TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 26, 2018 at 11:12 AM
    #8161
    ThomasMore66
    Dallas/Fort Worth & Durango
    Whoa! I thought OV was going to be the answer.
  2. Oct 26, 2018 at 11:12 AM
    #8162
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    As far as OV, I think @loginfailed asked about custom tunes with larger injectors and there is a limit within the ECU tables regarding injector size. I believe the UCON gets around this as a piggyback tricking the ECU into what its seeing. Don't quote me on that.
    loginfailed and 12TRDTacoma[OP] like this.
  3. Oct 26, 2018 at 11:15 AM
    #8163
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I think it has the potential of being the best option for custom tunes, once its prioritized. We've had just one base Supercharger tune that is definitely not customized. Unfortunately the timeline isn't promising.
  4. Oct 26, 2018 at 11:26 AM
    #8164
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Yup, the maf sensor bung interferes with the harness doesn't it?
    U plug in the sensor and then it won't sit flush when u put the screws in.... Or you screw down the maf sensor first, and then plug the connector in and it only fits about 7/10 of the way and doesn't click into place right?
    You most likely have a whistle at part throttle too
  5. Oct 26, 2018 at 11:42 AM
    #8165
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It connects fine. I was wondering if it's a seal issue where the sensor connects to the pipe. Maybe I'll glue it in with rtv
  6. Oct 26, 2018 at 11:50 AM
    #8166
    ThomasMore66
    I thought so too. Just doesn’t appear to be going anywhere.
    12TRDTacoma[OP] and Norton like this.
  7. Oct 26, 2018 at 11:58 AM
    #8167
    inwood customs
    Dave
    That was gadgets suggestion to me... My fix was to sell it, no way I'm dealing with rtv every two years for emissions.
    U could try a gasket from afe... Tell them u have the stage 2 si, and need the maf sensor gasket. I have 4 in my toolbox as backup. Pretty sure they were stupid cheap.
  8. Oct 26, 2018 at 12:13 PM
    #8168
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Anyone know of a reputable shop that can reflow injectors? Revisiting the idea of resizing the flow for the stock N/A injectors up to the 61 lb range. Might be cheaper and eliminate the need for harnesses.
  9. Oct 26, 2018 at 12:43 PM
    #8169
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Matt told me it will be possible to run larger injectors with the factory ECU, but just “not yet”.
    I’d love to try running a tuneable stock ECU and no UCON, but that’s not obtainable right now. My UCON is working really well, so I will just watch the OVTune developments from a distance.
  10. Oct 26, 2018 at 12:45 PM
    #8170
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Ebay sells injectors that have been reflowed. Denso brand at that.
  11. Oct 26, 2018 at 12:46 PM
    #8171
    Droptopfox
    Droptopfox Works at Tinkers’ Nook
    Jermaine
    AZ
    2008 TRD Sport DCLB 4x4
    I used WitchHunter Performance with my old WRX. Very well known company in the Subaru community. I'm not sure if they would mod ours though...
  12. Oct 26, 2018 at 1:27 PM
    #8172
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Plug n play for the 4.0 1gr-fe? Got a link?...I'm only finding OEM for Denso
  13. Oct 26, 2018 at 1:38 PM
    #8173
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They are not difficult to find at all. Toyota uses the same plugs on a multitude of cars, so connector style and even length of injector body will be the same. Look for 6 that have been reflowed to whatever your CC choosing.
  14. Oct 26, 2018 at 1:50 PM
    #8174
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    You say plug n play, but if you're changing flow rates, you need a tune. I'll have some factory orange TRD's available shortly if some wants them to reflow or whatever.
    inwood customs and Norton like this.
  15. Oct 26, 2018 at 1:51 PM
    #8175
    ThomasMore66
    So, Ultragauge says 11.4 mpg for the 30 mile drive home...might have exercised the 2.6” on the way... kinda amazing how well it runs.
    Roostfactor, rmepilot and Athlaos like this.
  16. Oct 26, 2018 at 1:52 PM
    #8176
    12TRDTacoma
    Rob
    Concordia
    Boosted
    When he says plug and play he means fully plug in and ready to operate, no special adapters plugs, or physical injector modifications needed to make fit into the fuel rail and engine.
    JacksonTacoma likes this.
  17. Oct 26, 2018 at 1:53 PM
    #8177
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ouch. 3 gallons in 30 miles. That's painful, but it's all about the smiles per gallon right?!
    What did yo uh do to the truck recently, if anything at all that makes you say it's amazing how well it runs?
    rmepilot, XPOTRPR and Athlaos like this.
  18. Oct 26, 2018 at 2:06 PM
    #8178
    ThomasMore66
    2.
    2.6”, DT shorties, vibrant cats, @Roostfactor wrap kit. Dodge Ram be gone. You’re not even in the game.
  19. Oct 26, 2018 at 2:47 PM
    #8179
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Unnamed autoparts store has no record of that maf # you posted. Maybe I should go somewhere else. That part # comes up as a fluid resivoir:/
  20. Oct 26, 2018 at 3:13 PM
    #8180
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I went BD, due to warranty needs.
    No issues after 2 years, but still running stock otherwise. In a few months, we’ll see what happens...
