TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 27, 2018 at 9:45 AM
    #8241
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    It’s a good point,
    @White lightning boosted
    Don’t cancel your order yet. Since @12TRDTacoma was just there putting his tensioner on, he has a better idea of how it should fit.
  2. Oct 27, 2018 at 9:46 AM
    #8242
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I may. I need to slow it down on the mods though. I've spent about 1k a month for the past few months.
  3. Oct 27, 2018 at 9:48 AM
    #8243
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Another footnote, the Steeda should not require additional spacing of the idler pulley, as the base of the unit is still stock thickness, unlike mine which was 1/8" thicker overall since the Thump unit is a fully designed billet piece.
    As always, check for proper spacing before running the setup. Mount the new unit and eyeball the lineup of the crank pulley and tensioner idler pulley. We are crossing into custom territory here and proper fitment is never guaranteed.
  4. Oct 27, 2018 at 9:49 AM
    #8244
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    When you get to $1k/month for 24 months is when you need to start thinking about seeing someone to talk about your problem. So I’d say you’re good. :D
  5. Oct 27, 2018 at 9:50 AM
    #8245
    Athlaos
    Leigh
    Edmonton
    I was just thinking that’s probably where I am. The first step is acknowledging that you have a problem. Or something.
  6. Oct 27, 2018 at 9:51 AM
    #8246
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I've had my truck since xmas. Mod budget exceeds rent and grocery expenditures.:bananadead:
  7. Oct 27, 2018 at 9:52 AM
    #8247
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I didn’t add it up, but I can estimate and it’s probably more than that.
    :anonymous:
  8. Oct 27, 2018 at 9:53 AM
    #8248
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It's like calculating my former beer budget. Some math is best not known.
    mr.trd, stairgod, Biscuits and 4 others like this.
  9. Oct 27, 2018 at 9:55 AM
    #8249
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Is it wrong that I work as a dealer tech, but still go to Discount Tire to get tires fixed?
  10. Oct 27, 2018 at 10:01 AM
    #8250
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Nope. Is it wrong that stores dont stock maf sensors, yes.
  11. Oct 27, 2018 at 10:03 AM
    #8251
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    But I bet they have a fully stocked shelf of MAF cleaner.
  12. Oct 27, 2018 at 10:04 AM
    #8252
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Tried that. If anything things got worse. Yes, I was gentle and followed directions. Damn.
    12TRDTacoma[OP] likes this.
  13. Oct 27, 2018 at 10:05 AM
    #8253
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Just order one from rockauto. They have lots of choices.
  14. Oct 27, 2018 at 10:19 AM
    #8254
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  15. Oct 27, 2018 at 10:26 AM
    #8255
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Yeah that’s what I was afraid of. Trying to find a screw in toyota iat. Or maybe even a yamaha one. I would think that would be the best bet
  16. Oct 27, 2018 at 10:32 AM
    #8256
    Athlaos
    Leigh
    Edmonton
    Fascinating stuff. Sounds like a great mod actually. Would this be installed after the intercooler?
  17. Oct 27, 2018 at 10:46 AM
    #8257
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Perhaps a Lexus or scion one??? Idk if they separate them like that but it’s all Toyota
  18. Oct 27, 2018 at 10:50 AM
    #8258
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Well shit...
    Skootter14 and 12TRDTacoma[OP] like this.
  19. Oct 27, 2018 at 10:52 AM
    #8259
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
  20. Oct 27, 2018 at 10:52 AM
    #8260
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Denso only. Anything short is a gamble in quality and you dont want to gamble when you are boosted.
