TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 27, 2018 at 10:52 AM
    #8261
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I think that's his plan. So the ecu reads actual inlet temp after being conditioned with an ice box and meth.
    Athlaos[QUOTED] likes this.
  2. Oct 27, 2018 at 11:01 AM
    #8262
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I think I know the answer to my question, but is that a new tensioner??
  3. Oct 27, 2018 at 11:03 AM
    #8263
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    You do. It is.
  4. Oct 27, 2018 at 11:04 AM
    #8264
    Biscuits
    W.T.F.
    That would enrage me for a number of reasons.
  5. Oct 27, 2018 at 11:06 AM
    #8265
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’ve got the Steeda coming too. We’ll see how it works out. In the past few months I’ve spent way too much on the Tacoma and my wife’s 80.
  6. Oct 27, 2018 at 11:07 AM
    #8266
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Right?
    Luckily, it came from Summit (via eBay), so returning it will not be a hassle.
  7. Oct 27, 2018 at 11:11 AM
    #8267
    Biscuits
    Thankfully.
    If I were in your shoes, I'd send the manufacturer of that tensioner pictures of their sorry excuse for a product along with a letter asking what the heck was wrong with them.
  8. Oct 27, 2018 at 11:17 AM
    #8268
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    That's some disappointment in the quality control department.
  9. Oct 27, 2018 at 11:22 AM
    #8269
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Hadn’t thought of that. I may just do that.
  10. Oct 27, 2018 at 11:32 AM
    #8270
    Biscuits
    Mistakes happen, but that's egregious IMHO.
  11. Oct 27, 2018 at 11:52 AM
    #8271
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I understand you are upset @HolyHandGrenade and others are upset for you as well, I am upset for you also because it otherwise looks like a really nice unit, but stuff happens even during the shipment process. I'm not sure if you guys have seen how shoppers like UPS and FedEx handle their packages but they literally throw stuff across the room. Unfortunately when you are talking about cast aluminum it is all fair game. Which is why I was not comfortable with going for a Steeda.
    Athlaos and HolyHandGrenade like this.
  12. Oct 27, 2018 at 11:55 AM
    #8272
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    It was in a box inside a box. I don’t think I can blame Fedex for this one.
    Who on here was going to make a fully fabricated one? I’d still be in the market.
  13. Oct 27, 2018 at 11:55 AM
    #8273
    ThomasMore66
  14. Oct 27, 2018 at 11:57 AM
    #8274
    Jesse
    Poulsbo
    15' DCSB OR S/C
    What are the symptoms of octane too low? I'm not getting pinging, idles and runs smoothly too. I'm waiting til Tuesday for my new maf sensor. Last I fueled up at one of two places I go. Wonder if their premium isnt as good. Could my computer be pulling timing as a safety measure? Sometimes when I gas it the truck hesitates hard. Like I hit the parking brake. Usually a battery disconnect solved it. Now it happens more frequently. Maybe this is an exercise of patience.
  15. Oct 27, 2018 at 11:58 AM
    #8275
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's the MAF. With zero doubt at all. Mine has exhibited those symptoms before and replacing ththe MAF totally cured it. Make sure you baby it until you get the replacement sensor.
    Athlaos likes this.
  16. Oct 27, 2018 at 11:58 AM
    #8276
    Biscuits
    The defects in that tensioner were not caused by rough handling though. I'm still up for seeing what @XPOTRPR can come up with.
  17. Oct 27, 2018 at 12:01 PM
    #8277
    ThomasMore66
    What brand was that one?
    12TRDTacoma[OP] likes this.
  18. Oct 27, 2018 at 12:05 PM
    #8278
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    This sounds good. But what about methanol corrosion in the intercooler. Isn’t it made of aluminum? Also if the pump goes out for any reason that would be no bueno. @o0opackersfano0o
  19. Oct 27, 2018 at 12:06 PM
    #8279
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I had my intercooler open 30 min ago. I've run meth for months now. No issues there.
  20. Oct 27, 2018 at 12:09 PM
    #8280
    Biscuits
    It depends on the aluminum alloy used for the intercooler and the purity of the methanol with particular focus on chloride content.
    Roostfactor likes this.
