TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 4, 2018 at 11:29 AM
    #8921
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    The avalons have a v6 & efans
  2. Nov 4, 2018 at 1:52 PM
    #8922
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Avalon’s are 2gr and have a wide radiator.
  3. Nov 4, 2018 at 2:45 PM
    #8923
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    huge difference between 1gr and 2gr
  4. Nov 4, 2018 at 2:51 PM
    #8924
    richiep
    Rich
    NY
    My apologies if I'm mistaken, but a few years back I saw a engine pulley TSB regarding the 1gr for tacoma's & avalons
    & my neighbor has an 08 avalon & I thought it was a 1gr. anyway, it is a v6 with an efan.
    BassAckwards and Torspd like this.
  5. Nov 4, 2018 at 6:49 PM
    #8925
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    No pulley swap for me today. Foiled by a failed fuel pump mission. F×<# the engineer at toyota that designed the fuel fittings.
  6. Nov 4, 2018 at 7:04 PM
    #8926
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The vent fitting can be fun to get off.
    12TRDTacoma[OP] likes this.
  7. Nov 4, 2018 at 7:10 PM
    #8927
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Wont come off. It's broken and stuck on. Ran out of time fussing with it. Solution #1 buy a new one and destroy the old one. Solution #2 destroy the old one and make something work.
    Athlaos likes this.
  8. Nov 4, 2018 at 7:37 PM
    #8928
    Roostfactor
    TX panhandle
    Spray the whole area with high pressure nozzle. Then spray wd40 or similar to the area. Let sit for 30 mins and disconnect it.
    Work smarter not harder. It will come off. If you have to force it somethings wrong.
  9. Nov 4, 2018 at 8:43 PM
    #8929
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What fuel fittings are you referring to?
    This has literally been the name of the game both in the Army and my automotive career for a very long time now. I couldn't had said it better myself. :thumbsup:
  10. Nov 4, 2018 at 8:45 PM
    #8930
    Roostfactor
    TX panhandle
    Most likely the tank vent line next to the fuel fill line you have to disconnect when you drop the tank.
  11. Nov 4, 2018 at 8:48 PM
    #8931
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The little fitting on the fuel neck disconnect. Both crashnburn and I worked at it for a few hours til our hand were banged up. No dice. The fitting is literally broken and cant release. I have to have a new one on hand or more time in the day.
  12. Nov 4, 2018 at 8:48 PM
    #8932
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh... that explains why I was not familiar with. May it be my suggestion to @White lightning boosted to just lift the bed enough to be able to access and remove the pump bucket assembly instead of screwing with dropping the tank as a whole.
  13. Nov 4, 2018 at 8:49 PM
    #8933
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Can only do that with long beds.
    Athlaos likes this.
  14. Nov 4, 2018 at 8:53 PM
    #8934
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh shoot, you have a short bed?
    In that case follow @Roostfactor's instruction. If you must drop the tank without any other option, that is probably the best route to removing the thing you are having issues with.
  15. Nov 4, 2018 at 9:12 PM
    #8935
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yeah, dropping the tank isnt all that tough with 2 guys. Crashnburn and I did his a few months ago, same truck. This fitting is in a tough spot. We learned a lot on his. My fitting just failed. We'll get it next weekend. Seriously toyota? Couldn't use a spring clamp like everywhere else on the truck.:jerkoff:
  16. Nov 4, 2018 at 9:17 PM
    #8936
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What are they using to hold it down? A band clamp like those stupid CV axles of ours?
  17. Nov 4, 2018 at 9:26 PM
    #8937
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That would be an upgrade. Just a two pinch point plastic fitting. Sounds simple cause it is. This one broke inside so I'll have to cut it off.
  18. Nov 4, 2018 at 10:45 PM
    #8938
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I had an issue with that same 2 pinch vent line. It took me longer to get it undone then dropping the tank completely. That one sucks; mine seemed a little messed up too but everything works fine
    Roostfactor likes this.
  19. Nov 5, 2018 at 1:53 AM
    #8939
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I found the best way is to just tap it with a screw driver. They are usually filled with dirt and sand. And as u tap the vibrations loosen up all the sand and what else is around it. And it ones of those things u have to tighten to loose. Push it together as tight as u can and then pinch both sides and pull apart. Got to be easy with them tho.
  20. Nov 5, 2018 at 3:18 AM
    #8940
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This. And a little squirt of WD40 helps too.
