TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 25, 2018 at 8:00 PM
    #8061
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Hey @White lightning boosted 8 seperate slots cut across the pulley on the 2.5.
    I took a tailor's tape on mine measured around the ribbing diameter of the whole pulley at the time and then divided that into 8 sections, after I determined what the distance between each slot would be I marked each area to be cut with a Sharpie to see if it would be close enough, it was so I made my cuts and the rest was history. 8 may not be enough for you though so try and take your rib measurements and divide that by 10 or 12 and see what you get for spacing if using a 2.8.
    Athlaos likes this.
  2. Oct 25, 2018 at 8:02 PM
    #8062
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm a geometric whiz at work. That's no problem. How deep are they? 1/8"?
  3. Oct 25, 2018 at 8:02 PM
    #8063
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I have the fake trd pro one
  4. Oct 25, 2018 at 8:03 PM
    #8064
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I took them down to what would be close to the base of the grooves to ensure full contact with the deepest interior grooves of the belt.
  5. Oct 25, 2018 at 8:04 PM
    #8065
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I've compared our not so oem grilles to oem side by side. I cant tell a difference.
    BassAckwards[QUOTED] likes this.
  6. Oct 25, 2018 at 8:05 PM
    #8066
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I wish you lived close to me @rjbiii. We would figure out your lean spots of death real quick-like.
    I was under the impression fuel was already checked and out of the picture. If you have access to a fuel pressure gauge you could T tal into the fuel line connection points by the fender
  7. Oct 25, 2018 at 8:05 PM
    #8067
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Perfect. Every 30* I'll notch.
  8. Oct 25, 2018 at 8:06 PM
    #8068
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @12TRDTacoma
    Shouldn't we trust Gadget to have tested his computer correctly when he sent it back to them? And maybe not jump to that conclusion immediately? I think putting a different Toyota ECU in and seeing what happens is a good way to rule that out, but I think it's pretty unlikely at this point that it's a bad UCON...
    I remember a serious problem I had on my car, we were sure it was the engine computer because we felt we had ruled everything else out. We swapped computers and the problem was still there. It just ended up being a more unusual and difficult to diagnose mechanical issue (not the same issue as here, just using this as an example). My lesson from that was the computer is a very unlikely thing to be wrong (especially a brand new after-market thing like a UCON - which has even been tested post-installation by the company that manufactured it!!)
  9. Oct 25, 2018 at 8:08 PM
    #8069
    BassAckwards
    Thats good news for us!
    Did you get yours during the group buy?
  10. Oct 25, 2018 at 8:12 PM
    #8070
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Bummer, see if anyone on xru has a 2012+ with the urd intake.
    I guess since gadget made the urd intake so long ago, it was soley based on the pre facelift. Well, actually we know it was..... But look around on xru, maybe there's a few other stories like yours.
    Good luck... I loved that intake until it rained and I got water on the maf wire... Not fun merging.
  11. Oct 25, 2018 at 8:13 PM
    #8071
    BassAckwards
    I think the ucon is good, when my ucon went back for testing, i talked with gadget a few different times on the phone and walked him through when the problems were occuring so he could try to replicate it. i think my ecu just doesnt want to play nice for some reason.. im going to try and find a ecu and test with that and see what happens
  12. Oct 25, 2018 at 8:15 PM
    #8072
    Athlaos
    Leigh
    Edmonton
    Based on what I've read, I don't think we should say we've ruled out the fueling issue. What about bad pump? What about fuel pressure regulator?
    We haven't ruled out vacuum leak either, however I seriously doubt that's what it is based on the symptoms.
  13. Oct 25, 2018 at 8:16 PM
    #8073
    Athlaos
    Leigh
    Edmonton
    I agree, I think UCON being bad is really unlikely. Trying a different toyota ECU is a good idea.
  14. Oct 25, 2018 at 8:17 PM
    #8074
    BassAckwards
    Will definitely do that. Thanks, Yeah great intake, but definitely isnt perfect
    Did your truck sputter on you?
  15. Oct 25, 2018 at 8:17 PM
    #8075
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes I did. Have two stock originals now. One brand new. Need to sell it or something.
  16. Oct 25, 2018 at 8:18 PM
    #8076
    Athlaos
    Leigh
    Edmonton
    What I don't understand is why I haven't had any issues of the magnitude that you guys have. My only issue has been belt slip... and that's pretty easy to fix.
    BassAckwards likes this.
  17. Oct 25, 2018 at 8:23 PM
    #8077
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    FWIW I got a TRD tune back in March of this year after installing my own SC. The TRD tune is available nationwide, you just need the SC calibration ID number for your truck out of the back of the TRD instructions. I went to two dealers who had never done a TRD SC flash and they were able to find the SC calibration ID I gave them. The tech who did my ECU flash said it's the same process as any common ECU update as long as you know the calibration ID.
  18. Oct 25, 2018 at 8:26 PM
    #8078
    ThomasMore66
    Dallas/Fort Worth & Durango
    We’ve been seriously active here today. Wow. @JuanitoBunito is way behind.
  19. Oct 25, 2018 at 8:28 PM
    #8079
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    No kidding, I sat down for dinner, next thing I know there's 5 pages to catch up on
  20. Oct 25, 2018 at 8:29 PM
    #8080
    ThomasMore66
    Wife gets mad when I start ignoring her for you guys. Had to catch up myself.
