TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 2, 2018 at 9:55 AM
    #8821
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    cowl hood!
    i get 11 consistently with no supercharger.. towing is down to 9-10. but this thread does make me want one..
    mr.trd and Skootter14[QUOTED] like this.
  2. Nov 2, 2018 at 9:57 AM
    #8822
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I have actually gotten 19-20, with the supercharger, on the highway, if I was going exactly the speed limit.
  3. Nov 2, 2018 at 10:12 AM
    #8823
    Athlaos
    Leigh
    Edmonton
    I just did a quick calculation. I've put approximately 2.7 MILLION revolutions on my new idler since I installed it a few days ago. I figure that's a good shakedown.
  4. Nov 2, 2018 at 10:27 AM
    #8824
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I got around 13.6 pre S/C, and it’s slowly been creeping up since February. I’ve been sitting 14.3 for quite some time but I’m still hoping to squeeze out a little more mpg
    Edit: data from my ultra gauge
    12TRDTacoma[OP] likes this.
  5. Nov 2, 2018 at 10:43 AM
    #8825
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I get 10-11 pulling my camper
  6. Nov 2, 2018 at 11:00 AM
    #8826
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    If it is crank hp, something seems off with that ratio.
    I did some 3rd gear WOT runs at lunch today and my best MAF on OVTune was 308 g/s. That's roughly 363bhp and 309whp on a 2.5 pulley and its about 45 deg OAT. I dyno'd 314whp on the 2.7 pulley in July with 90 deg temps. All other mods are the same. Boost was about 9.5 and AFRs were high 9s.
    Interestingly, I switched back to the TRD tune and the same WOT runs saw a best MAF of 317 g/s. Boost was 9.5 and AFRs were a little leaner at low-mid 10s, so the TRD tune seems to be making more power than OVTune on the smaller pulley. OVTune made more power on the 2.7.
    Either way, I think my exhaust combination of the DT shorties, 300cfm cats, and TRD 2.5 catback is restricting MAF for the 2.5 pulley. I know the cats are more restrictive than some others.
    Also found out that the OVtune handheld has the datalogging function disabled. You can view real-time data but it will not log even though the option is in the menu.
  7. Nov 2, 2018 at 11:08 AM
    #8827
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Everything goes back to the TRD tune they say. LOL
    Biscuits, jojotoo and Athlaos like this.
  8. Nov 2, 2018 at 11:14 AM
    #8828
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Seems to hold true for my setup - at least until OVTune dials in his tune or provides a custom solution.
  9. Nov 2, 2018 at 11:54 AM
    #8829
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Everything went on today, I was, however, regretfully unable to run the new idler despite the AWESOME belt wrap it gave because the new tensioner arm would strike the fan clutch due to the new increase in tension it gave the belt.
    The only solution is to either A. run a new smaller fan clutch setup if something like that even exists? B. switch to an E fan, C. remove some material off the very tip of the tensioner or D. remove a little bit of material off of every little fin on the fan clutch.
    So I ran the setup as designed. The engine seems to wind up a tad bit faster now with the NST pulley. The stock crank pulley was starting to look like crap anyways so I'm glad I changed it. Nothing huge to write home about, but what I'm really stoked about is running this double bearing rigged tensioner assembly. Idle and boost seem to be so much more stable and consistent now!
  10. Nov 2, 2018 at 12:24 PM
    #8830
    Athlaos
    Leigh
    Edmonton
    Awesome, improved throttle response too? I noticed that each time I took steps to improve belt slip.
    Sucks on the tensioner interference tho. I'm lucky there, I have the e-fan mod.
  11. Nov 2, 2018 at 1:07 PM
    #8831
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Some improved throttle response. I have noticed that anytime you improve belt slippage the throttle response picks up as well.
    BassAckwards and Athlaos[QUOTED] like this.
  12. Nov 2, 2018 at 1:12 PM
    #8832
    Athlaos
    Leigh
    Edmonton
    Nice. Have you thought about removing the non-ribbed idler just below the lower wrap idler? That's what I did when I put my upper wrap idler on. Mostly the belt just wouldn't fit without doing that. But it was kind of a redundant idler in my opinion, with the lower wrap pulley added. Or you could put a smaller idler in its place. It might give you just enough to make your tensioner not interfere with the fan. Having no idler there has been working fine for me, the belt functions just fine without it. Here's the picture again for reference.
    Norton, Biscuits, Torspd and 4 others like this.
  13. Nov 2, 2018 at 1:23 PM
    #8833
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. It is worth playing around with!
    Athlaos[QUOTED] likes this.
  14. Nov 2, 2018 at 2:29 PM
    #8834
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Birdy told me gadget is gonna do it. Shhhh
  15. Nov 2, 2018 at 3:36 PM
    #8835
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I would say Efan and that would give even better throttle response. The only thing I don’t like about the efan is it’s another thing to worry about vs a clutch fan is solid and good to go. But if done right could be great.
    Are you not worried about harmonic dampening? Not sure if our trucks are internally balanced. Did the steel sleeve fit just right or did you have to sand it down? @12TRDTacoma
  16. Nov 2, 2018 at 3:38 PM
    #8836
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The issue for me is just that, reduced reliability, and it is way too easy to overheat an engine once the fan motor fails. I'd rather stick to fan clutch, as much as I hate it, it does work really well. Maybe I can start investigating a smaller design fan clutch, because I'm sure they are made.
    Alternatively I could always try to run the setup the way @Athlaos has it, which actually would and obviously does work!
    I am not worried about the dampening. If there were issues with the NST pulley after so many members running them for years and years already, we would had seen an engine internally melt down or something catastrophically loosen by now. The steel sleeve was already in place on the pulley, as NST has since rectified that issue with their previous pulleys and it went right in with little effort. It fits like a glove.
    ls1 prerunner, Athlaos and jojotoo like this.
  17. Nov 2, 2018 at 4:24 PM
    #8837
    ThomasMore66
    Dallas/Fort Worth & Durango
    Then I’m going to need a 6L80.
    Biscuits and Athlaos like this.
  18. Nov 2, 2018 at 5:41 PM
    #8838
    Athlaos
    Leigh
    Edmonton
    The radiator and shroud I got are great, but the fan supplied was not. I bought a low profile Spal fan and it works great.
  19. Nov 2, 2018 at 5:44 PM
    #8839
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There within lies my point. Lol.
    Way too many variables for today's cheap made in China electronics to go wrong then cause catastrophic engine damage. (Not the SPAL, I meant the fan itself)
  20. Nov 2, 2018 at 6:07 PM
    #8840
    Athlaos
    Leigh
    Edmonton
    Yeah, it’s a good point that an electric fan could be knocked out easier than a clutch fan.
