TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 30, 2018 at 7:04 AM
    #8481
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    From what I've read over the years, it seems like 10% of people with UCON are happy, issue free, and have a good tune, 30% are so unhappy they ditch it and return/ resell it, and 60% have frequent issues but are holding out that one day it will be right. And that's not good enough for me.
    Now we have ovtune as an option, where it seems that most everyone that is finally setup and has their tune, is very happy. But it took over a year in some cases after purchase to get there, and 2nd gen sc updates and development doesn't seem to be high on the priority list.
  2. Oct 30, 2018 at 7:12 AM
    #8482
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I will just confirm for anyone here, if you have the same exact mods as I had when my truck was dyno’d, and you get an ovtune handheld, you can request my dyno tune specifically and he will upload it for you. Mods at time of dyno were:
    2.85 pulley, bypass jet removed, afe stage 2 si intake, short tube headers, stock ypipe, 3” catback. DW 255 lph fuel pump, trd injectors, trd tune. I feel like I am forgetting something but I think that was everything.
    I know most of you have smaller pullies so that isn’t very helpful for you, but maybe others on here. Also the dyno was done at 800 ft above sea level, and if I remember correctly it was around 80 F in the dyno room.
    Also since said dyno tune I have added a ypipe and the valve body upgrade with no issues.
  3. Oct 30, 2018 at 7:35 AM
    #8483
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Yeah mine was a pos...
    Only thing that really matters is ovtune never left me stranded, the ucon did.
  4. Oct 30, 2018 at 7:42 AM
    #8484
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just ordered the Smoothflow 2.5" with RIP. @JuanitoBunito, you're going to have to step up here. The train is leaving you.
  5. Oct 30, 2018 at 7:52 AM
    #8485
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That was like my GTO. I was a pioneer in that arena. I had one of the fastest NA builds by using some real unorthodox methods in doing so. I pissed off a lot of people because it entirely went against everything they were spoon fed to preach to me that required modding to build over on that engine. Life was good. :D
    If I had that car today still (if only GM didn't build such garbage) I would still be blowing the doors off people with it.
    Unfortunate that he WAS such a good source for parts. I have literally built 98% of my truck without his stuff. The only reason why it has anything of his is on it is because he has a good intake design and because I picked it up second hand, due to his shitty customer service, and my firsthand experience in dealing with him so, I refuse to buy anything of his, at any point.
    So did the UCON clear up those weird running problems you had man?
    Speaking of which how is that valve body upgrade I did for you working out for you?
  6. Oct 30, 2018 at 9:51 AM
    #8486
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I can see that, you guys are breaking barriers here lately. I’m still comfy where I’m at.
  7. Oct 30, 2018 at 9:56 AM
    #8487
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Yeah, the GTO was a piece of sh!t. So I hear, anyways. Fun project, I'm sure, though.
    I'd say you're definitely pushing some limits by using the smaller pulley with TRD tune....
  8. Oct 30, 2018 at 10:17 AM
    #8488
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Unfortunately, we've heard that for months. :rolleyes:
    +1.
    Sad, but probably accurate.
    Congrats!
    Something my wife and I agreed on years ago was establishment of a "man account." It's auto-funded every month, and I use the funds to buy whatever I want for both my "garage mistresses" (the Tacoma and my Shelby). This lets her "budget" what I spend on go fast stuff, keeping both of us happy.
  9. Oct 30, 2018 at 10:28 AM
    #8489
    Athlaos
    Leigh
    Edmonton
    My girlfriend would be on-board with something like that. She's almost too good with money. It's been 9 months and she's already saying stuff like "so there's no more mods to do now? Just basic maintenance?"
    Lol
    mr.trd, Biscuits, Roostfactor and 3 others like this.
  10. Oct 30, 2018 at 10:29 AM
    #8490
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Thanks man. And I like that idea. Might have to bring that up or at least something like it when the time comes.
    Biscuits and Norton[QUOTED] like this.
  11. Oct 30, 2018 at 10:39 AM
    #8491
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    My wife has horses. I have cars lol. She tells my the xrunner is a money pit and I just remind her that still less money involved then horses. Side note saving some money. Got snipped today so no more kids for me lol. Looks like I’ll be cruising tacoworld all day
  12. Oct 30, 2018 at 10:43 AM
    #8492
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Horses are way more expensive than trucks. And not nearly as fast. Heal up quickly, I know that's my plan in a few years after we have however many we decide to have
  13. Oct 30, 2018 at 11:59 AM
    #8493
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Ah yes, cruising Tacomaworld with frozen peas on the jewels.
  14. Oct 30, 2018 at 12:14 PM
    #8494
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I'm lucky that my GF hasn't paid attention to how much more I spend on the truck than her :fingerscrossed:
    But I know I'm living on borrowed time as far as that goes....
  15. Oct 30, 2018 at 1:23 PM
    #8495
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    You definitely have the greatest pulley ratio for the TRD blower I’ve ever witnessed. Only one other person I know had a snake bite mod from stiegemeier. It produced something like 16 lbs on the 3 inch stock pulley but the engine didn’t last very long. Not sure if he was APRx1 tuned or not.
  16. Oct 30, 2018 at 1:29 PM
    #8496
    Athlaos
    Leigh
    Edmonton
    Yes, I've heard about that somewhere else on this forum.
    12TRDTacoma[OP] likes this.
  17. Oct 30, 2018 at 1:29 PM
    #8497
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Wasn't the guy running that setup also running an increased redline?
    At that boost amount proper tuning is critical, and if the tune was off it is entirely plausible that he blew up the engine simply because the tune was incorrect. Human error is a high factor when it comes to modding and high horsepower.
  18. Oct 30, 2018 at 1:39 PM
    #8498
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I was just talking to a Silverado guy and he couldn't believe the performance you can get out of a 4.0L v6 with our blowers. And to think most of us drove them home with a beastly 236hp at the crank.
    Roostfactor, Biscuits, Norton and 6 others like this.
  19. Oct 30, 2018 at 1:41 PM
    #8499
    Athlaos
    Leigh
    Edmonton
    Reminds me of guys in my car club (Nissan Z cars) who would buy an electronic boost controller and turn it up to 16psi on a stock tune. They say it was fast as fnck... until they had no more engine the first time they hit 6000rpm. Adding boost takes a little bit more thought than that.
  20. Oct 30, 2018 at 1:42 PM
    #8500
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is nothing more pleasing than walking or entirely blowing the doors off a V8 truck, or even V8 higher horsepowered car when they were not even close to expecting it out of a little gutless Tacoma.
    These engines are very slept on and configured correctly using the right combinations of parts and supporting mods, you could get some serious power out of them.
