TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 27, 2018 at 12:10 PM
    #8281
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    About to test drive to see if I have the bypass valve correct. My potentially effed maf sensor prevents good launches though. Ugh.
  2. Oct 27, 2018 at 12:11 PM
    #8282
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I imagine the light haze of fuel mixture provides a safe coating too.
    12TRDTacoma[OP] likes this.
  3. Oct 27, 2018 at 12:13 PM
    #8283
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Did you adjust the valve with the blower installed?
    Maybe, and the methanol is diluted. Just something to be knowledgeable and aware of.
    Roostfactor likes this.
  4. Oct 27, 2018 at 12:18 PM
    #8284
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    If the pump goes out or anything the iat sensor will just read what the temp is still. Will just be warmer
  5. Oct 27, 2018 at 12:30 PM
    #8285
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I did it blower installed. Its frustrating. But way easier than dating. Today I took off the cover to check. Think I got it right. Methanol is 50/50. Anything more fails pumps and causes hazards. My goal is only to use methanol as a supplement. Not necessity. Maybe when I get a custom tune I'll have it meth dependent from 4k to redline.
  6. Oct 27, 2018 at 12:39 PM
    #8286
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    For those inquiring about beef tensioners, you can either see if @XPOTRPR is willing to do it, or you could scope out classified for used units, or you could just bite the bullet and get the Thump, or ARS units. Even the Roush one is an upgrade over OE design.
  7. Oct 27, 2018 at 12:59 PM
    #8287
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Steeda
  8. Oct 27, 2018 at 1:08 PM
    #8288
    ThomasMore66
    Dallas/Fort Worth & Durango
    That’s what I thought. Bought same off of Amazon. If the quality wasn’t poor, do you think it would fit?
  9. Oct 27, 2018 at 1:11 PM
    #8289
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I stopped counting once the total hit what I originally paid for me truck
  10. Oct 27, 2018 at 1:12 PM
    #8290
    ThomasMore66
    Shhhh! Stop. I could have bought that GTR.
  11. Oct 27, 2018 at 1:14 PM
    #8291
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Seriously my aluminum welds looked better than that. Hopefully my unit looks better
  12. Oct 27, 2018 at 1:15 PM
    #8292
    ThomasMore66
    Yeah, not to mention that crack in the bolt hole.
  13. Oct 27, 2018 at 1:18 PM
    #8293
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    That was shocking. Nothing like visually checking the unit BEFORE wasting any time on modding it
  14. Oct 27, 2018 at 2:10 PM
    #8294
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yeah I never really noticed corrosion per say in the blower or the outside fins of the intercooler. But I did notice some at the throttle body and coupler after a few years running it.
    Spraying water/meth and atomizing with airflow is one thing. Having liquid methanol constantly inside the intercooler fins is another ballgame.
  15. Oct 27, 2018 at 2:15 PM
    #8295
    ThomasMore66
    Nitrous oxide would cool better...
  16. Oct 27, 2018 at 2:16 PM
    #8296
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. I did a quick wipe down in the intake. Probably giving it too much. Just toned it down today. It's a total experiment for me. If I knew who to ask for help I would.
  17. Oct 27, 2018 at 2:17 PM
    #8297
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. When its paid for and I have a turbo 7 liter I will.
  18. Oct 27, 2018 at 2:23 PM
    #8298
    ThomasMore66
    Yeah, payments are no bueno.
  19. Oct 27, 2018 at 2:33 PM
    #8299
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I’m not putting meth in the intercooler. Im spraying it like normal and running a icebox for the supercharger coolant
  20. Oct 27, 2018 at 2:33 PM
    #8300
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Only 5 more years
