TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 8, 2018 at 10:46 PM
    #9181
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The intake size is EVERYTHING for our trucks. The larger the size we can run the less knock is present during throttle. As for me, I need the largest possible so I'd like to do a large to small style if possible. The stock airbox will have to strictly be for smog as bad a restriction as it is.
  2. Nov 9, 2018 at 1:05 AM
    #9182
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Why don’t you just slap the eo sticker that came with the Toyota air filter (supercharger kit) on an AFE box with a coupe lid? Looks factory
  3. Nov 9, 2018 at 1:16 AM
    #9183
    DocME
    California
    '07 FJ Cruiser
    Knock and lean conditions are the result of too much air to fuel. So are you saying the stock box is giving you too much air? Or just an unbalanced tune?
    If the stock intake was a restriction, then you’d be running rich, assuming the ecu didn’t trim accordingly. Regardless what the intake allows through, the maf should be measuring, and ecu compensating. If your afr’s are outta whack when changing intakes, the maf’s reading are probably skewed. The true test of the intake would be to look at the grams/sec that the maf reads and compare them between intakes at similar load and rpm’s.
  4. Nov 9, 2018 at 1:23 AM
    #9184
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That is correct. My bad.
    Athlaos[QUOTED] likes this.
  5. Nov 9, 2018 at 1:43 AM
    #9185
    Roostfactor
    TX panhandle
    Thank you!
    Athlaos likes this.
  6. Nov 9, 2018 at 1:46 AM
    #9186
    Roostfactor
    TX panhandle
    The maf is calibrated for a 3" opening. If you put it in a larger opening then it will "see" less air and force a lean condition.
  7. Nov 9, 2018 at 1:49 AM
    #9187
    Roostfactor
    TX panhandle
    How does a restriction correlate to a lean mixture?
  8. Nov 9, 2018 at 6:28 AM
    #9188
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I don’t think it will...
  9. Nov 9, 2018 at 6:50 AM
    #9189
    Athlaos
    Leigh
    Edmonton
    I don’t know why I haven’t had this fabled issue.
    richiep likes this.
  10. Nov 9, 2018 at 6:56 AM
    #9190
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    You're Canadian exemption:)
  11. Nov 9, 2018 at 7:07 AM
    #9191
    Athlaos
    Leigh
    Edmonton
    It's all the snow stuck in my filter.
  12. Nov 9, 2018 at 8:00 AM
    #9192
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Sure is hard to get the supercharger belt off with all this extra room.
    #electricfanproblems
    :rofl:
  13. Nov 9, 2018 at 8:01 AM
    #9193
    DocME
    California
    '07 FJ Cruiser
    @12TRDTacoma , if you’re running lean after installing an intake with more restrictions, my first thought gravitates to a vacuum leak. That would allow unmetered air to affect the way the engine runs and give error codes. Might be worth evaluating.
  14. Nov 9, 2018 at 8:08 AM
    #9194
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't care what the rationality is here or how correct you guys might be. Engine knock > proper engine theory of operation.
  15. Nov 9, 2018 at 8:11 AM
    #9195
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No but really, I am not willing to gather any data at this point with the stock airbox in the configuration I have because the knock is that ridiculous right now and I do not want to blow up my engine just so I can collect some airflow data. All I can tell you is that it makes that much of a difference when switching out to a properly constructed intake. Perhaps it is because like you said @DocME that the stock airbox is just unbalanced.
    ls1 prerunner likes this.
  16. Nov 9, 2018 at 8:11 AM
    #9196
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    This will work for years 05-11. Trd never had an approved system for the 12-15. So I am SOL on this as well. Swapping the stock box isn’t that big of a deal though.
    Roostfactor and 12TRDTacoma[OP] like this.
  17. Nov 9, 2018 at 8:13 AM
    #9197
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Have you looked into the dual vvti fj/4runner 4.0 intakes? I think they are a straighter design. I know someone on this forum posted it. Let me know if you want me to find the thread
  18. Nov 9, 2018 at 8:14 AM
    #9198
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You would think so, but there is nothing other than tube and air cleaner box in the setup. Both of which are mostly before the MAF itself. The only thing that goes after the MAF is the opening you bolt up to the TB and I know all those connections are tight. I may just swap to the 2.5 and retry a quick run. Worst comes to worst I'll do a smoke test and check to see if any vacuum leaks indeed do exist.
    I hate you. Lol. LOOK AT ALL THAT SPACE!
    Now that I found all the bolts for the setup I am more than willing to swap intakes now. :D
    loginfailed[QUOTED] likes this.
  19. Nov 9, 2018 at 8:16 AM
    #9199
    12TRDTacoma
    Rob
    Concordia
    Boosted
  20. Nov 9, 2018 at 8:21 AM
    #9200
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    You actually can run a 3.5” or 4”, as long as it tapers back into the 3” where the Maf sits. You can use 2 silicone reducers; before and after the maf. I had an Injen air Intake on a previous vehicle that was 3” and tapers to a 2.5” to accommodate the maf and then back to 3”.
    My URD MK1 Kit came with a built in TCAI and yes the P0101 was a common code that came up. With a scan gauge it was too easy to just check the code and reset. But if you didn’t like it, the best way is to install the Injen heat shield which I would also use for splashing in the mud.
    I currently have a POS K and N “CAI” that the old owner tossed in with the SC, and where the intake sits, the heat shield box thing is hardly sealed off so I constantly see +5 IAT vs ambient and can raise +10-15 when idling. I have some 3” elbows and pipe on the way so I can build my rendition of the URD TCAI. The filter won’t be covering the heat exchanger and the maf will be moved further back downstream.
