TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 3, 2018 at 10:20 AM
    #8861
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Also, I believe gear ratio is only relevant to dyno hp.
    The Maf conversion is not affected by gear ratio.
    BassAckwards and Roostfactor like this.
  2. Nov 3, 2018 at 10:21 AM
    #8862
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    ^^^this^^^
    BassAckwards likes this.
  3. Nov 3, 2018 at 11:15 AM
    #8863
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Hey I have the same controller that I’m wiring up!
    1st where did you fit in, it’s actually massive!
    2nd what wire did you use to trip the a/c, was it one of the wires to the clutch?
    3rd what did you use to source acc power?
    Edit: I think you have a thread on this. I’ll copy there.
  4. Nov 3, 2018 at 1:23 PM
    #8864
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I posted where to get the A/C trigger here:
  5. Nov 3, 2018 at 2:10 PM
    #8865
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    A good one is better in my opinion.
  6. Nov 3, 2018 at 2:17 PM
    #8866
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Did you use the oem shroud? Any tips?
  7. Nov 3, 2018 at 3:00 PM
    #8867
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Ahhh, i can honestly say, the speed unlimiter is one thing i love about the ucon!
  8. Nov 3, 2018 at 3:23 PM
    #8868
    DocME
    California
    '07 FJ Cruiser
    Awesome! I’ve been perusing the electrical schematics to find something like that.
  9. Nov 3, 2018 at 4:28 PM
    #8869
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My E-fan is a Dorman unit from a mid-90’s Volvo. I think the one @Roostfactor has from the the Lincoln probably moves more air and is quieter. But mine works well enough.
    The cool thing about e-fan setups is you can go as basic or as elaborate and fancy as you want with regards to speed controls, fans and shrouds.
  10. Nov 3, 2018 at 5:05 PM
    #8870
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Slapping the blower on my truck made it MORE reliable than it previously was.
    The cars with E fans come that way from the manufacturer. They are designed direct from the manufacturer with longevity in mind using non made from China parts, and circuitry. (Usually)
    When purchasing fan motors and other related items from Dorman, or TYC, etc. etc. You can immediately see the decline in use of quality material usage in comparison to the OE stuff. Yeah the stuff may fit like OE, but the quality is usually questionable at best as to how long it will last. It's a guessing game really.
    The problem that concerns me about aftermarket setups is it can be and sometimes actually is made using inexpensive and inferior items which can compromise the integrity of an otherwise well thought out or quality system.
    That's just the way I see it.
  11. Nov 3, 2018 at 5:19 PM
    #8871
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have a hard preference for mechanical fans too... :spy:
  12. Nov 3, 2018 at 5:19 PM
    #8872
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Fans that spin at 100,000 rpm?
    Hahaha.
  13. Nov 3, 2018 at 5:22 PM
    #8873
    BassAckwards
    Are there any toyotas that you know of that came from the factory with an Efan? If i was to go the electric fan route, i would want to try and modify something OEM to fit in the truck...
  14. Nov 3, 2018 at 5:26 PM
    #8874
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would love to do that myself honestly.
    With that being said, I don't know if any Toyota truck or SUV that came with an electric fan from the factory. All of the ones I see are clutch driven.
    BassAckwards[QUOTED] likes this.
  15. Nov 3, 2018 at 5:29 PM
    #8875
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pff. Upscale. 130k. :p
  16. Nov 3, 2018 at 5:29 PM
    #8876
    BassAckwards
    I'll have to do some more research on this. Like you said though, i'd bet all of them are clutch driven. Would be sweet though if i was able to find one. Perhaps one from overseas.. Off to the search now :typing:
  17. Nov 3, 2018 at 5:48 PM
    #8877
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Whatever floats your boat, guy.
  18. Nov 3, 2018 at 5:53 PM
    #8878
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Sequoias have a clutch fan and an electric push fan on the other side of radiator.
    Roostfactor and BassAckwards like this.
  19. Nov 3, 2018 at 6:09 PM
    #8879
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Please... Are you really trying to compare the reliability of a TRD SC vs an efan?
    My point is if our blowers stop working there’s usually no damage. If an engine over heats than there is usually damage.
  20. Nov 3, 2018 at 6:12 PM
    #8880
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Or we could look to Lexus or scion models too.
