TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 30, 2018 at 7:38 PM
    #8561
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks. I'll take some video this weekend.
  2. Oct 30, 2018 at 7:44 PM
    #8562
    ThomasMore66
    Dallas/Fort Worth & Durango
    I think mine make a fluttering kind of sound. Might be the cats too, however they have a honeycomb kind of fill in them.
  3. Oct 30, 2018 at 7:47 PM
    #8563
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I only have one cat now. I need a second person to verify. @crashnburn80 and I are going to do my fuel pump Sunday. I'll take some video then and get his opinion.
  4. Oct 30, 2018 at 7:52 PM
    #8564
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You WILL have the y-pipe! Shop re-opens tomorrow!
  5. Oct 30, 2018 at 7:53 PM
    #8565
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Are you running larger than stock tires on stock gears?
    I ask, because that’s what my truck did post larger tires. Re-gear solved the problem.
    DocME, Biscuits and Roostfactor like this.
  6. Oct 30, 2018 at 7:53 PM
    #8566
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @Roostfactor, do you remember the maintenance checks one can do on TB internals?
  7. Oct 30, 2018 at 7:54 PM
    #8567
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Mine does it too. 456's someday for me.
  8. Oct 30, 2018 at 7:59 PM
    #8568
    ThomasMore66
    Mine too. And I have this weird vibration that only seems to occur in 5th. Manually shift a lot.
  9. Oct 30, 2018 at 7:59 PM
    #8569
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I thought I was part of the secret boosted society lol...:tumbleweed:
  10. Oct 30, 2018 at 7:59 PM
    #8570
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol.. IDK about that man. I'd like to give him another run for his money too.. especially after my new setup.. but that group doesnt screw around.. haha then again.. Im going weighed down. Maybe I should while the tent is off currently.. Need to get a new Y pipe before then too.
    it is fun tho. I had a guy in a new civic si pull up to me at a light and say how surprised he was at the quickness.
    :rofl: they knew it was going to be one sided.. they were cool.
    :laughing: we caught so much shit for that. 3 dudes, 3 tents. truck was LOADED. it did great tho pulling it all up grades and going from 1200 to 8000 feet.
  11. Oct 30, 2018 at 8:05 PM
    #8571
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Well of course you are. Entry is at least 2 gauges. You're all good!
  12. Oct 30, 2018 at 8:06 PM
    #8572
    Roostfactor
    TX panhandle
    Yes it would!
    BassAckwards[QUOTED] likes this.
  13. Oct 30, 2018 at 8:07 PM
    #8573
    Roostfactor
    TX panhandle
    You have a 5 floor garage? Jealous!!!
    XPOTRPR likes this.
  14. Oct 30, 2018 at 8:12 PM
    #8574
    Roostfactor
    TX panhandle
  15. Oct 30, 2018 at 8:19 PM
    #8575
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no shit? that's badass! every month they have the sand drags and mud bogs going on. make a trip! lol
  16. Oct 30, 2018 at 8:22 PM
    #8576
    Roostfactor
    TX panhandle
    That's a mighty shaft for a white boy!
  17. Oct 30, 2018 at 8:22 PM
    #8577
    ThomasMore66
    I wish. There is a really nice part of Dallas called Highland Park. I’ve seen a couple of houses in there with garages under the house. I’d like one of those.
  18. Oct 30, 2018 at 8:23 PM
    #8578
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I don't understand this. I don't mean to be cheeky, I genuinely don't understand how one correlates with the other.
    Why? It's an "I Voted" sticker. Zero discussion of candidates or political party. Voting is a basic requirement to be a contributing part of this country. If someone said they are or were military, how is that any different than saying they voted?
    CPO... Certified pre-owned?
    They're the problem in that case, not you.
    When you do, make sure it's recorded. Lol
    That's a hell of a lot different than saying you voted. Regardless, if merely saying that someone voted will cause riots in this thread, then we won't talk about it or anything else government related. No California CARB regulation discussion.
    :laugh:
    Aliens.
    I dip mine daily in sulfuric acid. Lol.
    I think I've clean the throttle body two or three times in a combined ~130,000 mi between my two Tacomas.
    I hear a fluttering sound on hard acceleration ever since I installed my boost and AFR gauges.
    You and I need to have a two person group buy on 4.56's...
    You are. We eat cookies and play tummy sticks.
  19. Oct 30, 2018 at 8:24 PM
    #8579
    Biscuits
    The water table allows for garages underneath residental homes up in Dallas?
    Roostfactor likes this.
  20. Oct 30, 2018 at 8:27 PM
    #8580
    Biscuits
    REPORTED.
    To the Bureau of Hilarity.
