TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 25, 2017 at 9:59 AM
    #861
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    No. This design will be a direct from factory ECM to an external tuner source where you can modify parameters.
    This design is virtually the same concept that is HPtuners for GM.
    Biscuits and ls1 prerunner like this.
  2. Nov 25, 2017 at 7:09 PM
    #862
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    Temecula
    Only windows based computers...that sucks!
  3. Nov 25, 2017 at 7:11 PM
    #863
    ThomasMore66
    Dallas/Fort Worth & Durango
    Real world.
    Norton and 12TRDTacoma[OP] like this.
  4. Nov 25, 2017 at 7:24 PM
    #864
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You should be able to have the option to choose between the two. It is 2017 for Christ sakes! For all this technology out there sure is a lot of "incompatibility" around.
    ExpoSpy[QUOTED] likes this.
  5. Nov 25, 2017 at 7:28 PM
    #865
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You can run it on a Mac running Windows w/ Bootcamp.
  6. Nov 25, 2017 at 7:32 PM
    #866
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That would make it "Windows based."
    How many folks out there who use mac computers really go through all the extra trouble of installing and running boot camp? Unless they use programs which specifically require it's usage on a regular basis, your average mac consumer does not use it.
    loginfailed[QUOTED] likes this.
  7. Nov 25, 2017 at 7:35 PM
    #867
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Put the quotation marks wherever you want, bro. :thumbsup:
    If you have a PC, you can run it.
    If you have a Mac, you can run it.
  8. Nov 25, 2017 at 7:36 PM
    #868
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  9. Nov 25, 2017 at 7:37 PM
    #869
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  10. Nov 25, 2017 at 7:37 PM
    #870
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Me.
    It took me awhile but I finally got it to work without paying a cent
    loginfailed likes this.
  11. Nov 25, 2017 at 7:40 PM
    #871
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    In b 4 pc v mac debate.
  12. Nov 25, 2017 at 7:41 PM
    #872
    12TRDTacoma
    Rob
    Concordia
    Boosted
  13. Nov 25, 2017 at 7:42 PM
    #873
    inwood customs
    Dave
  14. Nov 25, 2017 at 7:42 PM
    #874
    inwood customs
    Dave
    Linux
  15. Nov 25, 2017 at 7:42 PM
    #875
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
  16. Nov 25, 2017 at 7:42 PM
    #876
    inwood customs
    Dave
    Hackintosh
  17. Nov 25, 2017 at 7:45 PM
    #877
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You can run that on a Mac too.
  18. Nov 25, 2017 at 7:45 PM
    #878
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    U mad, bruh? :D
  19. Nov 25, 2017 at 7:47 PM
    #879
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  20. Nov 25, 2017 at 7:54 PM
    #880
    inwood customs
    Dave
