pose long enough in the rain to care today. It is hitting the stop only telling me it's most likely not adjusted to my benefit. To be continued......
    Roostfactor likes this.
  2. Oct 25, 2018 at 5:28 PM
    #8002
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Lean is correct. Drops off wayyy lean..
  3. Oct 25, 2018 at 5:30 PM
    #8003
    BassAckwards
    If i can somehow manage to find a used one, and i mailed it to you, would you be willing to flash it for me? I can pay postage both ways of course, and whatever you feel is a fair price to reflash it
  4. Oct 25, 2018 at 5:31 PM
    #8004
    BassAckwards
    This is 100% correct
    Biscuits[QUOTED] likes this.
  5. Oct 25, 2018 at 5:31 PM
    #8005
    BassAckwards
    Haha.. im already paranoid about blowing up my motor! Idk if that would help my situation :D
    The last few miles of it's life might be a good time though:burnrubber:
    Athlaos[QUOTED] and XPOTRPR like this.
  6. Oct 25, 2018 at 5:32 PM
    #8006
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    pretty much this. If I was registered out of the city.. or had a historic plate like my 86.. I wouldnt have to deal with this.
  7. Oct 25, 2018 at 5:33 PM
    #8007
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I can double check tomorrow at work. I tried to save a trd file and it won’t save.
    Ya if you send me the ecu I can plug it into my truck and reflash with the trd tune and send it back. I don’t think there will be any problems with that.
  8. Oct 25, 2018 at 5:33 PM
    #8008
    BassAckwards
    I want to try to do this, but now i gotta track down a unicorn of an ecu since my trucks a 6spd 4wd.. will likely post in the for sale section soon to see if anyone has one though or start scouring the pick and pulls
    richiep and loginfailed like this.
  9. Oct 25, 2018 at 5:36 PM
    #8009
    BassAckwards
    This would be superb! I need to track down an ECU now..
  10. Oct 25, 2018 at 5:36 PM
    #8010
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    are you able to swap with anyone? I know 2 local guys with 6spd 4wd's..
  11. Oct 25, 2018 at 5:39 PM
    #8011
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ebay
    Norton and 12TRDTacoma[OP] like this.
  12. Oct 25, 2018 at 5:40 PM
    #8012
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. I went to craigslist. Found a super cool dude. He let me do most of the work. It worked out great for me.
  13. Oct 25, 2018 at 5:41 PM
    #8013
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Goes up way down there! LOL
  14. Oct 25, 2018 at 5:41 PM
    #8014
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The engineers design the system but who knows what minimum wage worker is doing the factory adjustment.
    There is possibly a minimal amount of break in where the set screw meets the stop but very little if any. It might set more if restrictor jet removed due to hitting the stop harder.
    There will also possibly be small changes in clearances due to temperature variations but you would know if it every bonded closed as you would always have boost. That would be bad.
    You dont want any air being bypassed through there when closed. That is just a loss of efficiency.
    Roost
  15. Oct 25, 2018 at 5:42 PM
    #8015
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    nice. good idea.. I'll check CL.
  16. Oct 25, 2018 at 5:42 PM
    #8016
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This is a good baseline starting point. Find a zero point ECU, if you can get that potentially @o0opackersfano0o can get his hands on the TRD flash file and do a reflash on the bench. If he can all you do is pay for shipping to and from, and possibly buy him a beer, or lunch or something and you're back in business! Excited for the possibilities of getting you back straight here @rjbiii!
  17. Oct 25, 2018 at 5:47 PM
    #8017
    BassAckwards
    I do know of one individual in my area (like 75 miles from me) with a 6spd 4wd. Might have to talk him into swapping with me to see if there is any difference.. :thumbsup:
  18. Oct 25, 2018 at 5:49 PM
    #8018
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you find yourself in Houston, I can also flash your truck. Provided the flash is still on TIS. I have a Mongoose cable.
  19. Oct 25, 2018 at 5:49 PM
    #8019
    BassAckwards
    Exactly! I knew you'd understand :D
  20. Oct 25, 2018 at 5:51 PM
    #8020
    Roostfactor
    TX panhandle
    I think I'm around 75 idc with the 61lb injectors and no 7th or meth.
    The larger the injector, the harder it is to control precise afr at idle. Think about trying to get a nice atomizing spray with a huge nozzle only open 1% of its duty cycle vs a smaller nozzle open 5% of the time at idle.
